Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 04-20-2021, 03:58 PM   #1121
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
Originally Posted by bkahler View Post
Dean, all I ever came up with was a Gates 26612 bend to fit hose.
We've discussed this a few times on the forum and no one has found anything better that I'm aware of.
I have two or three original used hoses that could be used for a pattern if someone ever finds a supplier that would be willing to reproduce them.
Nearest I found was Viper Performance (https://www.viperperformance.co.uk/p...html#one%20off). They were willing to manufacture a 'prototype' for around $500 for the mandrel, and then $250 for the first hose, but could not confirm either without having a hose in hand (or a 3d drawing). Individual/small quantities were same price as the prototype but if we ordered 100 it dropped to less than $50 each. That said they really didn't want to make less than 100, so the story could have changed once they had the hose in hand!
martin300662 is offline   Reply With Quote
Old 04-20-2021, 04:08 PM   #1122
Airstream Driver
PeterH-350LE's Avatar
1994 30' Excella
1992 35' Airstream 350
Images: 49
Post a couple of picture when you get a chance. I know I replaced it on my 79 a long time ago and would be curious to see it.
AIR #13
PeterH-350LE is online now   Reply With Quote
Old 04-23-2021, 06:52 PM   #1123
Airstream Driver
1994 30' Excella
Images: 49
One free night with 30 amp and water at our Ranchette of the Deer in Austin, Texas and a bottle of wine, to the first person to correctly guess where specifically (your 350 doesn't count) this plug goes. Dean?
Chris (cdmadmaxman) is not eligible to participate in this event.
AIR #13
Old 04-23-2021, 07:02 PM   #1124
Originally Posted by PeterH-350LE View Post
One free night with 30 amp and water at our Ranchette of the Deer in Austin, Texas and a bottle of wine, to the first person to correctly guess where this plug goes. Dean?
It goes in your 350
Did I win?
1975 24' Argosy Motor Home
Old 04-23-2021, 07:07 PM   #1125
Airstream Driver
1994 30' Excella
Images: 49
It goes in your 350
Did I win?
Nope
AIR #13
Old 04-23-2021, 07:43 PM   #1126
Nope
Just because I didn't read the directions doesn't mean I'm not right
Old 04-23-2021, 08:30 PM   #1127
dznf0g's Avatar
Oswego , Illinois
The manufacturer directions are only their opinion of the correct way to accomplish the end result.
-Rich-
Old 04-23-2021, 08:35 PM   #1128
cmadmaxman's Avatar
1982 31' Airstream 310
Columbia , Tennessee
Ah rats, I wanted to play
Chris & Brenda....................cMADMAXman
AIR Member 12654
1991 350LE "Zephyr"
1982 310 MoHo
Many Years ago, 1972 Argosy 24' trailer
Our Toad, 96 Saturn SW2 (274,000 and still going )
cmadmaxman is offline   Reply With Quote
Old 04-23-2021, 08:56 PM   #1129
dadstoy's Avatar
1982 28' Airstream 280
_ , _
I'm at a loss. It's not to seal anything since it has a small breather hole in the middle.
dadstoy is offline   Reply With Quote
Old 04-23-2021, 09:20 PM   #1130
Airstream Driver
1994 30' Excella
Images: 49
yes, it does
AIR #13
Old 04-24-2021, 06:56 AM   #1131
Airstream Driver
1994 30' Excella
Images: 49
it's not a breather hole, it limits supply
AIR #13
Old 04-24-2021, 08:00 AM   #1132
Keen amature
1975 20' Argosy 20
Chestfield , Kent
Not sure where you would use it on a 350 but I have used something that looks very similar. That was an air orifice so that you can have high pressure but a low volume to move air actuators.
Old 04-24-2021, 09:30 AM   #1133
dadstoy's Avatar
_ , _
Does it limit any type of hydraulic fluid?
Old 04-24-2021, 09:52 AM   #1134
Airstream Driver
1994 30' Excella
Images: 49
some may call it hydraulic fluid, but theoretically you could find it in 70's Argosy as well as in 90's 350, 300, 250 or in any of the 80's 345,325,310, 300, 290, 280, 270and 240's I don't think Bob has it in his 370
AIR #13
Old 04-24-2021, 03:13 PM   #1135
Airstream Driver
1994 30' Excella
Images: 49
Oh well, the bottle of wine I had in mind was this
Legendary 1945 Chateau Mouton Rothschild Bordeaux wine, Pauillac #2
currently for sale on Ebay for $20,000.00
Back to the plug. The official name is:
REAR CASE LUBE ORIFICE FOR 2WD 4L80E / 4L85E TRANSMISSIONS. (second pictures installed on the right)
When I removed the US Gear over/under drive from behind my 4l80e, i found this plug in the rear of the case and didn't have a clue what it did or did not. The new rear trans housing has a channel leading up to it (see 3rd pic tube on bottom), which is feeding the 2 rear shaft bearings. I talked to a lot of people about it and some said leave it in place, other said pull it out.
Finally when I picked up my custom 4l80e at Hughes Performance in Phoenix, I saw it had the plug in place. Everyone there told me it had to be there for my style of housing, being a 2WD. Removing it would flood the bearings and cause leaking. Only for 4WD it needs to be removed.
ID:	394017   Click image for larger version
AIR #13
Old 04-24-2021, 03:27 PM   #1136
dadstoy's Avatar
_ , _
I think that bottle is a bit above my pay grade.
Old 04-24-2021, 03:36 PM   #1137
I bet you would enjoy it though :]
Old 04-24-2021, 08:05 PM   #1138
Airstream Driver
1994 30' Excella
Images: 49
Finished the Radiator/water pump/fan blade/ clutch install. All tight. running at 195 at ambient 80 degrees. Just slightly annoyed, the new ACdelco fan clutch does not disengage. Roars like a train. Took it on the freeway at 75, never disengaged. Turned engine off in the driveway, let it sit for 10 minutes, still no go. any clues ? bad clutch?
AIR #13
Old 04-24-2021, 09:30 PM   #1139
dadstoy's Avatar
_ , _
I installed 3 of them before I solved that problem. First one was from Autozone. It never shut off. Second one was from Napa. It ran a few minutes, shut off for a few minutes, ran for a few, etc. It continued this pattern forever. Third one I went to my favorite independent parts house and got an AC Delco, which solved the issue. I'm guessing you got a bad one or one that operates at the wrong temps for the 454 MH.Every time I buy cheap junk parts, I get taught the same old lesson. Changing the fan clutch three times WAS NOT FUN!
Old 04-24-2021, 09:33 PM   #1140
dadstoy's Avatar
_ , _
The one I got was AC Delco 88961767
Need a new gear/sprocket for a Reese lector-jacket! Ribbler Towing, Tow Vehicles & Hitches 4 06-03-2013 11:45 AM
Vintage Airstream jacket eBay Watch Airstreams on eBay 0 02-09-2012 11:10 AM
Bypass TBI water jacket???? Taxman General Motorhome Topics 8 06-15-2007 04:20 PM
motorhome jacket ALANSD Airstream Motorhome Forums 4 12-09-2002 04:58 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
