Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 06-14-2020, 07:00 AM   #881
Originally Posted by PeterH-Airstreamer View Post
No more heat soaked starter
Custom starter.....nice!
1975 24' Argosy Motor Home
Old 06-14-2020, 12:08 PM   #882
Airstream Driver
PeterH-350LE's Avatar
1994 30' Excella
1992 35' Airstream 350
Images: 49
Completed the rebuilt of the Air suspension system
Airbags: W01-358-5412
leveling valves: Excel # EM36270 Ref# Hadley H00450CE Mack 20QE3126
bushings and pins: Superide 7572-102, 5506-001
Pressure switch: Furnas
Total parts cost $~700.-
Labor ?? I I would not do it for less than $1,500.- labor and you would have to cut the floor.
This was a difficult job, more so than i expected. Without some of the heavy duty tools I have, it would have been impossible.
ID:	370322   Click image for larger version
Name:	leveling valves.jpg
AIR #13
PeterH-350LE is offline   Reply With Quote
Old 06-14-2020, 02:23 PM   #883
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
Thanks for the part numbers, Iím sure the guys will appreciate them....as for the labor and tools......tell me about it ! Regards, Bob
bobmiller1 is online now   Reply With Quote
Old 06-14-2020, 07:11 PM   #884
cmadmaxman's Avatar
1982 31' Airstream 310
Columbia , Tennessee
Great job dude, I knew you could do it
Most of the work we do on these, others could not afford us!!
Chris & Brenda....................cMADMAXman
AIR Member 12654
1991 350LE "Zephyr"
1982 310 MoHo
Many Years ago, 1972 Argosy 24' trailer
Our Toad, 96 Saturn SW2 (274,000 and still going )
cmadmaxman is offline   Reply With Quote
Old 06-14-2020, 08:00 PM   #885
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
Yeah I hear you complaining but I bet if one of us came by with a blown bag you would be under the rig twisting wrenches getting greasy with us. And when we finished you would want to feed us dinner too.
Now that you have that done what job are you doing next?
Cheers, Dan
~ Margaret Thatcher ~
Old 06-14-2020, 08:32 PM   #886
Airstream Driver
1994 30' Excella
Images: 49
Dan, you know that's right, already had a few of those instances over the years. Brad promised he would show up down here sooner or later and you know if he makes it, we basically have to redo his entire rig
After rebuilding the AC system and actually getting it work, changing all the fluids!!,replacing the power steering pump, the Master Cylinder and now the air bag suspension, I decided to work inside the 350 with Air condition for the summer month. Oh, did I mention that I replaced 8 tires whilst I was messing with the airbags, 2 at a time.
Last thing mechanical I will do is install the "mean green" starter.
And YES, I am always willing and able to assist anyone passing through!!
AIR #13
Old 06-14-2020, 08:45 PM   #887
Airstream Driver
1994 30' Excella
Images: 49
Thanks, Chris! your excellent write-up and support was very much appreciated!
AIR #13
Old 06-14-2020, 09:27 PM   #888
I think most everybody here feels that way. But Peter, Brad tells me if his rig ever rolls out the driveway everything will be right.
Now if I ever get down your way I'll definitely stop in but working will be the last thing on my mind. However I'm always up for some good eats.
Cheers, Dan
Old 06-15-2020, 10:14 AM   #889
cmadmaxman's Avatar
Glad it helped you.
If you want to copy it to help you make one up for the tag axle rigs, please do. That would be a great help for all the tag axle units out there.
AIR Member 12654
1991 350LE "Zephyr"
1982 310 MoHo
Old 06-16-2020, 08:50 AM   #890
[QUOTE=Smartstream;2371526]I think most everybody here feels that way. But Peter, Brad tells me if his rig ever rolls out the driveway everything will be right. ;/quote]
Hmmm.....I'm not sure what you're smokin up there in the great north west but the way things look I'll be lucky if mine EVER rolls out of the driveway!
Texas barbeque comes to mind
Old 06-16-2020, 05:07 PM   #891
Airstream Driver
1994 30' Excella
Images: 49
72 hours and counting system pressure at 100psi. When I mentioned that to Brad his comment was "that means you did everything right!"
