Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 12-13-2020, 04:37 PM   #1041
Airstream Driver
PeterH-350LE's Avatar
1994 30' Excella
1992 35' Airstream 350
Images: 49
Originally Posted by cmadmaxman View Post
This is what I put on the 310. Also have a 14" puller fan that comes on at 180 and off at 160, Sensor at line input at radiator. Attachment 384838
Nice Chris, except the fan on/off temp. Not sure if it would ever turn off on this 4l80e. According the Input Gauge (i have 2, one in and one out), cruising temp is around 170, grade and town closer to 200. Output temp is around 140. But thats the gauges talking, never took the thermometer to check.
AIR #13
PeterH-350LE is online now   Reply With Quote
Old 12-13-2020, 05:45 PM   #1042
cmadmaxman's Avatar
1982 31' Airstream 310
Columbia , Tennessee
With the 475 trans, it don't come on much. My temp gauge, I read on the dash, is in the pan, and once it reaches just over 200+, the fan will come on. I have a light on the dash to let me know when it comes on.
Like you said in town and the long pulls up grades, is about the only time it comes on. Cruising down the highway, it has never come on yet. There is enough air going across the cooler!
Chris & Brenda....................cMADMAXman
AIR Member 12654
1991 350LE "Zephyr"
1982 310 MoHo
Many Years ago, 1972 Argosy 24' trailer
Our Toad, 96 Saturn SW2 (274,000 and still going )
cmadmaxman is offline   Reply With Quote
Old 12-14-2020, 09:38 AM   #1043
1991 35' Airstream 350
Fishers , Indiana
Anybody have an issue with brake overheat on a350le ?im not pulling anything with it and loaded minimally.any ideas or fixes?thanks in advance
Sheri56 is offline   Reply With Quote
Old 12-14-2020, 09:54 AM   #1044
Front brakes? Rear brakes? Or both?
I don't remember for sure but I think you already replaced the rubber hoses, if not then I would suggest replacing them.
The other thing that comes to mind is the pushrod that goes between the MC and the hydroboost.
1975 24' Argosy Motor Home
Old 12-14-2020, 11:59 AM   #1045
Magnet18's Avatar
Churubusco , Indiana
Likewise to brad, more symptoms helps.
If just one front or both rear, the rubber lines are always my first suspect as Brad said. I've also had a caliper piston sieze and drag.
The caliper slide surfaces on these are also probably worth checking, they should be greased with silicone based caliper grease. I have read reports of mechanics that used anti sieze or all purpose grease instead and then the brakes lock up a couple years down the road.
Magnet18 is offline   Reply With Quote
Old 12-14-2020, 02:09 PM   #1046
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
You might want to consider removing the calipers once a year for maintenance purposes, it also gives you a chance to see everything before traveling for the season. Regards, Bob
bobmiller1 is online now   Reply With Quote
Old 12-14-2020, 03:56 PM   #1047
Airstream Driver
1994 30' Excella
Images: 49
This is what I did: I replaced the Master Cylinder, front brake pads and rubber lines and my brakes are trash and probably are overheating like yours. Now I moved to plan C ( as in Chris's list for parts)
and ordered all the good stuff, new rotors, calipers, heavy duty towing pads for all 4 wheels. Cost in Parts ~650.-
https://www.airforums.com/forums/f31...ml#post2435566
I will report back once I get it all installed.
AIR #13
Old 12-20-2020, 11:46 AM   #1048
Airstream Driver
1994 30' Excella
Images: 49
no comment (well, except does your calliper match your pinstriping, Dan?)
ID:	385203   Click image for larger version
AIR #13
Old 12-20-2020, 01:01 PM   #1049
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
Peter, us diesel guys have enough power that we don't need to worry about the little stuff like painted calipers.
Cheers, Dan
~ Margaret Thatcher ~
Old 12-20-2020, 08:13 PM   #1050
cmadmaxman's Avatar
Looking good Peter, you will have fun putting in the brake hose from the frame to the axle! You'll be thinking, why didn't I do this will I had the air bag system out of the way???
AIR Member 12654
1991 350LE "Zephyr"
1982 310 MoHo
Old 12-20-2020, 08:29 PM   #1051
Airstream Driver
1994 30' Excella
Images: 49
Ha Chris, I stopped working on the rear pending bearings arrival. Now, after what you are saying, I may never go back to it.
