04-05-2021, 01:22 PM
#1101
Churubusco
, Indiana
Originally Posted by PeterH-350LE
Recovery is doing well, thanks for asking! I am already able to chase that red
Cardinal all over the place. Since you trained him to attack shiny aluminum his skill has vastly improved. We also lost several very large trees in the super freeze. So plenty of wood waiting for you.
Glad to see you aren't slowing down!
04-06-2021, 02:33 PM
#1102
1984 27' Airstream 270
West Chester
, Ohio
If your condenser lines are long enough, may be able to swing out to the side and support while accessing the radiator. Here is my rigging
I really did t want to require removal and recharging the AC refrigerant!
04-06-2021, 03:07 PM
#1103
Airstream Driver
1994 30' Excella
1992 35' Airstream 350
Austin
No go on the 350. Ac lines are left and right and Oil cooler lines on the bottom.
On a different note, I called a radiator place today and asked if they recore radiators. The guy answering didn't know what I was talking about, since they only sell new radiators ..
AIR #13
04-06-2021, 03:20 PM
#1104
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim
, New York
A 4 row record with 9/16” tubes runs around $900.00 in my neck of the woods. Regards, Bob
04-06-2021, 03:21 PM
#1105
north blenheim
, New York
Recore, dammmmm auto spell.
04-06-2021, 07:04 PM
#1106
Airstream Driver
1994 30' Excella
Austin
Finally got the Radiator out. Very difficult with the Power steering pump reservoir being the last thing to keep it from coming out. Only one bracket on the top of the frame needs to be unbolted, everything else can stay in place.
All 4 frame bolts on the sides have to come out, so the upper frame can be lifted enough to pull the radiator out.
I have a 20" fan, now trying to find a 20" 7 blade. Any leads welcome.
I also ordered
ACDELCO154949 Radiator Fan Clutch
ACDELCO251612 Water Pump its the one that says serpentine belt and it is the more expensive one. We shall see.
AIR #13
04-07-2021, 04:48 PM
#1107
Airstream Driver
1994 30' Excella
Austin
Radiator, Condenser and Heater core went to an old school radiator shop. Radiator will be recored, Condenser and heater core checked for leaks.
I found a Derale 20" 6 blade fan that hopefully will work. Could not find a 7 blade one, except some 70's beat up one, I didn't like. Now I am waiting for the water pump and stuff to arrive. Radiator will not be ready until next week and yes, Bob, its expensive to have it done right.
Considering all the work I have done to this 350, this turned out to be a pretty large and difficult job. I don't want to try guessing what a capable shop would charge for something like this?? 5K or more ?
Btw, Chris, the 2 Bolts holding the large power steering reservoir in place are very hard to reach with the tire in place. I drove up on ramps too have more space below, so pulling the tire was no longer an option. Like i mentioned before, the reservoir bolts need to be at least loosened, otherwise the radiator will not come out.
AIR #13
04-07-2021, 05:13 PM
#1108
1991 35' Airstream 350
Columbia
, Tennessee
Thanks for the heads up on the reservoir!
Will use the jack stands, need to take that wheel of so I can polish it anyway.
How many cores are in the OEM radiator?
Chris & Brenda....................cMADMAXman
AIR Member 12654
1991 350LE "Zephyr"
1982 310 MoHo (Sold! New home, NYC.)
Many Years ago, 1972 Argosy 24' trailer
Toad, 2001 Chevy Tracker 4x4
04-07-2021, 05:20 PM
#1109
Columbia
, Tennessee
Will this 19 1/2" dorman work you think?
AIR Member 12654
1991 350LE "Zephyr"
04-07-2021, 05:21 PM
#1110
Airstream Driver
1994 30' Excella
Austin
4, quite a bit of white on the tank sides, signs of leaks. Same for the Heater core.
AIR #13
04-07-2021, 05:23 PM
#1111
Airstream Driver
1994 30' Excella
Austin
It may, just 1/2" shorter. I already have the 20" coming, if it doesn't work I will look into that one, thanks
AIR #13
04-07-2021, 05:32 PM
#1112
Airstream Driver
1994 30' Excella
Austin
forgot to mention, the heater core just slides out of 2 side brackets after the 2 hoses are disconnected. Of course, the cover has to come of the air distribution box in the cab.
AIR #13
04-07-2021, 05:41 PM
#1113
Columbia
, Tennessee
Ok, will ck that out as well.
AIR Member 12654
1991 350LE "Zephyr"
04-10-2021, 07:27 PM
#1114
Airstream Driver
1994 30' Excella
Austin
I also ordered
A little update on my coolant system quest.
The Water pump seems to be the perfect replacement. It didn't come with a 3/4" hose connection and I had to find one
EDGE INDUSTRIAL 3/4" Hose ID to 1/2" Male NPT MNPT Straight Brass Fitting Fuel / AIR / Water / Oil / Gas / WOG
The 20" Derale 6 blade replacement arrived and it is very well built and fit (well almost, had to shave just a tiny amount for the perfect fit)
I found my leak coming from the passenger side water pump to block mount gasket. Gasket surface was very rusty I had to plane it down a good bit.
My heater core turned out to be total trash, it had so many leaks.
Now i am waiting for the recored radiator, new custom built heater core and condenser. Hopefully I will get it by the middle of the week.
AIR #13
04-13-2021, 04:33 PM
#1115
1982 31' Airstream 310
champaign
We have an ooooold radiator and brake shop here in town, old school folks. They recored my 310 radiator for $400 a couple years ago. It seemed like a great price to me. It’s been no leaks this far.
04-13-2021, 07:16 PM
#1116
Airstream Driver
1994 30' Excella
Austin
Mike, that's a real good price, mine will 800 plus several hundred for a new heater core. At least the condenser checked out ok, I just need to have the High pressure hose rebuilt.
AIR #13
04-14-2021, 08:25 AM
#1117
Richmond
, Kentucky
Peanut's re-core cost $560 (vertical radiator).
1975 24' Argosy Motor Home
04-14-2021, 08:27 AM
#1118
_
, _
Hey Brad, did you ever find a solution for the lower radiator hose for the vertical radiators?
May a Firefly land upon your shoulder
and bring you good luck, good fortune, and abundance.
04-14-2021, 08:43 AM
#1119
Richmond
, Kentucky
Dean, all I ever came up with was a Gates 26612 bend to fit hose.
We've discussed this a few times on the forum and no one has found anything better that I'm aware of.
I have two or three original used hoses that could be used for a pattern if someone ever finds a supplier that would be willing to reproduce them.
04-20-2021, 02:37 PM
#1120
Airstream Driver
1994 30' Excella
Austin
Finally got the radiator, new heater core and condenser back from the shop. 4core 5/8 tubing will hopefully help. Now i just have to remember how to put it all back together
AIR #13
