Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Classic Motorhomes
Old 06-07-2021, 06:24 PM   #1161
Airstream Driver
PeterH-350LE's Avatar
1994 30' Excella
1992 35' Airstream 350
Images: 49
Note to self or whoever may want to listen:
Disconnected the battery before unplugging the ECU/PCM (if you should find it and figure out how to remove it)
Your engine may not start if you don't follow the above warning.
AIR #13
PeterH-350LE is offline   Reply With Quote
Old 07-30-2021, 01:20 PM   #1162
Airstream Driver
1994 30' Excella
Images: 49
A little decorating to get rid of the ugly floral vinyl in the "powder room" . real wood veneer with silver inlays. Its a wallpaper,not for the faint of heart to try to tackle.
Name:	Bath veneer.jpg
ID:	400708   Click image for larger version
Name:	Bath veneer2.jpg
AIR #13
Old 07-30-2021, 01:23 PM   #1163
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
Looks fantastic Peter
martin300662 is offline   Reply With Quote
Old 07-30-2021, 01:25 PM   #1164
Wow!
Old 07-30-2021, 09:39 PM   #1165
cmadmaxman's Avatar
1991 35' Airstream 350
Columbia , Tennessee
Images: 40
Looking great Peter.
You do beautiful work.
Chris & Brenda....................cMADMAXman
AIR Member 12654
1991 350LE "Zephyr"
1982 310 MoHo (Sold! New home, NYC.)
Many Years ago, 1972 Argosy 24' trailer
Toad, 2001 Chevy Tracker 4x4
cmadmaxman is offline   Reply With Quote
Old 09-25-2021, 05:27 PM   #1166
Airstream Driver
1994 30' Excella
Images: 49
anyone please point me in a direction where I can find the oil filler tube seal at the valve cover. Mine is seeping oil badly. I hope it can be replaced without pulling the cover?
AIR #13
Old 09-25-2021, 05:53 PM   #1167
Should be the one on the right.
grommet
1975 24' Argosy Motor Home
Old 09-25-2021, 07:37 PM   #1168
Airstream Driver
1994 30' Excella
Images: 49
grommet
Thanks Brad, looks like it is and I found it right around the corner at Autozone. My old one is threaded, but was glued into place with Blue silicon. It very hard, too. Have to see in the am if the doorman will fit properly.
AIR #13
Old 10-13-2021, 08:55 PM   #1169
Airstream Driver
1994 30' Excella
Images: 49
Had to cut our hill country tour short due to bad bad weather. Looks we dodged some bullets by leaving Blanco, which among others things is known for very dangerous flash floods.
I pulled into the driveway backwards to let the nose stick out from under the RV Port to check for leaks in the cab. Just before it started raining, I decided to turn the beast around, because of chances of Hail ( Rather have damage to the rear then the front NLA Panels.)
I just was getting ready to pull out of the driveway and the engine died. Puff!
Crank sounded like no spark. Pulled the cover, stuck a screwdriver in one of the ignition wire holes and confirmed no spark. Immediately pulled the distributor cap and replaced the ignition module and bam, it started. Quickly pulled her out and turned her around and got her under cover just before massive downpours started.
Total time under 10 minutes, 5 minutes spent on finding my spare ignition module, I had stored away in a safe , easy to remember place.
This is my third AC Delco original part Ignition module D1984A. And yes, sir I put the grease on the metal surface.
AIR #13
Old 10-14-2021, 05:20 AM   #1170
Someone was watching out for you. You could have been on the freeway in the left lane passing someone at 80 mph......
Good job of troubleshooting!
Sounds like AC Delco is having quality control problems. This may be one of those cases where you want to stock just about every brand out there in the hopes of finding one or two that work.
Old 10-14-2021, 07:46 AM   #1171
Airstream Driver
1994 30' Excella
Images: 49
And you aren't joking. Coming into Austin on 290 east is a freaking race track. Truckers take it personal when you try to pass them, which put me in an awkward position in the left lane going 75 with no way out. I tried to get away from this rock throwing dump truck, but just had to slow down and piss everyone else behind me off, so I could merge back into the right lane.
AIR #13
Old 10-14-2021, 09:21 AM   #1172
Wow! Glad you got out of it safely. I've been down that road where something breaks while passing a semi. NOT fun.
Old 10-15-2021, 06:03 PM   #1173
Airstream Driver
1994 30' Excella
Images: 49
one man AC removal and installation. High tech winch
ID:	406406   Click image for larger version
AIR #13
Old 10-16-2021, 01:08 AM   #1174
Boom Sounds's Avatar
1991 25' Airstream 250
Oxford , Oxfordshire
Note to self, but spare Ignition Module D1984A!
Boom Sounds is offline   Reply With Quote
Old 10-16-2021, 05:33 AM   #1175
Mentor , Ohio
Nice work on the A/C.
dspaw is offline   Reply With Quote
Old 10-16-2021, 05:32 PM   #1176
Airstream Driver
1994 30' Excella
Images: 49
New AC is in. Love the Dometic low profile. Buy it without the heat strip and save 300, then buy the heat strip for $90.-
Also installed the drain kit.
AIR #13
Old 10-16-2021, 06:54 PM   #1177
dadstoy's Avatar
_ , _
It looks nice up there!
May a Firefly land upon your shoulder
and bring you good luck, good fortune, and abundance.
dadstoy is offline   Reply With Quote
Old 10-18-2021, 06:44 AM   #1178
I like it!
Old 10-18-2021, 08:30 AM   #1179
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
So Peter, did you have an existing drain pan from you old ac mount and did you reuse it?
mayco is offline   Reply With Quote
Old 10-18-2021, 02:41 PM   #1180
Airstream Driver
1994 30' Excella
Images: 49
No Mike, its a different system altogether. The original AC's had a brilliant drain pan design, which was part of the AC. The only drawback is that they tend to get brittle and start leaking inside the coach. I have fixed several with vulkem and try to use those old AC's as long as possible, since they cool better. (R12)
It most cases, removal of the old AC will completely destroy the original pan, due to it being seal with vulkem.
The modern replacement is two cups, which are screwed to the bottom of the AC and a hose is routed through the gasket to the inside space to connect to your existing drain line.
A new AC typically comes with a new seal already glued to the bottom of the AC, so you have to drill 9/16 holes to route the hoses. A bit tedious and half a tube of vulkem is required.
AIR #13
Need a new gear/sprocket for a Reese lector-jacket! Ribbler Towing, Tow Vehicles & Hitches 4 06-03-2013 10:45 AM
Vintage Airstream jacket eBay Watch Airstreams on eBay 0 02-09-2012 10:10 AM
Bypass TBI water jacket???? Taxman General Motorhome Topics 8 06-15-2007 03:20 PM
motorhome jacket ALANSD Airstream Motorhome Forums 4 12-09-2002 03:58 PM
