RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 01-23-2021, 06:40 PM   #1061
cmadmaxman's Avatar
1982 31' Airstream 310
Columbia , Tennessee
Looking good Peter. Did you put on the extra insulators on the compressor? Or were you able to use the old isolators from the old compressor?
Chris & Brenda
AIR Member 12654
1991 350LE "Zephyr"
1982 310 MoHo
Many Years ago, 1972 Argosy 24' trailer
Our Toad, 96 Saturn SW2 (272,000 and still going )
cmadmaxman is offline   Reply With Quote
Old 01-23-2021, 06:56 PM   #1062
Airstream Driver
PeterH-350LE's Avatar
1994 30' Excella
1992 35' Airstream 350
Images: 51
If you mean the rubber feet, yes I used the old ones after i made a mounting plate. The little rubber grommets that came with the compressor just seemed too wimpy for a Metal install. They maybe ok on a wooden floor. I can't hardly hear it when inside the coach.
You can see the mounting plate elevated in my picture.
AIR #13
PeterH-350LE is offline   Reply With Quote
Old 01-23-2021, 07:03 PM   #1063
cmadmaxman's Avatar
Got it, thanks. Hopefully I won't have to worry about replacing my compressor in the near future
Chris & Brenda
AIR Member 12654
1991 350LE "Zephyr"
1982 310 MoHo
Old 02-22-2021, 06:08 PM   #1064
Airstream Driver
1994 30' Excella
Images: 51
stuff happens... and the fix
ID:	389251   Click image for larger version
AIR #13
Old 02-22-2021, 08:32 PM   #1065
Sunnyvale , California
New aluminum sheet?
marcvl is offline   Reply With Quote
Old 02-22-2021, 08:51 PM   #1066
Airstream Driver
1994 30' Excella
Images: 51
Originally Posted by marcvl View Post
New aluminum sheet?
29"x10" overlay
AIR #13
Old 02-22-2021, 11:01 PM   #1067
Magnet18's Avatar
Churubusco , Indiana
I found a cheaper solution I'll likely use on mine
https://youtu.be/4n1s_Fh7fdQ
(Start @ timestamp 11:03)
1983 Airstream 310 Class A Motorhome
-Rob
Magnet18 is offline   Reply With Quote
Old 02-23-2021, 05:50 AM   #1068
Airstream Driver
1994 30' Excella
Images: 51
says the guy chasing Red cardinals admiring themselves in his shiny coach...
AIR #13
Old 02-28-2021, 12:07 PM   #1069
Airstream Driver
1994 30' Excella
Images: 51
To complete my cold start issue, I ordered a ACDelco reman distributor, which was very expensive. Fired up once and then no go. Appears the Ignition Control unit fails when it gets hot. Installed the one from my old distributor and all is well.
What the heck
AIR #13
Old 02-28-2021, 12:58 PM   #1070
I had a similar problem with a new cheap chinese import distributor. for my engine The mechanical parts of the distributor were just fine. The ignition module however was bad from the beginning. Any time the engine was around 2000 rpm it faltered until you got above 2200 rpm. A new quality ignition module solved the problem.
Old 02-28-2021, 01:14 PM   #1071
Airstream Driver
1994 30' Excella
Images: 51
The ACD distributor came with a used GM Igniton Module that was not even properly coated with dielectric grease. It properly tested good cold, but as soon as it gets hot it fails.
I could have started another thread "hard start from Hot"
That just pisses me off, pay good money for crap. Bought it through amazon and could return the entire distributor, but no guarantees I would get a better one.
How in the world do they keep all these cars with all the electronics on the road?
ID:	389548   Click image for larger version
AIR #13
Old 02-28-2021, 01:32 PM   #1072
All these new cars you're referring to are just disposable appliances. I doubt seriously you'll find anyone that would want to restore one 20/30 years from now.
I don't really bother working on my "modern" daily drivers, it's just not worth the hassle.
Old 02-28-2021, 06:46 PM   #1073
cmadmaxman's Avatar
Same with a summit distributor on the 310 Brad. Electronics fine, but the timing weights system trashed after about 6 years!
Sorry to hear that Peter, amazing that workmanship is not like it should be at times! That is why when the bushings were good on mine, rebuilt it myself!
After over 4000 miles, I must have got something right
Chris & Brenda
AIR Member 12654
1991 350LE "Zephyr"
1982 310 MoHo
Old 02-28-2021, 10:09 PM   #1074
Magnet18's Avatar
I build ultra high reliability electronics for a living.
Depending on price point, electronics can be built to either outlast anybody alive... Or they can be built such that the average failure age is far enough out that *most* make it at least past the warranty date.
Automotive industry, while not as bad as consumer electronics, is still more the latter.
Anywho, sorry bout the luck, frustrating. Normally OE is the way to go.
-Rob
Old 03-03-2021, 06:46 PM   #1075
Airstream Driver
1994 30' Excella
Images: 51
how about this for some custom work? Covered up all the cracks very nicely!
ID:	389813   Click image for larger version
AIR #13
Old 03-03-2021, 08:52 PM   #1076
shepherd57's Avatar
1985 32.5' Airstream 325
Lindsay , Ontario
Nice looking repair Peter. Did you warm up yet we got some extra snow you can have.
shepherd57 is offline   Reply With Quote
Old 03-04-2021, 06:10 AM   #1077
Airstream Driver
1994 30' Excella
Images: 51
Sounds good John, I take all you can load up and deliver. I even go to the parts store with you and spent all your money to help you repair all the damage the transport will do!
Any word on the border situation?
AIR #13
Old 03-04-2021, 06:51 AM   #1078
cmadmaxman's Avatar
The master does it again!
Great looking job Peter, love all the rivets.
Chris & Brenda
AIR Member 12654
1991 350LE "Zephyr"
1982 310 MoHo
Old 03-04-2021, 08:43 AM   #1079
Very nice fab work Peter.
It’s like you know what you are doing!
Old 03-04-2021, 10:04 AM   #1080
Nice job!
Need a new gear/sprocket for a Reese lector-jacket! Ribbler Towing, Tow Vehicles & Hitches 4 06-03-2013 11:45 AM
Vintage Airstream jacket eBay Watch Airstreams on eBay 0 02-09-2012 11:10 AM
Bypass TBI water jacket???? Taxman General Motorhome Topics 8 06-15-2007 04:20 PM
motorhome jacket ALANSD Airstream Motorhome Forums 4 12-09-2002 04:58 PM
