Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 01-29-2021, 09:42 PM   #1181
Magnet18's Avatar
Churubusco , Indiana
TPMS installed. At dawn we ride
Magnet18 is offline   Reply With Quote
Old 01-30-2021, 02:40 PM   #1182
Magnet18's Avatar
Re-torqued the U bolts before leaving town this morning. My dad used to design severe-service suspensions for IH/Navistar, apparently they re-torqued them all after 100 miles from the factory. He informed me I most certainly should get my butt down there and check the torque. Guess he's seen axles fall off on the teat track.
Sure enough, they all took about half a turn to get back to 200ft-lbs
Got about one mile down the road before the GVOD gave out. Seemed electrical since I wasn't getting any lights. Checked the fuse and poked around to verify it's getting power, after poking around and hooking it back up it worked again. So a flaky electrical connection somewhere in the rats nest. Added to the list of things to run to ground.
Since then another couple hundred miles have passed event free so far.
Pretty sure I'm living Bob's dream- i can watch the fuel needle drop while I'm driving
Old 01-31-2021, 01:14 AM   #1183
Magnet18's Avatar
600 trouble free miles today. Stopped just shy of texarkana
1983 Airstream 310 Class A Motorhome
-Rob
Old 01-31-2021, 10:52 PM   #1184
Magnet18's Avatar
1000 essentially problem free miles* this weekend bring us to Peter's! Makes for an exhausting weekend.
And just in time too, home just got about 9 inches of snow
*The alternator belt will be the death of me
Old 01-31-2021, 11:13 PM   #1185
Magnet18's Avatar
Initial impressions of the EFI system now that I have a thousand miles on it with a good pressure regulator - loving everything but the fuel mileage.
15* outside? Fires first crank like a new car
Climbing hills? Piece of cake compared to what it was, just ease on the accelerator a tad more and up you go. I never had to touch WOT once, maybe only once did I hit the 60% that triggers the ac shutoff relay.
Noise? Quieter than it was. Certainly not luxury noise deadened, but a notable improvement.
Gas mileage? Eh... Not great. Maybe about where it was, maybe half a mile per gallon worse. Haven't crunched the receipt numbers much, but high 6s or low 7s at best there.
This hasn't been tuned at all, I literally slapped the universal kit on, fired it up, said "sounds decent to me" turned self-learning on and drove 1200 miles... So I'll post update once tuning files have been reviewed by a human.
One nit, when the engine is already hot and you start it up, it will start at high idle and then lower to your idle setpoint rather unceremoniously. It's fine, but you can tell there is all the elegance of a computer trying to go directly from A to B. That's a really tiny nit thought.
-Rob
Old 02-01-2021, 07:03 AM   #1186
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
How fast does your new fuel gauge move now ??? Regards, Bob
bobmiller1 is offline   Reply With Quote
Old 02-01-2021, 09:06 AM   #1187
Originally Posted by Magnet18 View Post
...*The alternator belt will be the death of me
That tells me your alternator is working too hard.
What size is your alternator and how do you have the wiring routed? What size is the wire from the alternator to the battery? You may also need to look at where the alternator "sense" wire is located. If you're using a 1-wire alternator you might want to reconsider that approach.
What type of devices are being powered by the 12 volt system while driving?
1975 24' Argosy Motor Home
Old 02-01-2021, 10:49 AM   #1188
Magnet18's Avatar
I've got a few alternator issues to sort out. The first is that I followed Dan's suggestion and looked at the belt with a straight edge, I believe it is standing proud of the crank pulley and therefore not lined up great. He mentioned changing the bracket to line it up properly made his problems go away. I'm not sure what bracket I can use to recess the alternator further back though, perhaps a pulley change. I'll look closer and try to get pics when I have the wheel off again in a day or two
The other issue is I am losing about 1.2 volts between the alternator and the battery. I can tell because I have my new dash gauge at the alternator output, while the holley system reports battery voltage. The dash gauge points just below 14 while the holley complains about getting 12.5 at the battery
I have the better style isolator that Peter installed on the way. Could be that will reduce the alternator load and fix some issues.
I haven't checked the sense wire location, I'll do that! Based on my symptoms I'm assuming it's on the low voltage side of the isolator
Old 02-01-2021, 10:51 AM   #1189
Magnet18's Avatar
Given my tiny 40 gallon tank... If I didn't have to watch the road I think I could watch it move
Old 02-02-2021, 09:09 PM   #1190
Magnet18's Avatar
Either my alternator or the pulley needs to move 5 or 7 millimeters forward
Old 02-02-2021, 10:09 PM   #1191
1986 34.5' Airstream 345
Londonderry , New Hampshire
Put a ruler on some of the other pulleys just to make sure that your alternator is not just cocked at an angle.
Air345Fly is offline   Reply With Quote
Old 02-03-2021, 04:34 PM   #1192
Airstream Driver
PeterH-350LE's Avatar
1994 30' Excella
1992 35' Airstream 350
Images: 49
one thing leads to another. Whilst bleeding Magnets brakes the Master Cylinder blew up. Now one of the brake lines is rusted solid to the master Cylinder. But my driveway is a good place for crap like that to happen.
AIR #13
PeterH-350LE is offline   Reply With Quote
Old 02-03-2021, 05:47 PM   #1193
Magnet18's Avatar
Yep, heck of a lot better than while going down a mountain!!!
I'm enjoying the 70 degree weather so much I'm hardly even phased
Ps... Good picture of the aluminum Tetris
Old 02-04-2021, 09:25 AM   #1194
Gee, I just might have to drive my Argosy down to Peter's place.....it needs an interior.....
Old 02-04-2021, 11:03 AM   #1195
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
Wait for me!!!!!!
martin300662 is offline   Reply With Quote
Old 02-04-2021, 11:06 AM   #1196
Originally Posted by martin300662 View Post
Wait for me!!!!!!
First come first served.....
Old 02-04-2021, 11:09 AM   #1197
Keen amature
1975 20' Argosy 20
Chestfield , Kent
I thought we were going to follow Peter home after the rally ?
Old 02-04-2021, 11:35 AM   #1198
Magnet18's Avatar
Master cylinder sure looks like a drop in replacement, napa for P30 with 4 wheel disc brakes. Should be the same one boom sounds and others have installed.
The micrometer says the distance from the mounting surface up and back down to the piston is maybe 0.008-0.010" different.
Unless anybody comes screaming in saying that's horrible, I'm thinking we're too far down in the weeds and I'll go ahead and install it. If this was a common mistake for p30 motorhome owners I'd think I could find something online, but since the internet is silent it's probably ok.
Old 02-04-2021, 02:53 PM   #1199
Magnet18's Avatar
Got more serious about my metrology. Looks a lot better than I initially thought, averaged within the measurement error of the caliper
Old 02-04-2021, 02:53 PM   #1200
Wait for me!!!!!!
Pedal to the metal, if you can keep up
That doesn't sound like enough to make a difference. If the decimal point was one to the right then I might look deeper.
Just my $0.02
Radiator Hoses for 1983 310 Billy B General Motorhome Topics 7 06-06-2016 06:59 PM
1983 310 Engine Problem Rik Mechanics Corner - Engines, Transmission & More... 7 10-28-2005 10:30 PM
1983 310 guages Bfrank General Motorhome Topics 6 07-23-2002 06:01 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
