01-23-2021, 02:56 PM
#1141
Churubusco
, Indiana
On the bright side, ride is notably improved with the rear suspension maintenance
01-23-2021, 02:59 PM
#1142
Airstream Driver
1994 30' Excella
1992 35' Airstream 350
Austin
Originally Posted by Magnet18
Issue #2, stopped on the south side of Indy at a flying j for propane. Apparently they don't have the right nozzle to fill an rv (dubious), but more pressing, noticed a totally flat tire, drivers outside dual.
Thankfully everything seems fine, no obvious damage.
I think what happened is we drove through a patch of road debris, a bunch of drywall that must've flown out of someone's truck. A piece of it may have flown up between the duals and hit the 90* fitting I had on the outside dual and allowed it to leak out. As evidenced by impact marks on both the valve stem and centramatic right behind it.
Pressure was near zero but thankfully the bead wasn't broken and it's taking air just as fast as the onboard compressor can dole it out.
To add to tools kit - heavy duty bottle jack
Lucky dog, the tire kicking helped!!
AIR #13
01-23-2021, 03:22 PM
#1143
Churubusco
, Indiana
That or I didn't kick the correct tire!
Will be sure to get all of them next time
Mechanical status -
engine performing great! Hill climbing notably improved
Mpg - 6.5 according to the fuel pump, longer average will tell the story better
Vacuum - 20@idle, 10when cruising
Oil pressure 60psi
14 volts but I know the isolator is stealing one
Engine temp staying at 180ish
Trans temp hasn't gone over 90 - trans cooler and pan doing their jobs
2650 RPM to cruise at 65mph
01-23-2021, 05:12 PM
#1144
_
, _
Send postcards along the way, I mean post pics!
May a Firefly land upon your shoulder
and bring you good luck, good fortune, and abundance.
01-23-2021, 05:47 PM
#1145
1991 35' Airstream 350
Columbia
, Tennessee
TPMS
I don't leave home with out it on all tires!
Even on our maiden trip home with the Zephyr, it caught a leaking valve stem extension!
Chris & Brenda....................cMADMAXman
AIR Member 12654
1991 350LE "Zephyr"
1982 310 MoHo (Sold! New home, NYC.)
Many Years ago, 1972 Argosy 24' trailer
Toad, 2001 Chevy Tracker 4x4
01-23-2021, 09:41 PM
#1146
Churubusco
, Indiana
Originally Posted by cmadmaxman
TPMS
Lesson learned!! I had been putting that off as an expensive nice-to-have, but I'll definitely be getting one immediately. Amazing that I didn't even feel it flat back there. Which one do you use?
Update on the rest of the day :
Stopped just short of Indy to make sure the tire still had air. All good there, up from 78 to 82 as it warmed up so not leaking.
While inspecting things, noticed a fuel leak at the pressure regulator. Tightened inlet NPT fitting - nope, confused for awhile, finally went away when I tightened the factory staked plug in the pressure port that I wasn't using, since I don't have a turbocharger.
Stopped 5 miles later to check the fuel leak - looked all gone. Finally got propane. Learned the thermostat won't work on a cheap inverter, worked fine on the puresine I intend to install. Also noticed the honda battery dead, as I had to keep the key on accessory to power the blue ox. Thought that might happen. Picked up a lithium battery pack to jump it and then to use to power the blue ox tomorrow.
Another couple hundred miles later in effingham, fuel regulator still looks dry. Filled up and parked nose downhill, and noticed a large puddle forming under the front of the airstream. Turns out I need to rethink the fuel tank vent, when steeply downhill on a full tank it is low enough for gas to pour right out. Turned around to park nose uphill. Need to re-do that pronto. Just moving the vent won't work as the hose along the way will also leak. Will also be careful to not fill the tank all the way.
01-23-2021, 09:50 PM
#1147
Churubusco
, Indiana
Other than the aforementioned minor hiccups, very happy with the big stuff. Between the centramatics and driveshaft there is a lot less vibration.
Regarding the EFI system, I was thinking the hill climbing and power felt much better, but didn't say anything. Just in case I was imagining it.
