Need help with 350LE entrance door issue!
Fellow Classic Owners, Looking for someone who can point me in the right direction to fix the entrance door on The Beast, my 1992 350LE...for some reason, the catch in the door and the bolt on the frame have gotten out of alignment...the bolt is higher than the door catch...so it's extra difficult to close the door now; I have to pull hard from the inside and then turn the deadbolt to hold it shut...did take it for a short ride a couple weeks ago, but it was uneventful, so I have no idea what brought this on...it was parked on an uneven gravel pad and I thought that maybe it was uneven ground causing the frame to bend a little, so I went to work on the pad and it's fairly even now; that didn't change anything... I have noticed that on both of the hinges there is a ~1/4" gap in the top (photo attached)...don't know if that is new or was there all along... Anyway, if anyone has ideas they would be greatly appreciated...and if someone with a similar model MH could confirm that the hinge space is normal (or not) that would be most useful...
Warm regards,
Rich
Anchor Point, AK
