06-05-2020, 11:36 AM
#861
Airstream Driver
1994 30' Excella
1992 35' Airstream 350
Austin
Originally Posted by bkahler
Peter,
It might be worth contacting the guy that runs the Acme Air Parts website. Back when I was rebuilding the evaporator box on my Argosy I contacted him about vacuum actuators and he had them available. I "think" his name is Richard but I could be wrong.
Thanks, Brad. I sent them an email, lets hope I hear back from them.
AIR #13
06-05-2020, 11:38 AM
#862
Airstream Driver
1994 30' Excella
Austin
Originally Posted by propstrike
... It. Never. Ends. Is this like the old Japanese guy, continually working on his house and garden? The day he finishes them is the day he crosses over? ......
That certainly enforces my preference to enjoy the road and not the destination.
AIR #13
06-05-2020, 03:55 PM
#863
Airstream Driver
1994 30' Excella
Austin
Peter,
Brad, you were right, i need to use a Trinary switch to control the fan. I talked to Richard of Acme and he was great. This is what he told me:
1. Use trinary switch to control the fan (it has 4 wires, 2 for the hi/low and 2 for the fan)
2. The switch does not control the cycling , it just shuts off the clutch at low and high pressure
3. The cyling is controlled by the thermo switch at the evaporator
4. The compressor may not cycle for a long time
5. Best to use relays for both the clutch and the fan and just use the PCM for the signal
this is switch he told me to order , its part number 410-3025
http://acmeairparts.com/rvacheaterpa...egory=16022557
Now I am confused how to wire the fan wires from the switch. As is the fan just has + and - coming from the PCM I assume. How do I figure out where to send the fan signal to ?
AIR #13
06-05-2020, 04:14 PM
#864
Richmond
, Kentucky
I knew the thermo switch would cycle the compressor but I had thought the high pressure switch that is part of the Binary switch would come into play depending on how hard the system is working.
That doesn't surprise me!
That is 100% correct. The important thing is you have to be able to identify the wire coming from the PCM. That wire will provide the ground (sink) connection for the fan relay.
The switch in the link mentions 1/4" port. It will be interesting to see if it matches your 3/8-24 thread requirements. If not I think I know where to source a Trinary switch with 3/8-24 threads.
I'll create a diagram for you. Probably won't have it done until later this weekend though. I'll make sure you can still use your manual switch as well.
This diagram will give you an idea of what you'll be doing, it's how I wired my Argosy dash heat/ac system.
1975 24' Argosy Motor Home
06-05-2020, 06:22 PM
#865
Airstream Driver
1994 30' Excella
Austin
The switch in the link mentions 1/4" port. It will be interesting to see if it matches your 3/8-24 thread requirements. If not I think I know where to source a Trinary switch with 3/8-24 threads...
I wrote Richard about the 1/4 port, this is what he replied:
It's 3/24 thread, but called 1/4 inch port
Hahaha, no wonder this stuff confuses the crap out of me.
AIR #13
06-07-2020, 10:10 AM
#866
Airstream Driver
1994 30' Excella
Austin
50 ways to leave your lover...
or 20 ways that Classic would have let me down, would I have followed up with my plan to fly to FL to drive the 350 home.
Interestingly, the 2 items I already had dropped shipped to FL (starter and alt) were ok.
Most of these items would have gotten me stranded and probably at different times.
1. Intermittent replacement fuel pump wire (just wrapped around the terminal of the radiator fan switch)
2. Added Fuel Pump wire was fed into the engine compartment to the back of the coach, laying on top of the muffler
3. Fuel tank gauge not working.
4. Badly leaking power steering pump reservoir hose and power steering pump
5. Airbag compressor ran continuously and only got the bags up to 60 pounds (leak at fitting of compressor)
6. Signal lights not working
7. headlights badly adjusted
8. Windshield wiper blades torn
9. Tires had severe sidewall cracking
10 . wiring harness rubbing on A/C pulley
11. 2 Gauge battery wire almost rubbed through insulation by motor
12. Transmission fluid external cooler leaking
13. Metal transmission almost rusted completely through
14. Rear Airbags have bad cracking
15. Some rubber fuel line hoses needed dire replacing
16. Fuel tank vent hose badly connected, would leak fuel when filling
17. Fuel tank strap bolt cross threaded at the beginning of the thread
18 . Generator not working, someone disconnected fuel line at the tank and used fitting for vent hose.
