01-11-2021, 04:55 PM
#1081
Churubusco
, Indiana
Something going on tonight so I couldn't get properly dirty after work. Wrapped up the last dashboard project for now. Changed all the switches to these and added 4 more, plus leveler warning and brake warning.
I intend to have the LEDs in the stalks come on with the headlights and the rest of the dash lights, but that's a project for later as I'll need to add a pwm circuit to dim them. They're wayyyyy too bright to have on at night.
01-11-2021, 07:01 PM
#1082
Foothill Ranch
Me Likey!
01-11-2021, 11:48 PM
#1083
Churubusco
, Indiana
Other than the horn I mentioned in the other thread, hooking up the stalks, labels, and whenever I get around to wiring in docking lights... It's done. No more need to go back there. I'm pretty stinking pleased with how it turned out.
Still need to re-do with real wood someday, but for now I think this is a massive improvement. Assuming it all works.
01-12-2021, 03:47 PM
#1084
Churubusco
, Indiana
Stainless line showed up to replace the cheap steel brakes line I put on over the weekend
Mounted the steer tires, I like them a lot, side by side pic
01-12-2021, 04:05 PM
#1085
1982 28' Airstream 280
Redwood City
Rob, what is your thoughts on the brightness of the lights you installed in the dash? Too bright? Just right? Not bright enough?
The dash looks great!
"A nation that isn't broken but simply unfinished" -
Amanda Gorman
01-12-2021, 06:34 PM
#1086
Churubusco
, Indiana
The indicators seem about right, if they end up being too bright for night driving I'll certainly be posting about it
Thanks!
1983 Airstream 310 Class A Motorhome
-Rob
01-12-2021, 07:09 PM
#1087
Churubusco
, Indiana
Tube bending coming along well. Thanks Peter for the zip tie tip.
5/16 return is almost done. The flares on the factory cut ends were fine, but wherever I had cut the line myself they felt kinda rough to the touch. Even my 20/20 eyes aren't good enough to make out detail that small, so I broke out the macro lens, really glad I did. Looked like garbage.
Some research and I've learned you can't cut with a tubing cutter or the stainless work hardens. Makes sense. Saw a recommendation to cut with a 32tpi hacksaw - looks infinitely better after doing that.
Nothing like learning the hard way
01-12-2021, 08:45 PM
#1088
1972 25' Tradewind
1976 31' Excella 500
1974 31' Excella 500
1975 24' Argosy 24
Denver
I really do think you should stop referring to it as a "dash." It's obviously a cockpit (and very cool). Maybe you should replace the steering wheel and gas pedal with a yoke & throttle?
25' 1972 Airstream Trade Wind Land Yacht (heavily customized)
2006 Jeep Liberty CRD (diesel)
BeahmStream.com
01-12-2021, 08:46 PM
#1089
1972 25' Tradewind
1975 24' Argosy 24
Denver
That is some really good information. Thanks for posting.
BeahmStream.com
01-12-2021, 09:19 PM
#1090
Churubusco
, Indiana
Thank you!
01-13-2021, 06:43 PM
#1091
Churubusco
, Indiana
So the original blue ox patriot is compatible with the honda fit but the patriot II and patriot 3 interfere with the floorplan design. Lots of angry people online.
I very carefully found a small site selling the original patriot, figured they had NOS on a shelf, selling for less than $1k.
I was very surprised when a patriot 3 showed up today. On the one hand they got my order wrong. On the other hand, I got the newest model for more than $500 off.
The patriot 3 is their answer to people complaining of destroyed brakes. It supposedly continually monitors and makes sure it isn't riding the brakes.
I figured what the heck and unboxed it. A couple minutes with a jigsaw, piece of cake.
01-13-2021, 10:56 PM
#1092
Churubusco
, Indiana
Alright, one fitting short, shows up tomorrow, but the fuel lines are done.
Connections to the tank are about 1' of hose, then 3/8 hardlines to the fuel filter just in front of the rear wheel, a small bit of hose on each side (easily upgraded later) then one hardline allllll the way to the regulator mounted on the frame by the engine.
5/16 hardline to a union under the door, then back to the tank.
Hose from the regulator to the throttle body rail
Not show car quality but good enough to be functional I think
01-13-2021, 11:47 PM
#1093
Churubusco
, Indiana
Tank done
01-14-2021, 08:01 AM
#1094
Richmond
, Kentucky
When I built my new Argosy tank I ran hard pipe to all fittings on top of the tank. I didn't want to have to deal with dropping the tank for a rubber hose issue.
01-14-2021, 08:31 AM
#1095
Churubusco
, Indiana
Thanks brad. That's certainly a better way to do it, the less rubber the better, and I'd like to make that upgrade down the road.
In the meantime, 1 I didn't have the fittings for it, and 2 my tubing bender gave up the ghost, so in the interest of starting this engine sometime in 2021 I made do
01-14-2021, 12:33 PM
#1096
Richmond
, Kentucky
I used to have one of those one size fits all benders but about the time I started doing all the various lines on the Argosy I on went on ebay and started buying used industrial quality tubing benders for each size of pipe. Made a huge difference!
01-14-2021, 10:10 PM
#1097
Churubusco
, Indiana
Yep, I'll be getting me some of those next time!
Slow and steady today, resisting the urge to rush it on the important stuff. Exhaust headers back on, gaskets made and on the throttle body stack, fuel tank mostly in but realized I need to take a chunk out of the wooden cross piece to clear the old pickup hoses now that I turned it 180. And a couple hours cleaning up my messes.
So close I can taste it.
Tomorrow I need to
- Flush the fuel lines with gas
- Secure the fuel lines down
- Install exhaust
- Pray
- Spark plug wires
- Cross my fingers
- Fill the tranny
- Pray some more
- 5 more gallons of clean gas
- Knock on wood
- Turn the key
Sweating bullets over here
01-15-2021, 06:20 AM
#1098
Airstream Driver
1994 30' Excella
1992 35' Airstream 350
Austin
Tomorrow I need to
- Install exhaust
- Pray
- Spark plug wires
- Cross my fingers
- Fill the tranny
- Pray some more
- Knock on wood
- Turn the key
12. check for leaks
13. retighten all rubber clamps after a full warm up run
14. check for leaks
15. find comfort in having a well equipped pit stop half way to
AZ
AIR #13
01-15-2021, 10:38 AM
#1099
Churubusco
, Indiana
Originally Posted by peterh-350le
12. Check for leaks
13. Retighten all rubber clamps after a full warm up run
14. Check for leaks
15. Find comfort in having a well equipped pit stop half way to
az
100%
01-15-2021, 10:30 PM
#1100
Churubusco
, Indiana
Tank finally bolted in for good
Flushed 5 gallons of fuel through back into a can. Glad I did as I saw at least one stray piece of sawdust that would have otherwise ended up in an injector.
Confirmed they hydramat works, if any fuel was left in the tank it was about a quart.
Fuel system looks good. One tiny weep at the pressure regulator input I can't get to seal. Not a deal breaker, one drop every few minutes, can troubleshoot in parallel. Ordered replacement fittings and soft aluminum crush washers Everything else is dry as a bone
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
