Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 02-17-2020, 04:03 PM   #781
Airstream Driver
PeterH-350LE's Avatar
1994 30' Excella
1992 35' Airstream 350
Images: 49
How to restore a classic Airstream MH: 1 step at a time
Toilet seat restored, new seals and seat on Porcelain toilet
AIR #13
PeterH-350LE is online now   Reply With Quote
Old 02-17-2020, 09:21 PM   #782
"Alumi-holic"
cesalie2's Avatar
1982 31' Airstream 310
Dearman Avenue , Tennessee
Toilet Make and Model?
cesalie2 is offline   Reply With Quote
Old 02-18-2020, 05:08 AM   #783
Airstream Driver
1994 30' Excella
Images: 49
its a Sealand, now available as Dometic 511PS
https://www.dometic.com/en-us/us/pro...511-ps-_-25571
AIR #13
Old 02-18-2020, 06:19 AM   #784
"Alumi-holic"
cesalie2's Avatar
Just what I was looking for...thank you,
Old 02-28-2020, 05:59 PM   #785
Airstream Driver
1994 30' Excella
Images: 49
The early 90's MH have this "fancy" center panel(s) on the ceiling, covered in mouse fur. Unfortunately, the PO allowed several leaks to stain it beyond recovery. So I tackled the recovering with a high grade automotive vinyl. Tough job, fortunately I figured out how to pull 2 of the panels down and work on them in my shop.
I used Landau top commercial Contact cement to withstand the 120 plus summer temps and covered the ugly wall while I was at it.
Left the old recessed lights in place and added a few LEDs
ID:	362131   Click image for larger version
ID:	362133   Click image for larger version
AIR #13
Old 02-28-2020, 06:20 PM   #786
Airstream Driver
1994 30' Excella
Images: 49
here is the ugly wall before I laminated it with Vinyl
AIR #13
Old 02-29-2020, 03:38 PM   #787
Nice
Were you able to install the ceiling center panel by yourself? If so, any tips?!
1975 24' Argosy Motor Home
Old 02-29-2020, 06:28 PM   #788
Airstream Driver
1994 30' Excella
Images: 49
Originally Posted by bkahler View Post
Nice
I didn't have a clue how to remove those panels. Buried in the mouse fur, I found some small set screws on 1 side. Once those were removed the lip on the other side acted like a hinge. The long panel needs more than 1 person to install.
I checked on Freds archive and it looks like they first started to use these in the 1989 LE's.
AIR #13
Old 03-01-2020, 04:51 PM   #789
So airstream made a change in how the panels are installed, interesting. I've removed the old style panels before but have not as yet re-installed any of them!
Old 03-12-2020, 05:15 PM   #790
Airstream Driver
1994 30' Excella
Images: 49
To paint the front and rear skirt of my 350 took 5 rattle cans of automotive primer and more than 1 quart of Acrylic automotive paint (the stuff that takes hardener and reducer). I spray it @50# with a Binks conventional sprayer with an inline water filter. It would have taken at least 8-10 cans just for that, but never achieving the same thickness.
ID:	363142   Click image for larger version
AIR #13
Old 03-14-2020, 10:42 AM   #791
Airstream Driver
1994 30' Excella
Images: 49
some before and after pictures. Acrylic metallic automotive paint needs to be stirred constantly to avoid settling of the heavier metals. (don't asked me why I know)
ID:	363249   Click image for larger version
ID:	363251   Click image for larger version
AIR #13
Old 03-14-2020, 11:16 AM   #792
mayco's Avatar
champaign , Illinois
Looking great
mayco is offline   Reply With Quote
Old 03-19-2020, 10:05 PM   #793
Airstream Driver
1994 30' Excella
Images: 49
Due to all the unexpected time off, I am moving right along with the interior refurbishing. Not sure how you guys handle it, but this 350 resto has kept me occupied and away from the so overwhelming news every day. Waiting for the chairs to come back from the upholstery guy.
ID:	363543   Click image for larger version
AIR #13
Old 03-20-2020, 08:04 AM   #794
Airstream Driver
1994 30' Excella
Images: 49
Need help to figure this out:
Its located next the steering column, but not connected to it.The very top portion of this unit has a linkage to original cruise control. It has a fat ~1" hose going to the back (trans I assume right now) with a sending unit half way. It has an open ~1/2 port. I also found a second port on my steering pump tank, which was clamped shut (and leaking).
What was the function of this unit?
ID:	363558   Click image for larger version
AIR #13
Old 03-28-2020, 09:21 PM   #795
Airstream Driver
1994 30' Excella
Images: 49
Vertical window seal
This has been discussed several times over the years. Well, here is again, how to replace the vertical seal of the cab window. You may find that the one in place now is the original one, which is very hard to remove. Cutting the slot also helps tremendously with removing the old one.
AIR #13
Old 04-05-2020, 08:14 AM   #796
Airstream Driver
1994 30' Excella
Images: 49
Finally got around to replacing the lower belt line. I prefer to use olympics for the rivets. Such a nice look.
I also had the torn fabric inserts of the passenger seat replaced with this blue vinyl I am using as accents. My upholstery guy declined to do it, unless I would do the material removal and installation myself and just deliver the material to him. Now I understand why, it took me 1 1/2 to remove it and 5 !! to put it all back together. The armrest and the head rest and all the cable driven mechanics make it extremely difficult.
ID:	364910   Click image for larger version
AIR #13
Old 04-06-2020, 08:10 PM   #797
Airstream Driver
1994 30' Excella
Images: 49
Got the bumper cleaned up and polished. Before and after
ID:	365092   Click image for larger version
AIR #13
Old 04-15-2020, 03:50 PM   #798
Airstream Driver
1994 30' Excella
Images: 49
Getting some polishing done and redesigned logo space
ID:	365834   Click image for larger version
AIR #13
Old 04-15-2020, 06:24 PM   #799
"Alumi-holic"
cesalie2's Avatar
Nice!
Old 04-15-2020, 09:44 PM   #800
mayco's Avatar
WOW! Muy bueno!
Need a new gear/sprocket for a Reese lector-jacket! Ribbler Towing, Tow Vehicles & Hitches 4 06-03-2013 11:45 AM
Vintage Airstream jacket eBay Watch Airstreams on eBay 0 02-09-2012 11:10 AM
Bypass TBI water jacket???? Taxman General Motorhome Topics 8 06-15-2007 04:20 PM
motorhome jacket ALANSD Airstream Motorhome Forums 4 12-09-2002 04:58 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
