Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Classic Motorhomes
Old 07-02-2020, 08:52 PM   #921
cmadmaxman's Avatar
1991 35' Airstream 350
Columbia , Tennessee
Images: 40
Looking good Peter[emoji106]
Chris & Brenda....................cMADMAXman
AIR Member 12654
1991 350LE "Zephyr"
1982 310 MoHo (Sold! New home, NYC.)
Many Years ago, 1972 Argosy 24' trailer
Toad, 2001 Chevy Tracker 4x4
cmadmaxman is offline   Reply With Quote
Old 07-03-2020, 10:03 AM   #922
Airstream Driver
PeterH-350LE's Avatar
1994 30' Excella
1992 35' Airstream 350
Images: 49
Guess which side has the LEDS Head lights installed? And this is in low beam.
My box of LED's came without any documentation, so I had to dig through the forum and consult with Brad on how to wire the low beam.
In my case, I had rotate the three wires 1 slot clockwise. This can be done by either re-pinning the socket or using the supplied adapter.
Late Wayne's excellent description help a lot, thank you Wayne!
So many great people gone and they are missed.
I will repost his pictures in case someone else needs it.
AIR #13
PeterH-350LE is offline   Reply With Quote
Old 07-03-2020, 01:03 PM   #923
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Just sent you an IM on those headlights Peter
mayco is offline   Reply With Quote
Old 07-08-2020, 01:43 PM   #924
Airstream Driver
1994 30' Excella
Images: 49
I admit, I did ignore that little bit of rust on the transcooler lines, until I saw the drip. It will only drip with the pump running, so I just blamed the little wetness on "its coming from somewhere" So here is the beef:
The original replacement size on the 4L80E is 5/16x72" standard brake line.
I would venture to bet thats it is the same on the TH400.
Using the full length is pretty much impossible, unless you want to do a lot bending getting it into place. So instead I used 60" with unions to add the smaller sections to the radiator tank and external cooler.
And yes, you absolutely have to use a pipe bending tool to copy the old line.
I could not imagine a favorable outcome, loosing your transfluid going down the road, not to mention the vicinity of the exhaust
ID:	372289   Click image for larger version
AIR #13
Old 07-08-2020, 02:07 PM   #925
mayco's Avatar
Nice clean work Peter
Old 07-08-2020, 02:36 PM   #926
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
If you think doing the 2 transmission lines is tough, the fire suppression system I put in the 325LE ate up about 90’ if 3/8” line with a lot of unions (to many to count). When I was all done bending and installing the lines I opened the ball valve to the AFFF bottle and closed it after about 30 seconds. Only 3 leaks. I was glad to have my Snap-On crowfeet and line wrenches to finish the task. Regards, Bob
bobmiller1 is offline   Reply With Quote
Old 07-08-2020, 04:06 PM   #927
Airstream Driver
1994 30' Excella
Images: 49
At least, for the most part, you can pick and choose where you want to run those lines. The trans cooler lines do have a mandated route with little room to wiggle.
And I got it done with all my sh it tools, thats worth something
AIR #13
Old 07-12-2020, 07:36 AM   #928
Airstream Driver
1994 30' Excella
Images: 49
Originally Posted by PeterH-Airstreamer View Post
Did I mention that I hate those Furnas pressure switches? Only one i could find as a drop in replacement was a 125/95 and I have been having hell to get down to 95/80. I think its not possible to get that range. Best I can get is 100/75 and 100 is seems to be a magic number for compressors to start complaining. I thought I had it set, but after a big road trip today, it didn't want to shut off at 100.
Good report on rpm. Was running a tad over 2000 rpm at 65 with temp at 200
Grrrr, just to mention again how much I hate those Furnas style pressure regulators. It took me a looong time to get the new one I bought to have a range of 75-100. It worked fine until yesterday. Now it shuts off at 85 and comes on at 65. What the heck? I may have to replumb to accommodate a more reliable type unit.
Any suggestions for a good one?
AIR #13
Old 07-12-2020, 11:37 AM   #929
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
I don't know exactly what you mean by Furnas style pressure switch. I have always used a Square D brand switch with no problem. I guess now a days there are many cheap copies around but Square D has been good for many years. It's a pretty simple switch with a couple of springs and a few contacts. Maybe you need to check out some swap meets or garage sales and find one that was made 20 or 30 years ago.
Cheers, Dan
~ Margaret Thatcher ~
Old 07-12-2020, 12:13 PM   #930
Airstream Driver
1994 30' Excella
Images: 49
Thanks Dan, I looked at the square D (2nd picture) and they certainly have a much better adjustment mechanism (nuts instead of highly inaccurate plastic screws).
ID:	372681   Click image for larger version
AIR #13
Old 07-12-2020, 12:50 PM   #931
2007 22' International CCD
The story of the Airstream 310 Jacket
On the Square D pressure switch, the big spring sets the high pressure point, and the little spring sets the differential between high pressure shut off and low pressure pump start. The two interact a little bit, so adjust cautiously and in small increments.
Loosening the nut in the big spring reduces the shutoff pressure. I don’t remember the way the differential nut works but I suspect loosening it reduces the differential pressure. Experiment and let us know...
Old 07-12-2020, 06:03 PM   #932
1986 34.5' Airstream 345
Londonderry , New Hampshire
You may want to check the contact rating for the switch. Running
on DC is much harder on contacts than AC. The closest Square D
switch that I found was rated for 1.5 HP motors using AC but only
.25 HP motors using DC.
Air345Fly is offline   Reply With Quote
Old 07-12-2020, 07:40 PM   #933
Airstream Driver
1994 30' Excella
Images: 49
Good point, thanks
AIR #13
Old 07-13-2020, 11:22 AM   #934
Good point, thanks
Peter, if you have a relay controlling the compressor with the pressure switch controlling the relay then you don't need to worry about the pressure switch contact rating.
1975 24' Argosy Motor Home
Old 07-13-2020, 11:25 AM   #935
That is right. Automotive rated stuff will be designed for DC.
It is the AC rated stuff that can cause problems.
Old 07-13-2020, 12:11 PM   #936
Airstream Driver
1994 30' Excella
Images: 49
Excellent!
AIR #13
Old 07-15-2020, 09:53 AM   #937
Airstream Driver
1994 30' Excella
Images: 49
center hanger bearings rubber deteriorated had a good 1/4" play
AIR #13
Old 07-15-2020, 11:59 AM   #938
cmadmaxman's Avatar
Images: 40
While you have em out, I would replace all the u-joints as well!
AIR Member 12654
1991 350LE "Zephyr"
Old 07-15-2020, 01:15 PM   #939
Airstream Driver
1994 30' Excella
Images: 49
... and getting it balanced. Pulled the parking brake hub, now trying to find the right size rear oil seal
AIR #13
Old 07-16-2020, 08:01 AM   #940
Did you have any vibration coming from the drive line?
Need a new gear/sprocket for a Reese lector-jacket! Ribbler Towing, Tow Vehicles & Hitches 4 06-03-2013 10:45 AM
Vintage Airstream jacket eBay Watch Airstreams on eBay 0 02-09-2012 10:10 AM
Bypass TBI water jacket???? Taxman General Motorhome Topics 8 06-15-2007 03:20 PM
motorhome jacket ALANSD Airstream Motorhome Forums 4 12-09-2002 03:58 PM
