Old 11-07-2020, 10:38 AM   #861
Magnet18's Avatar
Churubusco , Indiana
Originally Posted by PeterH-Airstreamer View Post
Pretty impressive, Rob. Hats off for sticking with it and getting it done the right way !
Thanks Peter!
I've never been accused of lacking stubbornness
Playing detective here, these gears look fine to me, and I think based on the tool marks and mismatched bolts, this axle has been serviced before.
Unless someone sees something wrong here, I'm happily going to put it back together and refill.
ID:	382724   Click image for larger version
ID:	382726   Click image for larger version
Magnet18 is offline   Reply With Quote
Old 11-07-2020, 01:57 PM   #862
cmadmaxman's Avatar
1991 35' Airstream 350
Columbia , Tennessee
Images: 40
Your heel and toe to drive and coast wear patterns look good. Good full contact wear in pattern.
You can use a gasket or only RTV, both work good if all surfaces are cleaned up good with acetone. I would lean to RTV with a stamped steel cover due to the irregular surface of the cover.
I have been using Mobil 1 75/90 full synthetic.
Chris & Brenda....................cMADMAXman
AIR Member 12654
1991 350LE "Zephyr"
1982 310 MoHo (Sold! New home, NYC.)
Many Years ago, 1972 Argosy 24' trailer
Our Toad, 96 Saturn SW2 (276,000 and still going )
cmadmaxman is offline   Reply With Quote
Old 11-07-2020, 02:41 PM   #863
Magnet18's Avatar
Thank you for looking! You clearly know better what you're looking at than I do.
Just installed the new valve, drop in replacement
ID:	382733   Click image for larger version
Old 11-07-2020, 02:44 PM   #864
Magnet18's Avatar
I also prefer rtv over gaskets for things like this. Just used permatex for gear-oil.
Old 11-07-2020, 03:06 PM   #865
Airstream Driver
PeterH-350LE's Avatar
1994 30' Excella
1992 35' Airstream 350
Images: 49
Hey Bubba, consider using teflon tape on the brass to brass fitting. Don't take my word for it, just come by my house and redo the top airbag fittings ( I already did, no worries)
AIR #13
PeterH-350LE is offline   Reply With Quote
Old 11-07-2020, 03:27 PM   #866
Magnet18's Avatar
Was planning to for the airbag ones. Interestingly, haldex instructions said to not use tape on the fittings, but to use oil or thread locker. Or did they just mean the brass-to-housing ones? I assumed they didn't want tape shreds getting in the valve.
Definitely using tape for the rest!
Old 11-07-2020, 03:37 PM   #867
Airstream Driver
1994 30' Excella
Images: 49
Oil and thread locker pretty much do the same as teflon tape, they act like a lubricant. Of course, thread locker also has a different purpose, but thats not what we are discussing. I found that dry brass to brass just locks up prematurely without a 100% seal. I had to redo 1 Top airbag fitting and 1 valve fitting.
AIR #13
Old 11-07-2020, 04:26 PM   #868
1986 34.5' Airstream 345
Londonderry , New Hampshire
The problem with Teflon tape is that those thin threads that you sometimes
get will float around the system and jam up valves or orifices. If properly
used Teflon tape is great.
With Teflon tape you should never apply it to the last thread of the male
thread of the fitting. Properly applied the last thread should be visible.
Tape that extends beyond the last thread will often get cut off as you
tighten the joint. This results in the threads that will cause problems.
Air345Fly is offline   Reply With Quote
Old 11-07-2020, 09:47 PM   #869
Magnet18's Avatar
Thanks both!
Got the air system back together, went straight forwardly, but time consuming.
I am a little surprised by how much play is still in the transverse rod system. About an eighth inch to the side of the bushings, they aren't exactly snug.
ID:	382759   Click image for larger version
ID:	382761   Click image for larger version
Old 11-08-2020, 03:55 PM   #870
Magnet18's Avatar
Got the drum on, torqued to 80ft lbs. And a lot of painting work today.
ID:	382816   Click image for larger version
ID:	382818   Click image for larger version
Old 11-08-2020, 03:56 PM   #871
Magnet18's Avatar
Old vs new
Old 11-08-2020, 04:23 PM   #872
Airstream Driver
1994 30' Excella
Images: 49
coming along!! Red loctide on the bolt, yes?
Btw, I replaced the drum brake shoes and I was shocked how expensive they were, compared to regular brake shoes. I bet you are getting anxious to take her for a spin.
AIR #13
Old 11-08-2020, 04:44 PM   #873
Magnet18's Avatar
Yep, even came in the kit with the bolt so it must be important
Very anxious, hasn't been for a real spin in coming up on close to a year.
After this road test, making sure everything still works and I didnt break anything, I have a pile of boxes with everything needed for an EFI install...
Old 11-09-2020, 06:25 PM   #874
Magnet18's Avatar
Hard to photograph shiny metal, but the super misselweld is working out great. Good beads, and no cracking noises as it cools.
I did end up grinding off the ones I did earlier and re-welded, i didn't trust them
ID:	382890   Click image for larger version
ID:	382892   Click image for larger version
Old 11-09-2020, 06:54 PM   #875
Magnet18's Avatar
And done
ID:	382894   Click image for larger version
Old 11-09-2020, 08:49 PM   #876
Magnet18's Avatar
Ready for install tomorrow
Airstream only had one weld bead on the stirrups, I did 3 passes per manufacturers recommendation. They turned out a little bit porous, but I'm feeling fine about them.
Old 11-09-2020, 09:15 PM   #877
cmadmaxman's Avatar
Images: 40
Great job Rob. Good welding rods make the job much easier.
Also your side to side play on your traverse rod is not an issue, really needed for the angle change on the leaf springs to air spring beam. You just need no slop from pin to pin. Hope that make sense!?
AIR Member 12654
1991 350LE "Zephyr"
Old 11-09-2020, 09:24 PM   #878
cmadmaxman's Avatar
Images: 40
On your EFI, are you going with the Holley Sniper?
AIR Member 12654
1991 350LE "Zephyr"
Old 11-10-2020, 05:50 AM   #879
Magnet18's Avatar
Thanks! And yes, perfect sense
I thought long and hard about the sniper, and after loads of research steered away mostly for reliability concerns. I went with the terminator x.
The sniper just had way too many reports of spontaneous ECU failure. It makes sense, you're taking the electronics which are sensitive to heat and vibration, and putting them in the hottest and most heavily vibrating part of the engine bay. When you have an issue you're dead in the water.
The remote mounted ECUs on the rest of their lineup have been around for a long time and have a much better track record for reliability.
The terminator system also leaves an upgrade path to controlling a 4l80e in the future if I ever go that route. I would need to upgrade the ECU but the rest of the system would remain the same. The sniper is incompatible with the 4l80e
Old 11-10-2020, 08:19 PM   #880
Magnet18's Avatar
Drivers side back together, and without even throwing my back out.
I've literally noticed an increase in my deadlift strength just from moving these damn things around
Radiator Hoses for 1983 310 Billy B General Motorhome Topics 7 06-06-2016 05:59 PM
1983 310 Engine Problem Rik Mechanics Corner - Engines, Transmission & More... 7 10-28-2005 09:30 PM
1983 310 guages Bfrank General Motorhome Topics 6 07-23-2002 05:01 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
