10-31-2020, 11:13 AM
#841
Churubusco
, Indiana
Took a minute to out the banana wraps back on
It's definitely a 10-footer job, but I'm happy enough. Polishing the bumper and painting the grill are next on that list.
And thanks Brad for selling me the lights, perfect fit
11-01-2020, 08:36 PM
#842
Churubusco
, Indiana
Got the old bushings out and the new bushings in. One of those things you'll think takes an afternoon and takes all weekend.
The springs were easy, but there was no way to fit the spring beam in the press, ended up using a heavy duty ball joint service kit. Got the job done eventually but took a few hours and a lot of patience.
Borrowed a beefier angle grinder and made pretty quick work of the cutting, plus it doesn't ruin the heat treat, not that that probably matters.
11-02-2020, 04:17 AM
#843
1986 34.5' Airstream 345
Londonderry
, New Hampshire
I always wondered about the damage to the heat treat on my torch cut springs but after 34 years it is probably not a problem.
11-02-2020, 05:49 AM
#844
Churubusco
, Indiana
Yea, it would soften the metal locally but at the very end where the airbags are anyway. If it caused problems I guess we all would have experienced them by now
11-02-2020, 08:42 PM
#845
Churubusco
, Indiana
Finished disassembly (got the other spring out) and started painting the wheel well
Reassembly should start tomorrow, hoping for a road test this weekend
11-03-2020, 02:19 AM
#846
1995 36' Classic 36
Ludington
, Michigan
Magnet18's 1983 310
Good work!
I’ll be right behind you on that project. Bit of a delay on back ordered Firestone air springs. Already received the Haldex leveling valves and Bilstein shocks.
11-03-2020, 06:05 AM
#847
Churubusco
, Indiana
Originally Posted by Kota
Good work!
Thanks!
Yours is the diesel pusher right? Do you have the same suspension? I thought those were a different chassis
11-03-2020, 10:08 AM
#848
1995 36' Classic 36
Ludington
, Michigan
Thanks!
It’s on a Spartan EC2000 chassis. Different beast but but getting new airbags, shocks, and leveling valves front and rear.
Good to see people tackling these projects. Just like working on a car. Bigger wrenches, bigger parts, and a bigger Jack!
11-04-2020, 08:12 PM
#849
1984 310 Limited
Airstream - Other
1984 31' Airstream310
Elkhart
, Indiana
Would love info on those lights. Looking for some myself. Thanks!
Cynthia
1984 310
11-04-2020, 09:07 PM
#850
Churubusco
, Indiana
Cynthia
1984 310
Brad PMd me and let me know the right part number is GM 916558 - might be able to find NOS units
Chris found them at mill supply, part number 66-152
https://www.millsupply.com/amber-parking-lamp-assembly-wi-66152.php?p=451636
11-05-2020, 05:10 PM
#851
Churubusco
, Indiana
Drained the diff... Ew
Anyone know if they used a gasket from the factory? There is no gasket, only RTV, which would be a good sign that this isn't the first ever change
11-05-2020, 05:13 PM
#852
1982 31' Airstream 310
champaign
There was a gasket on mine when I changed the fluid. I can’t remember where I bought the new gasket but it wasn’t hard to find.
11-05-2020, 07:04 PM
#853
Churubusco
, Indiana
Hmm. Pondering the welding.
ACS says it is"extremely important" to
1. Preheat to 5-700 F
2. Use Eutectrode 3026 1/8" TIG rod
3. Weld the center of the spring in 3 passes, staying away from the edges
Airstream, on the other hand
1. Preheat unknown
2. Weld type unknown, but they left a bit of spatter, so probably MIG
3. Welded an interface plate down first, along the edges, presumably to avoid the center of the spring
And I am unsure if I should re-use that interface plate, and if my flux core skills are up to the job. Hmm.
I'm guessing the point of the plate is that, if a weld cracks
1. You have 3 more holding it on
2. A crack along the edge won't break the spring
Based on where they're at, I'm not that concerned. It's not an eye on the end that will fail catastrophically, if all welds failed at worst you would have a terrible ride. Even if the top leaf snaps it's still not catastrophic.
I'd happily take it to a shop for a skilled tig welder to do it, but I think the general consensus outside this specific use case here is that springs are never to be welded.
Hmmmm...
11-05-2020, 09:01 PM
#854
Churubusco
, Indiana
As I often do in times of indecision, I fell back on that old mantra, perhaps even poem, that always steers me true. Nut up or shut up
After practicing on offcuts, I propped the spring up so the heat didn't get sucked down to the second one, preheated the area to 700 best I could with a torch (all the way to the end of the color chart, but well before glowing, the colors were quite easy to see) and copied the airstream procedure, down to the offset of the spring
Seems to be doing ok, but I can hear bits of popping as it cools, no bueno. But for all I know the airstream welds did that too, and after grinding the old ones off, they were definitely on their good.
I'll let these two on this side cool overnight, and test their integrity in the morning (hammer, vice grips)
11-05-2020, 09:14 PM
#855
1991 35' Airstream 350
Columbia
, Tennessee
The spring stirrup needs that 1/4 plate of mild steel to weld to, mild steel to mild steel, then you weld along the edge of that to the spring. DO NOT weld across the springs! That could cause them to crack.
You need to weld with a dissimilar rod, that will weld to mild steel to a harder steel like the springs without the weld cracking.
Chris & Brenda....................cMADMAXman
AIR Member 12654
1991 350LE "Zephyr"
1982 310 MoHo (Sold! New home, NYC.)
Many Years ago, 1972 Argosy 24' trailer
Toad, 2001 Chevy Tracker 4x4
11-05-2020, 09:16 PM
#856
Churubusco
, Indiana
Thanks a lot for the response Chris!
What dissimilar rod did you use?
11-05-2020, 09:32 PM
#857
Columbia
, Tennessee
Harris Super Missileweld rod should be available at your Airgas store, hopefully not to far away.
AIR Member 12654
1991 350LE "Zephyr"
11-05-2020, 10:25 PM
#858
Churubusco
, Indiana
Thanks Chris!
I could hear too many cracks popping into existence as those cooled to be comfortable, I'll get my hands on some of that and probably grind these two off and start over. Great that it's stick welding rod, that makes it easy.
11-06-2020, 02:04 PM
#859
Churubusco
, Indiana
Pleasantly surprised by the two welds, they're on there quite well. But I'll be doing the rest with the proper rod.
I had to order the welding rod online, should be here early next week. So no road test this weekend, but I have plenty to do either way
1983 Airstream 310 Class A Motorhome
-Rob
11-06-2020, 07:30 PM
#860
Airstream Driver
1994 30' Excella
1992 35' Airstream 350
Austin
Pretty impressive, Rob. Hats off for sticking with it and getting it done the right way !
AIR #13
