Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 11-30-2021, 08:16 AM   #141
1988 34.5' Airstream 345
Clarkston , MI
What a great group. Kind folks stopping by to get all dirty and greasy together whilst enjoying company, food, and knowledge sharing!
Beltran is offline   Reply With Quote
Old 11-30-2021, 08:19 AM   #142
Clarkston , MI
Glad to see I am not the only one out there with clear coat spots.
Old 11-30-2021, 11:11 AM   #143
cmadmaxman's Avatar
1982 31' Airstream 310
Columbia , Tennessee
Yep, pretty much comes a standard option on all these old classics
On another note, the wife found some of these and bought us one. Although it's a 345 and not a 350, close enough for us. This is 500 of 500 made Click image for larger version
ID:	408601Click image for larger version
Sent from my SM-G950U1 using Airstream Forums mobile app
Chris & Brenda....................cMADMAXman
AIR Member 12654
1991 350LE "Zephyr"
1982 310 MoHo
Many Years ago, 1972 Argosy 24' trailer
Our Toad, 96 Saturn SW2 (274,000 and still going )
cmadmaxman is online now   Reply With Quote
Old 12-01-2021, 04:46 PM   #144
Clarkston , MI
Oh man. Would love to have one.
Old 12-01-2021, 08:08 PM   #145
cmadmaxman's Avatar
We found them on Airstreams site for their Heritage items.
Looks like we got some of the last ones, they are no longer available!
AIR Member 12654
1991 350LE "Zephyr"
1982 310 MoHo
Old 12-03-2021, 08:38 AM   #146
cmadmaxman's Avatar
Did a little up date for the trans cooler. It's now under the radiator and just a skooch lower that the front air dam. Was thinking of putting a lower scoop below the dam, but looking at that big area blocking the air, decided to make air more direct to the cooler.
The fan can be turned on manually and also automatically with the temp switch going into the radiator, on at 180 deg, off at 160 deg.
AIR Member 12654
1991 350LE "Zephyr"
1982 310 MoHo
Old 12-03-2021, 08:45 AM   #147
cmadmaxman's Avatar
Here is the model of the complete cooler I used:
Derale Hyper-Cool Extreme Remote Fluid Coolers with Fan 13870
Here it is with the wiring complete.
AIR Member 12654
1991 350LE "Zephyr"
1982 310 MoHo
Old 12-03-2021, 09:41 AM   #148
1991 35' Airstream 350
Mentor , Ohio
Looking good.
dspaw is offline   Reply With Quote
Old 12-03-2021, 09:44 AM   #149
Clarkston , MI
Nice. I have the version that fits in front of the radiator. But I also do not have the AC cooler in there anymore.
Old 12-03-2021, 10:30 AM   #150
I like it!
1975 24' Argosy Motor Home
Old 12-03-2021, 04:08 PM   #151
Airstream Driver
PeterH-350LE's Avatar
1994 30' Excella
1992 35' Airstream 350
Images: 49
Attachment 408717
Attachment 408718
Attachment 408719
Attachment 408720
Nice, Chris, you always come up with great solutions! Does that mean you still run the lines through the Radiator Transcooler?
I also installed the auto temp switch to control the fan with a manual over ride. Only once have a seen the fan come on automatically, even though the temp gauge at the same location reported 200++. so much about gauges...
AIR #13
PeterH-350LE is online now   Reply With Quote
Old 12-03-2021, 06:17 PM   #152
Airstream Driver
1994 30' Excella
Images: 49
Like I always said, it really doesn't matter who you know, what matters is who knows you!!!
Look what arrived in today's mail. What a surprise, Chris, you really outdid yourself. Thank you so very much, we will cherish this gift.
ID:	408730   Click image for larger version
AIR #13
Old 12-03-2021, 06:26 PM   #153
dadstoy's Avatar
1982 28' Airstream 280
_ , _
Sweet!
dadstoy is offline   Reply With Quote
Old 12-03-2021, 07:00 PM   #154
cmadmaxman's Avatar
Your welcome Peter.
Just a thanks for the beautiful art work you sent us.
Yes I still use the radiator, then the auxiliary cooler. My temperature switch is at the line going into the radiator. Click image for larger version
AIR Member 12654
1991 350LE "Zephyr"
1982 310 MoHo
Old 12-10-2021, 06:39 PM   #155
cmadmaxman's Avatar
Got a little item for the front of the Zephyr.
It took 3 1/2 months to get it, thank you covid! Weather held up today to get it mounted and the rear neoprene isolators put on. It is a Hellwig 1 5/8" sway bar 7162.
AIR Member 12654
1991 350LE "Zephyr"
1982 310 MoHo
Old 12-11-2021, 12:42 AM   #156
Clarkston , MI
Upgrade or just a replacement?
Old 12-11-2021, 07:43 AM   #157
cmadmaxman's Avatar
This is an upgrade. The old bar is 1 1/8" with rubber isolators. The hellwig is 1 5/8" with neoprene isolators for the new front bar, and rear bar.
AIR Member 12654
1991 350LE "Zephyr"
1982 310 MoHo
Old 12-11-2021, 10:48 AM   #158
mayco's Avatar
champaign , Illinois
What will the heavier sway bar do for you? Just wondering if I should consider that on my 310.
mayco is offline   Reply With Quote
Old 12-11-2021, 03:33 PM   #159
cmadmaxman's Avatar
This should help with windy conditions and passing big trucks. Will get out with her this next week and find out more. I think it should be a big improvement.
AIR Member 12654
1991 350LE "Zephyr"
1982 310 MoHo
Old 12-11-2021, 07:06 PM   #160
mayco's Avatar
Before I started work on the front end of my 310, semi trucks passing in either direction was quite an adventure. In hindsight I probably shouldn’t have had it on the road on our first few trips. I remember trying to anticipate and time the steering correction for the passing trucks…..it was nuts. I installed new SuperSteer bell cranks, new shocks, new steering damper, upper and lower ball joints on both sides, sway bar bushings, new tires, new tie rods both sides, and got a top notch alignment from a truck shop. Passing trucks are no longer an issue but it was pretty crazy before. I’ll be interested in what you think of the improvement in stability once you get the beefier sway bars installed. I think high winds are always going to be a concern with driving these rigs on the highway. (does it ever stop blowing in Kansas?)
They are like big sails. I keep an eye on the wind speed before we take off in the mornings. When they get up in the 20mph+steady with gusts higher then that, I will stay put if need be. It’s only happened a few times, always in Kansas, either going or coming from out west.
new member owner 1991 350Le wheeler134 Classic Motorhomes 6 01-31-2015 06:18 PM
1991 Airstream 350LE Classic Class A LOW MILEAGE eBay Watch Airstreams on eBay 0 06-25-2009 03:30 PM
1991 Airstream 350LE Classic Class A LOW MILEAGE eBay Watch Airstreams on eBay 0 05-20-2009 08:30 AM
Looking at a 1991 350LE dssauburn Trailer Values 24 11-19-2006 08:32 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
