Old 09-15-2020, 07:07 AM   #701
Magnet18's Avatar
Churubusco , Indiana
Originally Posted by mayco View Post
If you’re willing, it would be great if you could photo document the rear air bag replacement.
I’m sure it’s in my future at some point. All the 310 owners would really benefit....thanks Rob.
Mike
Will do Mike!
My photo documentation for this thread is usually pretty lax, but I'll see if I can make something useful this time
Magnet18 is offline   Reply With Quote
Old 09-15-2020, 07:13 AM   #702
Magnet18's Avatar
Originally Posted by JeffofCT View Post
I used Henry's white on my canned ham trailer restoration. It held up well. As I recall, it cured pretty quickly, but then again I was in the summer sun. Gets about as hard as a finger nail.
I wonder if it needs the uv from the sun to cure, mine is still a bit rubbery feeling. Not that I'm worried about it, as-is it's still fine
Old 09-15-2020, 07:23 AM   #703
Magnet18's Avatar
Got the assembly line setup. Strip, paint, seals, reinstall.
Interesting, looks like airstream used leftover rubber hose as a spacer for some of the fixed windows, not all
ID:	378680   Click image for larger version
Old 09-15-2020, 07:37 AM   #704
Airstream Driver
PeterH-350LE's Avatar
1994 30' Excella
1992 35' Airstream 350
Images: 49
you just dont mess around, do you? Many of us do 1 window and then take a 3 week vacation. If you didn't have to chisel out the old one inch by inch, you may not be the first replacing the seal.
AIR #13
PeterH-350LE is offline   Reply With Quote
Old 09-15-2020, 08:04 AM   #705
Magnet18's Avatar
Haha, the seasons started changing and it kicked my butt in gear. I'm working with a weather window right now where I can actually get by with no windows or climate control, and I can paint without building a heated paint booth.
The old schlegel will indeed need chiselled out inch by inch, that's the project I start today while the wife strips the old paint off.
Old 09-15-2020, 09:00 AM   #706
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
I found that however I did the windows on the 325LE and the 370LE, each window took 4 hours to complete. I changed everything and even re-screened the screens. Dud I spell that right ? Regards, Bob
bobmiller1 is offline   Reply With Quote
Old 09-15-2020, 09:10 AM   #707
Magnet18's Avatar
Well, I'm up to 4 or 5 hours for the removal of 7 windows, so at least 23 hours to go by your math! Sounds like a good goal. Hoping to finish this weekend, I'm putting in about 4 hours a day.
Doing screens as well, going with a finer no-see-um mesh to keep the gnats out
Old 09-16-2020, 04:22 AM   #708
Magnet18's Avatar
Cleaned the old channel out yesterday evening
Old 09-16-2020, 06:44 AM   #709
Magnet18's Avatar
I was able to get a (just one) decent chunk out in one piece.
Here is a side by side comparison with the schlegel that inland rv sells.
The original was all rubber and looks much more, or exactly, like the AS1268 weather stripping than the schlegel.
Interestingly, the schlegel is exactly what airstream used in my cockpit windows, rather than the rubber.
No idea why they used 2 different materials on the same build, but I have no idea why they did a lot of things
Based on reports that the schlegel (that I have in hand, for free) will rust and/or cause rough operation, I went ahead and ordered the AS1268.
I figure I'm not doing this job again, might as well do it right
Old 09-16-2020, 06:49 AM   #710
Magnet18's Avatar
I'm also soaking some schlegel in warm salt water to see if it really does rust, or of that's a myth. The wire core of it might be aluminum, and I don't see any rust on my original cockpit slider tracks
1983 Airstream 310 Class A Motorhome
-Rob
Old 09-16-2020, 06:43 PM   #711
Airstream Driver
1994 30' Excella
Images: 49
I read on the InlandRV site that the new schlegle has alu guts. The original I have seen before definitely was rusty steel.
I like that the 1268 will perfectly conform to the curves if the back is sliced as described. It also lets you cut nicely working drain holes. I understand that the schlegle is supposed to be porous for draining, just not sure how efficient that is.
One more consideration is that you can adjust the 1268 by trimming if you happen to have a super tight channel spot.
AIR #13
Old 09-17-2020, 05:10 AM   #712
Magnet18's Avatar
Makes sense, I confirmed that the new stuff the PO bought is aluminum
My shipment of 1268 should be here Friday, I expect I'll have some schlegel for sale after that
Old 09-18-2020, 06:30 AM   #713
1971 31' Sovereign
1972 31' Sovereign
Soddy Daisy , Tennessee
Magnet18,
If you have any left over let me know, I need to change mine out on the 310 also. Got the little rusty screws out a while back so it will be easier to get apart to replace the gasket and our temps have dropped to a nice level to work outside.
cole3444 is offline   Reply With Quote
Old 09-20-2020, 08:08 AM   #714
Magnet18's Avatar
Originally Posted by cole3444 View Post
Magnet18,
Will do! I expect I'll have some, I'll post here.
Yesterday, finished stripping all the old sealant that was above the windows, captain tolleys on every rivet, and started painting the first of the windows. Should be able to keep painting and start reinstalling today
Old 09-23-2020, 07:21 PM   #715
Magnet18's Avatar
I drastically underestimated how long it would take to strip and prep and paint all the windows, finally finished last night, then got about half the screens done
Old 09-24-2020, 12:10 AM   #716
bobmiller1's Avatar
LOL......Regards, Bob
Old 09-26-2020, 06:03 PM   #717
Magnet18's Avatar
Long process stripping the window panes, finally got the first window resintalled, went pretty smooth.
Make sure to straighten and smooth the beat up corner of the slider window!
Different than what I saw in peters post, I had no problem waiting until the weatherstrip was installed to then install the sliding window, and had to remove it to get the screen window installed. What seemed easiest to me was
Schlegel
Screen
Slider
Upper channel
Lower channel
Fixed window
Very happy with the result, operates like new!
ID:	379550   Click image for larger version
Old 09-26-2020, 06:06 PM   #718
Magnet18's Avatar
I noticed the fuzzy seal on the screen frame is not even close to making a seal, does the screen frame need bent to a more aggressive angle? Seems risky
-Rob
Old 09-27-2020, 06:02 AM   #719
bobmiller1's Avatar
If you want a nice clean finish before you install the fin seal, take a Brillo or SOS pad to the frames and clean them all up, then you can run a pocket screwdriver down the fin channel before you put the adhesive on to get the old crap out, Regards, Bob
Old 09-27-2020, 06:17 AM   #720
Magnet18's Avatar
Thanks for the tip Bob!
Radiator Hoses for 1983 310 Billy B General Motorhome Topics 7 06-06-2016 05:59 PM
1983 310 Engine Problem Rik Mechanics Corner - Engines, Transmission & More... 7 10-28-2005 09:30 PM
1983 310 guages Bfrank General Motorhome Topics 6 07-23-2002 05:01 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
