RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 11-15-2020, 06:50 PM   #901
cmadmaxman's Avatar
1982 31' Airstream 310
Columbia , Tennessee
Have mixed feelings on the torque for these U-bolts. Here in the GM manual it calls for 200 ft lbs. Other places have them over 300 ft lbs!?
So I used the GM spec and had no problem with torqueing with my 250 ft lbs wrench!
Have been many thousands of miles and they haven't fallen of yet!
Here is a PDF of the page from the manual you can ponder over.
Rear springs on P30.pdf
Chris & Brenda
AIR Member 12654
1991 350LE "Zephyr"
1982 310 MoHo
Many Years ago, 1972 Argosy 24' trailer
Our Toad, 96 Saturn SW2 (270,000 and still going )
cmadmaxman is offline   Reply With Quote
Old 11-15-2020, 09:02 PM   #902
Magnet18's Avatar
Churubusco , Indiana
Attachment 383318
Good to know, thanks!
I hadn't checked the manual yet, online I had found the 300lb number.
A 200lb torque wrench will be much easier to come by than a 300lb!
Magnet18 is offline   Reply With Quote
Old 11-16-2020, 02:02 PM   #903
I've got one on the shelf that will do 600 lbs. Would that do it?
Old 11-16-2020, 02:19 PM   #904
Magnet18's Avatar
I'd imagine it will, but unless you're selling or taking a road trip, I don't think it'll do me much good down there in Kentucky
Old 11-19-2020, 09:49 PM   #905
Magnet18's Avatar
Wrapping up painting, very happy with it so far, we'll see how it holds up
3 layers of paint, 3 layers of matte enamel clearcoat
Starting on the floor as well if you couldn't tell by the pile of scrap
Old 11-19-2020, 10:03 PM   #906
Magnet18's Avatar
Also been playing with the new internet setup
Getting 40 mbps with AT&T and about 20-30 with Verizon, out in my backwater neck of the woods that's pretty good. Able to hotswap between the two without hardly a hiccup, did so this morning when verizon was acting up.
Still need to get the load sharing server setup, but so far I'm happy
ID:	383550   Click image for larger version
Old 11-20-2020, 08:21 AM   #907
cmadmaxman's Avatar
Cool Rob!
Think they could have gotten a few more antennas on that unit?
Chris & Brenda
AIR Member 12654
1991 350LE "Zephyr"
1982 310 MoHo
Old 11-20-2020, 12:07 PM   #908
Magnet18's Avatar
Cool Rob!
There is also a GPS antenna, not connected in that picture
Yea, they quite obviously didn't expect anyone to actually use the included antennas, I've got it run on a harness now to a roof mount 7-in-1 antenna
Old 11-20-2020, 03:32 PM   #909
Magnet18's Avatar
Omni directional all in one antenna
Need to get it mounted on the roof, shouldn't be a big job
Old 11-21-2020, 10:43 AM   #910
Magnet18's Avatar
Grille and windshield wipers painted, I think that leaves just the stripe and rear banana
Old 11-21-2020, 12:19 PM   #911
Airstream Driver
PeterH-Airstreamer's Avatar
1994 30' Excella
1992 35' Airstream 350
Images: 51
Rob, Is that set-up 4 and 5G compatible?
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 11-21-2020, 01:11 PM   #912
Magnet18's Avatar
Compatible with all the 4g frequency bands that currently exist, not with 5g. 5g is still in its infancy. The "good" 5g is millimeter wave and has almost no range, it can basically be blocked by a piece pf paper, used only in downtown urban areas and sports stadiums
The rest of the "long range 5g" currently being rolled out is mostly just for the sake of slapping the 5g name on it, and is using 4g broadcast equipment and sharing the load with 4g traffic, so currently no benefit to 5g for RVing. I'm thinking 4g will be the way to go for at least a few more years.
If you wanted to think longer term the best option currently is the pepwave balance 20x
http://download.peplink.com/resource..._datasheet.pdf
It is very similar but instead of 2 4g modems it has one 4g modem and an interchangeable slot, which you could put a second 4g modem in now and put a 5g modem in later when it's established
The downside is it's not ruggedized for RV environments, and quite a bit bigger
Old 11-21-2020, 01:14 PM   #913
Magnet18's Avatar
Driveshaft in, balanced and painted with new Spicer joints
A tip for others doing this job... Careful not to let it fall on your head
Old 11-21-2020, 02:38 PM   #914
Airstream Driver
1994 30' Excella
Images: 51
Good info, thanks. AT&T is anxious to get me to 5g and buy a new Phone...
AIR #13
Old 11-21-2020, 03:43 PM   #915
Magnet18's Avatar
Ha, I'm sure they are
Old 11-21-2020, 03:47 PM   #916
Magnet18's Avatar
So the new saddles had exactly the same profile as a spring, sharp 90 degree corner...
These were pretty much the only saddles I could find with a 2.5" width, supposed to be for similar gm vehicles
A couple boring hours playing flap-disc Michaelangelo, and I ground in a profile I'm happy with, they sit nice and flat now. Spacing compared with the old "saddle" is the same
ID:	383612   Click image for larger version
Old 11-21-2020, 04:44 PM   #917
Magnet18's Avatar
Torque values from my shop manual, looks like 200lbs here too.
ID:	383616   Click image for larger version
Old 11-22-2020, 10:43 AM   #918
Magnet18's Avatar
Leak reappeared on the leveler jack, definitely coming from the actuation cylinder so that's good news
I'll call hwh on Monday and get a couple on order
Old 11-23-2020, 02:50 PM   #919
Magnet18's Avatar
Ordered the actuator cylinder from HWH. Not in stock anymore, unfortunately, so we will see how long the wait is.
https://www.airforums.com/forums/f15...ml#post2428281
1983 Airstream 310 Class A Motorhome
-Rob
Old 11-24-2020, 08:34 AM   #920
Magnet18's Avatar
Well my plans for a road test last sunday were foiled by an unexpected snowstorm/freezing rain all day. Should be great weather Friday Saturday and Sunday, looking forward to it.
Instead I plowed ahead on the floor, got all the holes patched up and underlayment down, 1-1/2" 3/8 stainless bolts and T nuts worked well for 2 layers of 5/8 plywood.
ID:	383725   Click image for larger version
Radiator Hoses for 1983 310 Billy B General Motorhome Topics 7 06-06-2016 06:59 PM
1983 310 Engine Problem Rik Mechanics Corner - Engines, Transmission & More... 7 10-28-2005 10:30 PM
1983 310 guages Bfrank General Motorhome Topics 6 07-23-2002 06:01 PM