19. Radiator coolant reservoir broken into pieces
20. Badly worn front right brake pads
AIR #13
06-07-2020, 10:25 AM
#867
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim
, New York
That’s all ??? Regards, Bob
06-07-2020, 05:53 PM
#868
Airstream Driver
1994 30' Excella
Austin
When I replaced the Airbags on my 1987 345 years ago, I declared it to be almost impossible. Well, Airstream improved on the 350LE and ran a lot of other lines right on top of the bags, making it completely impossible to remove the bags without cutting a hole in the floor. Look at this mess.
AIR #13
06-07-2020, 06:41 PM
#869
1982 28' Airstream 280
Port Angeles
Come on Peter, if it was easy anybody could do it.
Cheers, Dan
~ Margaret Thatcher ~
06-07-2020, 07:46 PM
#870
Airstream Driver
1994 30' Excella
Austin
Look, Dan, what happens when anybody can do it, like buying these sh it tires in 2013. These kind of tires are the ones that tear your rig apart. One of tires was a Goodyear G647 from 2010. It was in such good condition that the shop mounted it for my spare. I went with the Goodyear 8R19.5 G647
AIR #13
06-07-2020, 10:36 PM
#871
Port Angeles
I agree, I replaced the Goodyears on my 280 when they were 10 years old and not a crack in any of them. Had about 60,000 miles on them and plenty of thread left. Now get back to work and change out those bags.
Cheers, Dan
06-09-2020, 02:29 PM
#872
Airstream Driver
1994 30' Excella
Austin
that was tough, should have just left them in, they look pretty good
More info on how to on the Superide Model 8050 (early 90's I think) over on cmadmaxman's suspension thread:
https://www.airforums.com/forums/f15...ml#post2368972
AIR #13
06-09-2020, 02:56 PM
#873
1991 35' Airstream 350
Columbia
, Tennessee
Glad you got them out! Did you have to jack up the frame like we talked about?
Yours look like mine did
Good job Peter, knew you could do it!
Your a great member in the "Airstream Busted Knuckle Garage"
Chris & Brenda....................cMADMAXman
AIR Member 12654
1991 350LE "Zephyr"
1982 310 MoHo (Sold! New home, NYC.)
Many Years ago, 1972 Argosy 24' trailer
Toad, 2001 Chevy Tracker 4x4
06-10-2020, 09:12 AM
#874
Richmond
, Kentucky
A little Trempro 635 and you'd have been good to go with the original bags.......
06-10-2020, 11:40 AM
#875
Airstream Driver
1994 30' Excella
Austin
Great minds think alike!!
I was thinking Black Vulkem and some saw dust for the tranny for the sale..
AIR #13
06-10-2020, 02:32 PM
#876
Richmond
, Kentucky
Already thinking of selling?
06-10-2020, 04:21 PM
#877
Airstream Driver
1994 30' Excella
Austin
Actually, NO! Sorry, I know you want it, but this will be a keeper for a while. You just have to finish your Argosy.
AIR #13
06-10-2020, 04:28 PM
#878
Airstream Driver
1994 30' Excella
Austin
Yes, max I could get with manually inflated bags was 4 1/4" on 1 side and 4 1/2" on the other. Just enough to unload the airbag Beam, but not enough to have room for the valves to clear. (not even enough room to get the darn wrench on top of the bag to unscrew the air fitting)
Dogbone is just blowing in the wind, since this "Airstream Busted Knuckle Garage" is a one man outfit with some old guy...
AIR #13
06-11-2020, 05:25 AM
#879
Richmond
, Kentucky
350's are WAY to long
By the time I finish the Argosy I'm going to be to old to use it......
06-13-2020, 04:49 PM
#880
Airstream Driver
1994 30' Excella
Austin
No more heat soaked starter
AIR #13
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