To be honest, I am pretty sore after a weekend of switching out disks and calipers. Heavy stuff, hard work.
AIR #13
Old 12-20-2020, 08:50 PM   #1052
cmadmaxman's Avatar
I know you can do it, just would have been easier when we had the system out of the way!
AIR Member 12654
1991 350LE "Zephyr"
1982 310 MoHo
Old 12-21-2020, 05:42 PM   #1053
Airstream Driver
1994 30' Excella
Images: 49
I am ready to pull the tank again (pulled it once when I got to 350 just to get it running). Too much rust and debris clogging up my filter in no time.
I used 30R9 fuel injection hose around the tank and I am surprised to see how soft it got in just 1 year of service. I am going to switch to 30R14T2.
Comments?
AIR #13
Old 12-21-2020, 07:20 PM   #1054
Airstream Driver
1994 30' Excella
Images: 49
Comments?
If you have a hard time finding the SAE30R14T2 it is sold as
Gates 4219BF Barricade
AIR #13
Old 12-22-2020, 07:02 PM   #1055
bobmiller1's Avatar
If you think those are heavy, I just picked up the brake parts for the 396XL.......like having 2 of my mother-in-laws in the back ! I did this job once before on a 390XL that I owned....I traded it in for the 2007 396XL.....I was younger then, the parts seemed lighter ! Regards, BobClick image for larger version
Old 12-22-2020, 07:50 PM   #1056
Airstream Driver
1994 30' Excella
Images: 49
Originally Posted by bobmiller1 View Post
If you think those are heavy, I just picked up the brake parts for the 396XL.......like having 2 of my mother-in-laws in the back ! I did this job once before on a 390XL that I owned....I traded it in for the 2007 396XL.....I was younger then, the parts seemed lighter ! Regards, BobAttachment 385350
Wimp, have another coffee or two Thats what you get for neglecting the silver bullets
AIR #13
Old 12-24-2020, 04:10 PM   #1057
Airstream Driver
1994 30' Excella
Images: 49
The little stuff
Pulled the tank again and my plan is to not have to pull it again, ever!
I already moved the fuel pump out of the tank and now the tank is getting cleaned next week.
I spent hours on finding a good way to reroute the supply line which used to go to the pickup at the sending unit/internal pump.
With the external pump being forward of the tank, I had a problem with the tank pinching the rubber line. I finally succeeded in cutting the metal line and rerouting it away from the tank mount. Sounds easy, but it wasn't. I even tried to run a new 3/8 metal fuel line from the midship secondary fuel filter, but it was too tight to push it through.
ID:	385439   Click image for larger version
AIR #13
Old 12-24-2020, 05:06 PM   #1058
Famous last words......
If I remember correctly the 345 that I dismantled had 1/2" steel fuel lines for the suction side and 3/8" for the return side. Somewhere near the front the suction changed to 3/8" and the return to 5/16".
Then again my memory isn't all that great anymore.....
Old 01-08-2021, 05:51 PM   #1059
Airstream Driver
1994 30' Excella
Images: 49
Just finished my holiday assignment:
1. Complete new brakes, rubber lines, rotors, calipers, pads. Replaced the rear wheel bearings, expensive stuff.
2. Fuel tank flush
3. All hard lines to the trans cooler (no more rubber), thermal switch controlling an additional fan (180 on /165 off) Over ride switch and signal light on the dash.
AIR #13
Old 01-23-2021, 04:05 PM   #1060
Airstream Driver
1994 30' Excella
Images: 49
Just finished installing Viair 450C. The late 1991 and 1992 are the only Classics I have seen with the air compressor compartment under the coach in an enclosed housing. Since its outside and bit harder to hear, I also ran a wire to the dash for a signal light when the compressor is running.
AIR #13
Need a new gear/sprocket for a Reese lector-jacket! Ribbler Towing, Tow Vehicles & Hitches 4 06-03-2013 11:45 AM
Vintage Airstream jacket eBay Watch Airstreams on eBay 0 02-09-2012 11:10 AM
Bypass TBI water jacket???? Taxman General Motorhome Topics 8 06-15-2007 04:20 PM
motorhome jacket ALANSD Airstream Motorhome Forums 4 12-09-2002 04:58 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