Without prompting, the wife says "wow, it really climbs hills easier and quieter". So confirmed, I'm not imagining it!
01-23-2021, 11:57 PM
#1148
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim
, New York
Ahhhh.....church parking lots........gotta love them. Regards, Bob
01-24-2021, 06:23 AM
#1149
Foothill Ranch
Awesome!
Sounds like those M&S rated Roadmasters are not too noisy then.
01-24-2021, 07:44 AM
#1150
Columbia
, Tennessee
I have the orginal pressure pro system on the 310 and now the pressure pro pulse on the zephyr. Removable sensors on the valve stems when not on the road, keeping batteries from running down on the sensors.
Might have to get a battery feed to the toad to keep battery up?
AIR Member 12654
1991 350LE "Zephyr"
01-24-2021, 10:54 AM
#1151
Churubusco
, Indiana
Awlrighty then. Spending a week in effingham.
Woke up at 6am to the sound of rain on the roof. Checked the weather, raining and 25 degrees. Not about to drive an ice storm in the dark, decided to go back to bed and get well rested.
Checked the fuel pressure regulator again before taking off, still dripping. Hunted for the leak, snugged things... Dripping even worse.
Took me awhile, eventually figured it's coming out between the two halves of the regulator body... Looks like a bad diaphragm. Research online shows I'm not the first to have this happen to a brand new regulator, so that's likely it.
Local parts stores of course came up empty. Fortunately, there was a private campground literally one block down the road. Clean and well maintained, no meth labs. Limped here and pretty much have the place to ourselves, the owner seems more than happy to have us during the off season. I think we can stay here as long as needed to fix the issue. Also an opportunity to go over everything with a fine tooth comb and check for loose bolts.
Going to get a new pressure regulator next-day delivered, preferably a beefier or better brand if I can find a drop in replacement.
Just shaking out the bugs and being flexible. I'm looking forward to kicking back here for a week and enjoying my heated floors, and might even fire the woodstove back up.
01-24-2021, 11:40 AM
#1152
Churubusco
, Indiana
On the brighter side of life, for the next week my corner office has a great view of a lake. Hard to complain.
01-25-2021, 11:08 AM
#1153
1982 31' Airstream 310
Tulsa
, Oklahoma
Hey Magnet,
If your route is thru Tulsa, I'm about 2 miles off I44 and have a driveway available. Tulsa is about 500 miles from Effingham. If it would work for an overnight stop let me know. Or if you're passing thru and need something let me know.
Dave
01-25-2021, 02:43 PM
#1154
Churubusco
, Indiana
Originally Posted by ontheroadagn
Hey Magnet,
Dave
Good to know, thanks!
Not sure yet if we'll go Oklahoma route or memphis route, or if we'll try to do it in one day. Sure appreciate the offer!
01-25-2021, 04:48 PM
#1155
Tulsa
, Oklahoma
I think you can go Memphis route with no toll roads. You can hardly get in or out or Tulsa without paying and plus you have 2 more axles behind ya.
Also keep an eye on the weather.
01-26-2021, 12:21 PM
#1156
1984 31' Airstream310
Honokaa
, Hawaii
Not bad as cubicles go....
01-26-2021, 02:24 PM
#1157
Churubusco
, Indiana
One thing is for certain... I don't think I'm ever going back to staring at the same 4 pieces of neutral grey sound dampening fabric for 9 hours every single day.
When I first started my career my goal was to eventually get a cubicle near the windows. Not actually a cube with a window, but if you stood up you could see outside. Talk about sad and pathetic.
01-26-2021, 02:33 PM
#1158
Churubusco
, Indiana
New regulator showed up. One thing summit does right is shipping. Ordered yesterday afternoon, paid $20 for shipping, parts arrived before lunch.
Slightly different mounting bracket, should be a drop in replacement otherwise, plus no more NPT fittings
01-26-2021, 07:43 PM
#1159
Churubusco
, Indiana
New regulator installed, fired right up, set it to 60, no leaks!
Need to mount it, wants to float above the frame. Thinking about possible spacer materials.
01-27-2021, 06:07 AM
#1160
Churubusco
, Indiana
1983 Airstream 310 Class A Motorhome
-Rob