Well, with 6 ports coming in/out of the tank, 2 exterior ports, air horn, dash pressure gauge and lines running everywhere, I think I just got lucky.
I believe that my leaks were in the pressure switch and the 2 leveling valves
AIR #13
Old 06-17-2020, 06:16 AM   #892
Do I see scotch tape on that needle holding it in place?
Old 06-17-2020, 06:59 AM   #893
Airstream Driver
1994 30' Excella
Images: 49
No Brad, what you see is a needle, not scotch tape. I learned this trick when I was a teenager and we used a hot needle to poke a hole in the plastic clear cover of the pinball machine to advance the free game counter.
AIR #13
Old 06-17-2020, 12:59 PM   #894
Ultraclassic's Avatar
2000 30' Excella
GTA , Ontario
I used to just rack up free games, then run like hell to get back to class before the bell rang
#4286 Stella the 2000 30ft Excella/Classic - Tow Vehicle - 2012 Mercedes Benz GL350d - CanAmRv.ca hitch Reinforcement EZ-Lift WD with 2 Anti Sway Bars. previous tow vehicle 2005 Ford F150 Lariat 367,000Kms 5.4L
Ultraclassic is offline   Reply With Quote
Old 06-18-2020, 09:10 AM   #895
Airstream Driver
1994 30' Excella
Images: 49
With new valves and everything the way it should have been the day it rolled out of the factory, the bags are 11 1/2", with no way to adjust them any lower (no tread left for further adjustments) The tag tires barely touch the ground. I ordered 1" shorter linkage to be able to fine tune the ride heights. Without being able to weigh the tag axle, I would feel more comfortable at 10 1/2 ".
Thoughts?
AIR #13
Old 06-18-2020, 11:50 AM   #896
Peter if you loosen the nut on the leveling valve arm, there is more adjustment. The hole the bolt go goes through is actually a slot that allows quite a bit of adjustment. If that isn't enough, most guys bend the rod.
Cheers, Dan
Old 06-18-2020, 08:46 PM   #897
Airstream Driver
1994 30' Excella
Images: 49
its adjusted to the max, nothing else can be adjusted to lower the bags. I ordered new 1" shorter rods that come with new rubber in the eye hole
AIR #13
Old 06-20-2020, 07:16 PM   #898
Airstream Driver
1994 30' Excella
Images: 49
Did I mention that I hate those Furnas pressure switches? Only one i could find as a drop in replacement was a 125/95 and I have been having hell to get down to 95/80. I think its not possible to get that range. Best I can get is 100/75 and 100 is seems to be a magic number for compressors to start complaining. I thought I had it set, but after a big road trip today, it didn't want to shut off at 100.
Good report on rpm. Was running a tad over 2000 rpm at 65 with temp at 200
AIR #13
Old 06-26-2020, 03:55 PM   #899
Airstream Driver
1994 30' Excella
Images: 49
One more item for the parts list:
Leveling valve linkage. They are measured center eye hole to center eye hole. Mine was 7" and I had no more options to reduce the heights, which was at 11 1/2 ". The new 6" gave me just the perfect adjustment options. I am now sitting at 10 1/2 " and have options to go either way if needed.
https://www.heightcontrolvalve.com/f...linkage-25.htm
AIR #13
Old 06-29-2020, 09:57 AM   #900
Airstream Driver
1994 30' Excella
Images: 49
Finally got around to pulling the lower rub rail to permanently seal the problem spots. And did I find some bad stuff! The drainage of the drivers side awning happen to dump right on this area and it soaked and destroyed the floor on that side. What were they (not) thinking???
ID:	371493   Click image for larger version
AIR #13
Need a new gear/sprocket for a Reese lector-jacket! Ribbler Towing, Tow Vehicles & Hitches 4 06-03-2013 11:45 AM
Vintage Airstream jacket eBay Watch Airstreams on eBay 0 02-09-2012 11:10 AM
Bypass TBI water jacket???? Taxman General Motorhome Topics 8 06-15-2007 04:20 PM
motorhome jacket ALANSD Airstream Motorhome Forums 4 12-09-2002 04:58 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
