Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Classic Motorhomes
Old 09-24-2020, 10:30 PM   #981
Magnet18's Avatar
Churubusco , Indiana
Originally Posted by bobmiller1 View Post
The 370LE, bring the largest classic motor home ever made rides on a Gillis heavy duty bus chassis with a real air bag suspension and is powered by a Ford V8 460 mated to a C6 transmission which I upgraded to a E4OD heavily modified , Regards, Bob.......I hope this clears up any confusion.
I knew it was a ford 460, so the E4OD, that makes more sense
Thanks Bob
Magnet18 is offline   Reply With Quote
Old 09-24-2020, 10:32 PM   #982
Magnet18's Avatar
Originally Posted by Waipio Rim View Post
I mistook a bad front tire for a driveline vibration for quite a while...
Thanks Wap, a good thing I'm planning on replacing those too then!
They're low mile but getting on towards the expiration date
Old 10-03-2020, 01:42 PM   #983
Airstream Driver
PeterH-350LE's Avatar
1994 30' Excella
1992 35' Airstream 350
Images: 49
Let the fun begin. And, yes, Bob, I replaced the cheapo gasket with the oem version
AIR #13
PeterH-350LE is offline   Reply With Quote
Old 10-03-2020, 02:07 PM   #984
I think you have it pointed in the wrong direction.......
1975 24' Argosy Motor Home
Old 10-03-2020, 04:03 PM   #985
Airstream Driver
1994 30' Excella
Images: 49
I have to look into that...
The matter of a good trans jacks is another thing. All $200-300 versions have lots of negative reviews of weak construction, hard to control hydraulics, stability issues and insufficient lift range. So here is my custom homemade version, very strong bolted onto a 4 ton jack that can be controlled with precision. I drove the 350 up on ramps, but still will have a tight situation getting the trans out. Looks like I even have to install the old 2 1/2 deep pan to install the new trans. The deep pan for the new trans is over 4 inches.
ID:	379999   Click image for larger version
AIR #13
Old 10-03-2020, 10:02 PM   #986
Magnet18's Avatar
Very nice, both the trans and the jack!
1983 Airstream 310 Class A Motorhome
-Rob
Old 10-09-2020, 06:20 PM   #987
Airstream Driver
1994 30' Excella
Images: 49
greetings from the underworld. Tough job!
ID:	380424   Click image for larger version
AIR #13
Old 10-09-2020, 06:33 PM   #988
Be sure and check the flex plate for cracks. Better to find them now than after you already have the new tranny in place!
Old 10-09-2020, 06:39 PM   #989
Airstream Driver
1994 30' Excella
Images: 49
Yes Sir, I remembered you telling me that. I checked it and it looks good. Talking about Flex plate, one of the bolts scared the daylight out of me, it didn't want to budge. After breaking a 15 mm craftsman 6point socket, I used 6 point impact socket with a 2' foot extension and had to lean into to hard to crack it. 12 point would have killed that nut
AIR #13
Old 10-10-2020, 05:11 AM   #990
6 point sockets are definitely the way to go. Unfortunately I mostly have 12 point. One of these days I'll have to remedy that situation!
When are you lifting the new transmission into place?
Old 10-10-2020, 06:31 AM   #991
cmadmaxman's Avatar
1991 35' Airstream 350
Columbia , Tennessee
Images: 40
You will probably have to do some clearance work on the transmission cross member to clear the bigger trans pan. Had to take about a 3/8" off mine for the mag-hytec pan. Looking at your pan, will probably be more than that.
Chris & Brenda....................cMADMAXman
AIR Member 12654
1991 350LE "Zephyr"
1982 310 MoHo (Sold! New home, NYC.)
Many Years ago, 1972 Argosy 24' trailer
Toad, 2001 Chevy Tracker 4x4
cmadmaxman is offline   Reply With Quote
Old 10-10-2020, 06:42 AM   #992
Airstream Driver
1994 30' Excella
Images: 49
will start after I finish this pot of super strong coffee.
AIR #13
Old 10-10-2020, 06:43 AM   #993
Airstream Driver
1994 30' Excella
Images: 49
trans cross member is out, so i may just do it while is easy. The old pan was just in front of the cross member, will have to take some measurements. When I installed a Derale deep pan on a TH-400, I had to modify the crossmember. Exhaust crossover is out, had to wiggle the old trans out because of exhaust pipe side clearance. Just didn't want to pull the headers. Will see today if I can get the new one in. Best thing I did was spending time on building the floor jack adapter, its super strong and extremely responsive.
AIR #13
Old 10-10-2020, 11:48 AM   #994
Airstream Driver
1994 30' Excella
Images: 49
the new trans is in, was able to slip the widest housing section over the exhaust coming from the rear. Chris you were right, I had to notch the crossmember for the new pan. checked flex plate to converter clearance and will be ready to torque the new converter bolts. A few hours of odds and ends and she will be ready to be filled .
AIR #13
Old 10-10-2020, 02:48 PM   #995
cmadmaxman's Avatar
Images: 40
Looking good, excited to see how the new trans performs.
AIR Member 12654
1991 350LE "Zephyr"
Old 10-10-2020, 06:31 PM   #996
Airstream Driver
1994 30' Excella
Images: 49
All done, filled and no leaks, shifts and not throwing any codes. Test drive in the morning. Pretty big job for an old guy with shi tty tools
AIR #13
Old 10-10-2020, 08:03 PM   #997
cmadmaxman's Avatar
Images: 40
Looking good under there. Good job young feller!
AIR Member 12654
1991 350LE "Zephyr"
Old 10-11-2020, 10:36 AM   #998
Airstream Driver
1994 30' Excella
Images: 49
Test drive went well,smooth shifting up and down. As a bonus I do have a parking Pawl now, which makes me extremely happy. I do understand the weight limitation and dangers associated with that, but more than willing to deal with it.
AIR #13
Old 10-11-2020, 12:10 PM   #999
Airstream Driver
1994 30' Excella
Images: 49
Besides being very pleased with the new trans, I do have a problem with the builder not following my precise instruction for the rear output shaft. I did sent them the picture below and told them that it was extremely important to have the same shaft measurement.
When I picked up the trans in Phoenix a few weeks ago, I did notice that the length was just a tad over 6 1/8. I wasn't please but thought with the slip joint on the driveshaft it should be ok, which it turned out to be.
The parking brake was a different issue, since that amount of set back preloaded the shoes to the point of dragging the new shoes to almost lock up and not enough play to engage the parking brake. I ended up drilling a new cable mounting hole to get the right length back.
Name:	shaft length.jpg
AIR #13
Old 10-11-2020, 02:03 PM   #1000
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
Peter I admire and congratulate your tenacity and endurance, job well done.
If I was doing a job like that and sat down to report on mid job progress, there is no way my old body would return to the job that day or maybe even for a couple of days. I may have to return some of those special rivets you gave me, if I can figure out how.
Cheers, Dan
~ Margaret Thatcher ~
Need a new gear/sprocket for a Reese lector-jacket! Ribbler Towing, Tow Vehicles & Hitches 4 06-03-2013 10:45 AM
Vintage Airstream jacket eBay Watch Airstreams on eBay 0 02-09-2012 10:10 AM
Bypass TBI water jacket???? Taxman General Motorhome Topics 8 06-15-2007 03:20 PM
motorhome jacket ALANSD Airstream Motorhome Forums 4 12-09-2002 03:58 PM
