01-27-2021, 06:15 AM
#1161
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim
, New York
The Halon system is great for enclosed spaces, however it is not for our application, the fan and road wind would dissipate the Halon and make it ineffective for fire suppression. The foam is a much better choice. Regards, Bob
01-27-2021, 06:21 AM
#1162
Churubusco
, Indiana
Got it, so this one then
BD-SS100AF-RH 2 Liter. AFFF Foam Remote Head with 4′ cable
165F or 286 F temperature trigger
Cylinder size: Size-17” x 4.25”
Is one head enough for our engine bays? Wondering where the best place to mount the head is
1983 Airstream 310 Class A Motorhome
-Rob
01-27-2021, 07:24 AM
#1163
1982 31' Airstream 310
Henniker
, New Hampshire
1982 310 motorhome 502
Henniker New Hampshire
01-27-2021, 08:19 AM
#1164
Churubusco
, Indiana
Hadn't seen the little balls, but I had seen these
https://www.amazon.com/dp/B07KT9JZ6M...ing=UTF8&psc=1
I think i agree with bob, foam is probably the way to go for our very open engine bays, I think these are meant for small compartments. May throw one in the generator bay though.
-Rob
01-27-2021, 11:08 AM
#1165
north blenheim
, New York
Pictures of the install (for reference) from the 325LE fire suppression install are on my other thread “It’s Never Done”. I used 2 heads on the engine, 1 for the generator, and one for the refrigerator. Although the generator is an enclosed cabinet, whether driving or stationary the generator is air cooled so the fan to cool the generator creates a lot of wind. Same goes for the refrigerator, the louvers on the outside create an environment which does not work well with Halon. Regards, Bob
01-28-2021, 01:19 PM
#1166
Churubusco
, Indiana
Thanks for the info
I think, unless you have suggestions for a better way for an end user to get their hands on a system, or any other sources, I really don't see many online, I'll probably order one of the 3 liter dual head units here when I drop the airstream off for 3 weeks to have it polished
http://www.firefightproducts.com
They have a Dual head with 4 ft and 6 ft hoses, 286* trigger point, for $625
The generator is only ever used for 30 seconds at rest stops, and destined to be replaced with a lithium setup someday.
The fridge needs protection. Lots of companies make little automatic solutions but they're all powder or halon/HFC227.
A 2 liter bottle just for the fridge/genset doesn't make sense... I don't want to spend forever running more lines... Thinking it over
01-28-2021, 01:21 PM
#1167
Churubusco
, Indiana
Also, *VERY* glad I got the M&S tires on the duals.
With the centramatics, zero road noise from them as far as I can tell.
01-28-2021, 01:37 PM
#1168
north blenheim
, New York
Firefight products is where I got the goods (Florida), have them keep the stainless lines, they’re never the right length, and substitute the hoses for 2 more heads. Get the 286 heads. Don’t shortchange yourself, this luxury option is for total loss only. Do it right, should you ever need it you will not regret spending the time making up the lines. If your motor home catches fire on the highway by the time you pull over it will be to late. Imagine lifting the dig house cover off while you’re sitting next to it at 65 MPH. Regards, Bob
01-28-2021, 01:40 PM
#1169
_
, _
I see someone else likes to go "glamping" in the snow!
May a Firefly land upon your shoulder
and bring you good luck, good fortune, and abundance.
01-28-2021, 02:15 PM
#1170
Churubusco
, Indiana
Thanks for the info Bob.
I will certainly be installing something at a minimum in the engine bay. Like you said, if a fuel line bursts at 65mph spraying right on the exhaust - that's a very bad day.
I'm not opposed to running lines for the genset and fridge, might just wait until this fall when I'm back at the workshop to do it with a second bottle. Thinking about doing it outside on the ground somewhere in the southwest surrounded by cacti and fighting off fire ants... yea, maybe this fall.
01-28-2021, 03:25 PM
#1171
Churubusco
, Indiana
On a similar note, had the 310 agreed value bumped up to 50,000 on a full timers package. $50k agreed value 1k deductible, 5k contents coverage $100 deductible.
$58/mo, seemed like a good deal. I checked the fine print and got in writing that it's agreed value and for full time travel. Not sure if someone fat fingered something but I'm not complaining.
-Rob
01-28-2021, 03:27 PM
#1172
Churubusco
, Indiana
And got blackstone report back on the first oil change. Nothing alarming.
01-28-2021, 03:44 PM
#1173
1971 31' Sovereign
1972 31' Sovereign
Soddy Daisy
, Tennessee
Here are the different types of the fireballs
Class A - Dry fires (wood, paper, fabrics), Class B - Fatty Lights (Flammable Liquids, Plastics), Class C - Gas Lights (propane, butane, etc.), Class E - Lights of Electrical Origin, Class F - Lights related to cooking.
This could be expensive depending on uses. Foam works better and being a firefighter for over 46 years its quick and dependable with a lot less mess.
01-28-2021, 04:02 PM
#1174
north blenheim
, New York
I was a fire fighter in New York for 12 years.....:you forgot to mention class “D” and what it was used for .......a little trivia ???? Regards, Bob
01-28-2021, 05:56 PM
#1175
2007 22' International CCD
Corona
If memory serves, Class D is flammable metals, like magnesium and the like. Tough to put out and requires special methods and agents.
Navy had a nasty shipboard fire during the Vietnam era when a magnesium flare cooked off and the guy tossed it back into the flare locker and slammed the lid. Bad move, to put it mildly. Better move would have been to jettison it over the side or dump the locker over the side immediately. Most dangerous munition on a ship.
01-28-2021, 06:33 PM
#1176
north blenheim
, New York
Excellent......mostly painted yellow, we only had 1,very costly to recharge. It was kept on the rescue truck which was first to respond on the parkways/expressways, Ansul was the vendor, never had to use it, but was trained on it. It sprayed out a purple colored jelly that would cover the burning metal. Regards, Bob
01-28-2021, 06:53 PM
#1177
1971 31' Sovereign
1972 31' Sovereign
Soddy Daisy
, Tennessee
Forgot about that one, we liked to spray water on magnesium and watch the pretty show.
01-28-2021, 06:54 PM
#1178
Churubusco
, Indiana
One thought on those foam extinguishers, do they work in sub zero weather? Wondering if I need a heating element on it for cold weather travel.
-Rob
01-28-2021, 06:55 PM
#1179
Churubusco
, Indiana
And if you ever want a fun show, light a piece of magnesium and sandwich it between two blocks of dry ice.
01-29-2021, 02:41 PM
#1180
Churubusco
, Indiana
After too long fighting the tiny fasteners in the biting wind laying on gravel and ice... Finally got it mounted down in there. Let it come up to temp and everything looks dry, fingers crossed it stays that way this time
Checked all the fluids including brake, all look good.
Put an always-hot outlet in the honda for the blue ox, should be able to unlock the steering, pull the main fuse, and use that. The blue ox draws about as much as a phone charging, should be able to go 12 hours no problem
Tpms should arrive yet today, fingers crossed for hitting the road at sunrise tomorrow and arriving at Peter's Sunday!
-Rob
