01-19-2021, 04:15 PM
#1121
Churubusco
, Indiana
I'll be curious to see how your cerakote turns out.
Do they make a satin version? I wonder if that would look good.
1983 Airstream 310 Class A Motorhome
-Rob
01-19-2021, 05:03 PM
#1122
1972 25' Tradewind
1976 31' Excella 500
1974 31' Excella 500
1975 24' Argosy 24
Denver
How cool would this one be?!
https://www.cerakote.com/shop/cerako...326/polar-blue
And I love that their white is called "stormtrooper white."
25' 1972 Airstream Trade Wind Land Yacht (heavily customized)
2006 Jeep Liberty CRD (diesel)
BeahmStream.com
01-19-2021, 09:35 PM
#1123
Churubusco
, Indiana
Originally Posted by kidjedi
I could see that being a really cool way to mimic the stock factory color patterns they put on some of the later models!
01-19-2021, 09:36 PM
#1124
Churubusco
, Indiana
New rear calipers and pads, new chunk of hardline verified leak free, I think the brakes are ready to make the trip.
Sorry... I didn't take the time to paint these ones red...
01-19-2021, 10:22 PM
#1125
Foothill Ranch
Yes, they make satin.
I think that blue cerakote would look best on the calipers....
01-21-2021, 01:52 PM
#1126
Churubusco
, Indiana
Diff filled
Broken air suspension line fixed, now at 24 hours without sagging
Burped the coolant system, which took awhile, and noted the new thermostat keeps the system at 180.
Rear centramatics showed up, wheels all back on
Rolled it back and forth in the barn
Connected the fuel pressure sender, looks like it holds nicely at 58-59 psi
Inserted a soft aluminum shim in the weeping fuel line connection, looks like it sealed it up.
Gearing up for a test drive this evening
-Rob
01-21-2021, 03:30 PM
#1127
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim
, New York
Bring a fire extinguisher......Regards, Bob
01-21-2021, 03:42 PM
#1128
Churubusco
, Indiana
I've got 3  :
01-21-2021, 10:43 PM
#1129
Foothill Ranch
Bob is so full of positivity....
But such a realist....
01-22-2021, 04:11 PM
#1130
Airstream Driver
1994 30' Excella
1992 35' Airstream 350
Austin
a sure sign that company is coming soon. Packages arriving with someone's name
AIR #13
01-22-2021, 11:49 PM
#1131
Churubusco
, Indiana
The kind of company that clutters up your place before ever meeting you!
Looking forward to it, and thanks again for wll the help
Up till 2am the last two nights taking care of the very long list of tiny things like reconnect turn signals and zip-tie sensor wires and reinstall trim pieces. Amazing how long it all takes when added up.
The plan is to leave and go get gas at first light in the morning. If problems are identified, return home to troubleshoot if needed. If not, just keep driving!
Really looking forward to warmer weather, we've got a cold front moving in dropping it to the teens here today (yesterday) and my hands are looking like 10 miles of bad road.
01-23-2021, 11:12 AM
#1132
Churubusco
, Indiana
20mi down the road
No leaks no fires everything working well
Got a AAA card...
Onward!
-Rob
01-23-2021, 11:30 AM
#1133
Richmond
, Kentucky
Did you lock the doors when you left?
Have a safe trip!
1975 24' Argosy Motor Home
01-23-2021, 11:48 AM
#1134
Airstream Driver
1994 30' Excella
Austin
Monday, Sunny 70 high 45 low
AIR #13
01-23-2021, 12:00 PM
#1135
1971 31' Sovereign
1972 31' Sovereign
Soddy Daisy
, Tennessee
Have a safe trip
01-23-2021, 12:07 PM
#1136
Churubusco
, Indiana
Jinxed it, throttle cable stuck wide open. Not even an issue at the engine end, bad design on the pedal end, the dust sleeve over the cable was short enough that at WOT it could catch on the end of the cable sheath.
Could have happened before, probably something everybody should check!
Anyway, stopped safely, modified so it couldn't happen again minor enough, onward!
And thanks everybody, will be as safe as possible!
-Rob
01-23-2021, 12:15 PM
#1137
Churubusco
, Indiana
Peter informed me it was because I forgot to kick the tires
Should be all good now
01-23-2021, 02:27 PM
#1138
1991 35' Airstream 350
Columbia
, Tennessee
Think we are all to familiar with that position under the dash!
Be safe friend.
Chris & Brenda....................cMADMAXman
AIR Member 12654
1991 350LE "Zephyr"
1982 310 MoHo (Sold! New home, NYC.)
Many Years ago, 1972 Argosy 24' trailer
Our Toad, 96 Saturn SW2 (276,000 and still going  )
01-23-2021, 02:42 PM
#1139
Churubusco
, Indiana
Be safe friend.
Yep, got my dose of yoga in for awhile!
01-23-2021, 02:51 PM
#1140
Churubusco
, Indiana
Issue #2, stopped on the south side of Indy at a flying j for propane. Apparently they don't have the right nozzle to fill an rv (dubious), but more pressing, noticed a totally flat tire, drivers outside dual.
Thankfully everything seems fine, no obvious damage.
I think what happened is we drove through a patch of road debris, a bunch of drywall that must've flown out of someone's truck. A piece of it may have flown up between the duals and hit the 90* fitting I had on the outside dual and allowed it to leak out. As evidenced by impact marks on both the valve stem and centramatic right behind it.
Pressure was near zero but thankfully the bead wasn't broken and it's taking air just as fast as the onboard compressor can dole it out.
To add to tools kit - heavy duty bottle jack
