01-08-2021, 09:08 AM
#1061
Foothill Ranch
Looking good!
I used the 2000f paint on mine.... and it is pretty soft until it cures. Ended up scratching it up on reinstall.
01-08-2021, 09:30 AM
#1062
Churubusco
, Indiana
Originally Posted by PeterH-Airstreamer
with the new fuel combinations and additives, fuel lines have been going through their own evolution. The intank stuff is SAE J30 R10 and is only supposed to be used submersed in fuel. It can not be used in hot engine compartments. Your outside hose looks like the newer carb compliant stuff, I have been using. I am just surprised is no SAE ID #
But, I am sure this is the last thing you are concerned about at this point, considering how close you are to turning the key
Yes, I am very excited to turn the key. Was starting to feel like it would never get there, pulled the carb off nearly a month ago! Meanwhile bob and Charlie have swapped a whole engine
01-08-2021, 09:39 AM
#1063
Churubusco
, Indiana
Originally Posted by Keyair
Looking good!
Good to know. I saw their recommended curing cycle on the can, will be careful. I'll still certainly scratch them up, but I'll be careful while doing it
01-08-2021, 10:34 AM
#1064
Churubusco
, Indiana
how will you plug up the old fuel connections.
Not pretty but they're plugged. And cheaper than the $15 each billet aluminum plugs.
01-08-2021, 11:01 AM
#1065
Churubusco
, Indiana
Fresh rubber tank strap pads
01-08-2021, 03:30 PM
#1066
Foothill Ranch
Where did you find those!!!!!
01-08-2021, 04:36 PM
#1068
Churubusco
, Indiana
Tank, in!
And nice easy access from inside!
01-08-2021, 04:43 PM
#1069
Airstream Driver
1994 30' Excella
1992 35' Airstream 350
Austin
Originally Posted by Magnet18
Tank, in!
That's nice to have access like that. My fresh water tank is right on top of the fuel tank. You must have a 60 gal tank. Mine is 80 gal has 3 straps and a total of 4 bolts on the ends.
AIR #13
01-08-2021, 06:51 PM
#1070
Churubusco
, Indiana
California special... 40 gallon
On the bright side, i easily just bench pressed it right in
01-08-2021, 07:23 PM
#1071
Churubusco
, Indiana
Pulled the exhaust down so I could access the lines.
Guess what I found... Yea... Brake line rusted halfway through
I have a service reciept for the PO paying a shop to replace all the brake lines.
The rest of the brake lines are more or less fine, look to be - 5 years old I'd guess? Not more than a few tiny spots of rust at least. I'm guessing the shop just ignored the hard to access section because they didn't want to deal with it behind the exhaust.
Half a mind to have my lawyer buddy send that shop a letter.
Anyway, i think i lucked out in that it might be a standard 40" length. I can swap out.
Ignore the green from the shorted out copper wire from the chassis batt. *Sigh*
01-09-2021, 10:27 PM
#1072
Churubusco
, Indiana
Only got a half day in today
Got the old lines out
Made a new shower curtain
01-10-2021, 09:37 AM
#1073
Churubusco
, Indiana
Brake line replaced
In the teens in the shop this morning... Busting ass to get out of here sooner than later, tired of this weather
01-10-2021, 09:51 AM
#1074
Airstream Driver
1994 30' Excella
Austin
Brake line replaced
Come on down, getting it all ready for you.
Next weekend 60/40
AIR #13
01-10-2021, 10:57 AM
#1075
Foothill Ranch
Those brake lines are scary... dont miss the fixing rust days at all... but then again, there are many man made things that suck in Kalifornia...
01-10-2021, 11:20 AM
#1076
Churubusco
, Indiana
Next weekend 60/40
60/40 sounds perfect. Heck, I'll settle for anything above 32 right about now.
Next weekend is feeling ambitious but I'm pushing hard. Tubing on hold until I get the straightener tomorrow. Wrapping up the dash today, then when I put the fuel line in it should be all ready to fire up!
Tried pulling the old tires off myself... No luck... You guys must know a trick I don't. Might have to outsource that.
Also centramatic still hasn't shipped the rear duals... Hopefully those ship this week
01-10-2021, 11:23 AM
#1077
Churubusco
, Indiana
New shower curtain is actually white, and i made a quick modification so it can be pulled down and washed without having to drill out rivets... Good one there airstream...
01-10-2021, 12:55 PM
#1078
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim
, New York
Regards, Bob
01-10-2021, 10:01 PM
#1079
Churubusco
, Indiana
Originally Posted by bobmiller1
01-11-2021, 08:44 AM
#1080
Churubusco
, Indiana
Now I see why Bob posts pictures of his perfectly straight tubing, what a pain
