Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 02-04-2021, 03:54 PM   #1201
Magnet18's Avatar
Churubusco , Indiana
Originally Posted by bkahler View Post
That doesn't sound like enough to make a difference. If the decimal point was one to the right then I might look deeper.
Just my $0.02
I thought so too Brad, assuming the tolerance on the drawing was Ī.005, given the surface finish that seems reasonable.
Had a good chat with Chris (cmadmaxman). On his 310 after replacing the master cylinder he had the brakes lock up, the solution was to install a .015 shim between the cylinder and booster... So apparently 10-20 thousands can make a difference
I like his .015 thou shim solution and while I think I'm probably fine to go as is, I'll be making one up in case of roadside repairs. Fortunately it can be dropped in without removing the MC
Magnet18 is offline   Reply With Quote
Old 02-04-2021, 05:47 PM   #1202
Interesting. You must have just been borderline clearing the port passages. Have to keep that in mind!
1975 24' Argosy Motor Home
Old 02-04-2021, 06:34 PM   #1203
Kvsterling's Avatar
West Chester , Ohio
I installed the NAPA master cylinder about 1.5 yrs ago. It was a drop in replacement from what I could tell, worked perfectly. Bench bleeding was essential! It was an improvement from previous one, although I donít know that these classics are known for brake pedal feel
Kvsterling is offline   Reply With Quote
Old 02-04-2021, 06:51 PM   #1204
Airstream Driver
PeterH-350LE's Avatar
1994 30' Excella
1992 35' Airstream 350
Images: 49
I drove over 200 miles with the 87 345 before the brakes locked up, all 4 right in my driveway, real close to where Magnet is parked right now I did fix it with a shim, was a much better solution than the previous owners idea of opening one of the rear bleeder valves....nope, not joking.
AIR #13
PeterH-350LE is offline   Reply With Quote
Old 02-04-2021, 06:57 PM   #1205
Airstream Driver
1994 30' Excella
Images: 49
First come first served.....
We do have Master cylinders, worn out rotors, spun bearings and snapped off brake lines and even saw dust for your transmissions. Come on down
AIR #13
Old 02-04-2021, 08:09 PM   #1206
Magnet18's Avatar
Originally Posted by PeterH-350LE View Post
spun bearings...
Yea... Guess we find out tomorrow if I need to order one more of those
Old 02-05-2021, 11:14 AM   #1207
Magnet18's Avatar
Turns out the brake lines from the master cylinder to the distribution block are custom, different fittings on each end, yay!
1983 Airstream 310 Class A Motorhome
-Rob
Old 02-06-2021, 07:10 AM   #1208
Airstream Driver
1994 30' Excella
Images: 49
Whilst I was out working hard, amazingly enough, my buddy Joe and Magnet located a shop in deep South Austin with the capacity to make that a replacement brake line with the two different fittings. Here is their description:
1/4 OD Ezibend Tube-custom Bent with Double Flared ends and 1/2"x20, 7/16"x24 Tube nuts
I already can hear Dan saying, oh those, I make them all day long....
AIR #13
Old 02-06-2021, 08:05 AM   #1209
Magnet18's Avatar
Making it was our backup option, we had a shop with a 45 double flare tool sitting and waiting behind the counter, but this shop custom made and bent it for under $40, so I told them to shut up and just take my money!
Then got the last of the brake job done and theoretically should just need to bleed the brakes today .. knock on wood.
New front bearings, Rear bearings didn't look perfect but also didn't look bad, didn't fail any criteria in the service manual as all marks could come out with light polishing, so back in they went
Also checked the alt pulley again with the straight edge on the crank. Looks fine so I guess the alternator tilt is due to the belt tension. Assuming the brakes get working again soon I'll be chasing down the electrons
ID:	388184   Click image for larger version
Old 02-06-2021, 10:59 AM   #1210
1986 34.5' Airstream 345
Londonderry , New Hampshire
That alternator tilt is still not good. It stresses the belt more than
it should. I suspect that the mounting bracket is bent. Belt
tension should not change the alignment of the pulleys. If you
loosen the belt do you still get the same misalignment?
Air345Fly is online now   Reply With Quote
Old 02-06-2021, 11:26 AM   #1211
Magnet18's Avatar
I agree, and I'll be checking that.
Not on the picture you can see the belt sticks a up little above the pulley, whereas on the crank pulley it is flush. I wonder if that's the root of the problem.
Old 02-06-2021, 11:47 AM   #1212
Magnet18's Avatar
Think I found the problem with the master, the rear valve had, when the pedal was pushed all the way in, sucked down into it's hole and gotten stuck. To un-stick it we had to push the piston in all the way then pry it out. Why that was able to happen I'm not sure.
-Rob
Old 02-06-2021, 12:02 PM   #1213
cmadmaxman's Avatar
1982 31' Airstream 310
Columbia , Tennessee
Could be, have not tore one down to see how they work!
Chris & Brenda....................cMADMAXman
AIR Member 12654
1991 350LE "Zephyr"
1982 310 MoHo
Many Years ago, 1972 Argosy 24' trailer
Our Toad, 96 Saturn SW2 (274,000 and still going )
cmadmaxman is offline   Reply With Quote
Old 02-06-2021, 12:18 PM   #1214
Airstream Driver
1994 30' Excella
Images: 49
Party time
AIR #13
Old 02-06-2021, 12:41 PM   #1215
Magnet18's Avatar
Party time
When airstream motorhome owners get together
Old 02-06-2021, 01:05 PM   #1216
cmadmaxman's Avatar
AIR Member 12654
1991 350LE "Zephyr"
1982 310 MoHo
Old 02-06-2021, 01:50 PM   #1217
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
Well I don't really make them "all day long" but I have made them. The biggest problem is finding the fittings. I think the last one I did I had to buy two different over the counter brake lines and cut the fittings off and swap around to build what I needed.
If you have a lathe and can single point cut a thread you can make a fitting, not really that big a deal.
Now you guys get an idea how I feel after reading marcvl's post about setting up network connectivity. Steve put it well when he said "Well Done!
I have no idea what it all means but it sound good to me!"
Cheers, Dan
~ Margaret Thatcher ~
Old 02-06-2021, 02:09 PM   #1218
Classic moho social distancing.
Cheers, Dan
Old 02-06-2021, 02:18 PM   #1219
It's pretty amazing how simple a master cylinder is and how little they have changed in the last 90 years. That being said when one of those little valves acts up, things go to hell in a hurry.
Cheers, Dan
Old 02-06-2021, 08:25 PM   #1220
Magnet18's Avatar
Don't have a lathe... But I *have* watched every single "this old tony" youtube video, so I'll give it a go... As long as it's for someone else's brakes
Happy to say both motorhomes now run fine, Peter's fired right up with his new fuel pump, mine seems to be stopping better than ever. With new rotors, pads, hoses, and master cylinder (and rear calipers, and front bearings). Big thanks to his buddy for helping me out all week!
Radiator Hoses for 1983 310 Billy B General Motorhome Topics 7 06-06-2016 06:59 PM
1983 310 Engine Problem Rik Mechanics Corner - Engines, Transmission & More... 7 10-28-2005 10:30 PM
1983 310 guages Bfrank General Motorhome Topics 6 07-23-2002 06:01 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
