Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Classic Motorhomes
Old 12-20-2021, 07:37 AM   #181
cmadmaxman's Avatar
1991 35' Airstream 350
Columbia , Tennessee
Images: 40
Sure thing Dave, will put you on the list.
Hey Peter, I remember that now. We need to be on the lookout for some new "Rubber Baby Buggy Bumpers"!
I call them that because a Baby Buggy is about all that can be pushed with these before there is damage to the bumpers!!!
Here is the front bumpers off while I do the upgrade and polish everything up.
Much worse than the rear bumpers!
Chris & Brenda....................cMADMAXman
AIR Member 12654
1991 350LE "Zephyr"
1982 310 MoHo (Sold! New home, NYC.)
Many Years ago, 1972 Argosy 24' trailer
Toad, 2001 Chevy Tracker 4x4
cmadmaxman is offline   Reply With Quote
Old 12-20-2021, 08:59 AM   #182
1971 31' Sovereign
1972 31' Sovereign
Soddy Daisy , Tennessee
Upper Cabinets
This is what I did to my fronts due to the cracks I had makes it look a little better and matches my interior seating. Used luan, cushion backing pad and vinyl.
cole3444 is offline   Reply With Quote
Old 12-26-2021, 05:11 PM   #183
cmadmaxman's Avatar
Images: 40
Re-core Radiator
A little winter project to ck out the radiator. No Good!
I had the lower banana center section off to do a little repair, and with a small leak of coolant, decided to take a closer look!
After getting to the radiator, found out why I was having problems keeping the temperature in check.
Looks bad from the outside, and inside of the radiator!
New Flow Kooler water pump, new hoses and belts, 6 blade fan, ACD fan clutch and all cleaned up ready to install a re-cored radiator after our local shop gets er done.
AIR Member 12654
1991 350LE "Zephyr"
Old 12-26-2021, 06:04 PM   #184
Airstream Driver
PeterH-350LE's Avatar
1994 30' Excella
1992 35' Airstream 350
Images: 49
Is it just me or have others noticed, how clean and freshly painted Chris's project always look? That guy puts me to shame, by the time I get everything lined up to install, the last thing I worry about is painting a little rusted metal. But no, not Chris.
AIR #13
PeterH-350LE is offline   Reply With Quote
Old 12-26-2021, 06:14 PM   #185
dadstoy's Avatar
_ , _
Yes, very clean!
May a Firefly land upon your shoulder
and bring you good luck, good fortune, and abundance.
dadstoy is offline   Reply With Quote
Old 12-26-2021, 06:18 PM   #186
dadstoy's Avatar
_ , _
Chris, do you have a make and part# for your 6 bladed fan?
Old 12-26-2021, 06:45 PM   #187
cmadmaxman's Avatar
Images: 40
Here you go. Peter and I have used this fan. You have to clean up the powder coat on the ID, and and a tad more to fit the fan clutch. Attachment 409820
Sent from my SM-G950U1 using Airstream Forums mobile app
AIR Member 12654
1991 350LE "Zephyr"
Old 12-26-2021, 08:31 PM   #188
cmadmaxman's Avatar
Images: 40
Hey Peter!
I like to clean it up as much as I can when I can.
Just a bad habit!?
AIR Member 12654
1991 350LE "Zephyr"
Old 12-27-2021, 06:31 AM   #189
Airstream Driver
1994 30' Excella
Images: 49
The fan replacement on my 350, cut down on fan roar tremendously. I think my old 5 blade was bent.
AIR #13
Old 12-27-2021, 10:00 AM   #190
cmadmaxman's Avatar
Images: 40
Will try this again Dean.
Derale 17120 Standard Rotation Fan
AIR Member 12654
1991 350LE "Zephyr"
Old 12-27-2021, 06:37 PM   #191
dadstoy's Avatar
_ , _
Thank You!
Old 12-29-2021, 07:31 AM   #192
cmadmaxman's Avatar
Images: 40
While I had the rear bumper off and doing all that work, I fixed the license plate plastic surround. A little MEK and a lot of patience, was able to get it looking a little bit better!
I also removed the steel nut plates in the aluminum plate and put in aluminum Rivnuts, so no more rusting. Not my best paint job, but ok. LED lights as well.
AIR Member 12654
1991 350LE "Zephyr"
Old 12-29-2021, 11:08 AM   #193
Attachment 409889
Attachment 409890
Those sure are funny looking license plates....
1975 24' Argosy Motor Home
Old 12-29-2021, 11:14 AM   #194
cmadmaxman's Avatar
Images: 40
Hey Brad, just an abundance of caution![emoji3061]
AIR Member 12654
1991 350LE "Zephyr"
Old 01-09-2022, 09:57 AM   #195
cmadmaxman's Avatar
Images: 40
Got the front bumper back on, all polished up and some repair to the banana wrap.
Now waiting on the radiator to get it all back together!
I wish the radiator was in as good shape as the old radiator hoses!
AIR Member 12654
1991 350LE "Zephyr"
Old 01-09-2022, 10:05 AM   #196
Airstream Driver
1994 30' Excella
Images: 49
Attachment 410291
Attachment 410292
Wow, aug 27 1990. That speaks volumes on how long these last. Amazing
AIR #13
Old 01-09-2022, 10:16 AM   #197
cmadmaxman's Avatar
Images: 40
That's wat I was thinking Peter when I took them off. Still very flexible, and still in very good condition. Was thinking that they had been replaced until I cleaned them up and seen the date!
New ones gonging on anyway!
AIR Member 12654
1991 350LE "Zephyr"
Old 01-21-2022, 09:34 PM   #198
cmadmaxman's Avatar
Images: 40
New Pantry
Got to thinking of the area where the accordion door is/was, that we have never used! Using this area and some of the closet, I was thinking that I could get the wife some more accessible storage.
Used a pantry slide that is 24" full extension and rated for 175 lbs. The 6 shelfs are 4 3/8" wide, the 4 lower are 30" deep and the the top 2 are 24" deep.
When you pull it out, LED lights come on for each shelf.
If you need privacy, you can just open the doors to the closets!
Also found some extra storage under the left closet, with raising the closet floor, and installing a door! Thanks Peter!
Here is our privacy if needed.
AIR Member 12654
1991 350LE "Zephyr"
Old 01-22-2022, 06:06 AM   #199
Airstream Driver
1994 30' Excella
Images: 49
Attachment 410872
Attachment 410873
Attachment 410874
Attachment 410875
I am not sure, how you were able to mount the tracks for that system, without taking the fridge out, but nice job matching the wood and stain !! you must have a pro in the family!
AIR #13
Old 01-22-2022, 06:17 AM   #200
1988 34.5' Airstream 345
Clarkston , MI
Have you got a design for that shelf unit? I might be able to do the same.
Beltran is offline   Reply With Quote
new member owner 1991 350Le wheeler134 Classic Motorhomes 6 01-31-2015 05:18 PM
1991 Airstream 350LE Classic Class A LOW MILEAGE eBay Watch Airstreams on eBay 0 06-25-2009 02:30 PM
1991 Airstream 350LE Classic Class A LOW MILEAGE eBay Watch Airstreams on eBay 0 05-20-2009 07:30 AM
Looking at a 1991 350LE dssauburn Trailer Values 24 11-19-2006 07:32 PM
