11-07-2013, 05:56 PM
#321
1968 24' Tradewind
1959 17' Pacer
holly springs
, Georgia
Way to go Alan, you definitely have the camper for it.
11-09-2013, 07:29 PM
#322
1966 26' Overlander
Woodstock
, Georgia
not sure where the pix will appear, but they shot plenty. And video. I would like some more of that action.
11-10-2013, 07:41 PM
#323
1986 32' Excella
Canton
, Georgia
Alan, that's really cool! We can't wait to see the pictures whenever/wherever they appear!
11-11-2013, 08:14 AM
#324
1966 26' Overlander
Woodstock
, Georgia
It was a fun day, with a lot of people working on the set...Gorgeous weather to be at that park too
12-13-2013, 10:43 AM
#325
1966 26' Overlander
Woodstock
, Georgia
STOVE Exhaust VENT FAN
I njeed to replace the fan motor in our stove vent exhaust. Any ideas where i can get one or should I pull it our first and see what will fit there?
12-13-2013, 06:45 PM
#326
Remember, Safety Third
Possum Trot
, Georgia
You know, I think I read here recently that somebody found an equivalent (older Airstream) fan motor at Grainger.
12-13-2013, 08:27 PM
#327
Central
, Mississippi
Mine needed a good cleaning
12-14-2013, 06:46 AM
#328
1999 27' Safari
Stone Mountain
, Georgia
Alan, We seem to follow in parallel universes. The same motor was dead in our Overlander. I think 1960's grease cooking did ours in a long time ago. Anyway, it was frozen. Even taking it apart on the bench didn't help. I replaced it with a used roof vent fan motor I had. I just had to modify the shaft slightly to fit the little aluminum blade it comes with. Otherwise, it now works great. As of where to get one? It is different ( blade and motor ) than motors available, but once you get the motor out, you can see the similarities ( mounting, etc ) to the common roof fans.
Chris
_______________________________
Beth Wallace & Chris Sanor
1999 Safari 27'
1966 26' Overlander International (damaged back panel)
Towed by 2016 Ford F-150
Tin Can Tourist
TAC #GA-27
AIR #34930
12-14-2013, 11:27 AM
#329
Corona
Chris
The original stove exhaust fan motor is still available, from parts stocking dealers.
12-14-2013, 05:19 PM
#330
1966 26' Overlander
Woodstock
, Georgia
all good info. Yes Chris Overlander ownership runs in a parallel universe...we all experience similar things....I guess I need to pull the fan motor out and see what it look like...
12-14-2013, 06:25 PM
#331
Corona
It should look exactly like the motors in your ceiling fans.
12-14-2013, 07:47 PM
#332
1965 26' Overlander
Tulsa
, Oklahoma
I had the same issue on my 65 overlander. Since I was replacing the original roof bent with a much better fantastic fan , I used the motor from it; slightly larger motor, but it worked just fine!
12-15-2013, 07:25 AM
#333
1999 27' Safari
Stone Mountain
, Georgia
Same here Cochese
1999 Safari 27'
Tin Can Tourist
TAC #GA-27
AIR #34930
12-15-2013, 11:12 AM
#334
1966 26' Overlander
Woodstock
, Georgia
The exhaust fan in the bathroom area works great. Not bad for 50 yrs old
04-16-2014, 08:09 AM
#335
1966 26' Overlander
Woodstock
, Georgia
I just removed our working bathroom fan to replace it with a Fantastic Vent.
I seem to remember someone saying this fan or the motor was the same for the stove vent...is that true?
My stove vent fan does not work so it wold be great if this will replace it.
04-16-2014, 11:31 AM
#336
Corona
Yes, it's the same motor.
But check it out as a previous owner may have changed it out to something else.
04-16-2014, 11:46 AM
#337
1999 27' Safari
Stone Mountain
, Georgia
Funny Alan, we seem to work in parallel universes. I have a new Fantastic Vent in my garage waiting for me to install in the same location! . I just replaced. The skylight last weekend. The motor will work with some modification of the fan. Adapting the vent fan to the roof motor, but as I recall, it was pretty easy. Ours works great.
Sent from my VS840 4G using Airstream Forums mobile app
1999 Safari 27'
Tin Can Tourist
TAC #GA-27
AIR #34930
04-16-2014, 02:46 PM
#338
1966 26' Overlander
Woodstock
, Georgia
how cool is that? I was surprised at the size of the aluminum wire that went to the fan. Monstrous stuff. With Rob's help it was an easy job.
This trailer is so original nothing was ever changed except the front window to lexan.
05-01-2014, 07:43 AM
#339
1966 26' Overlander
Woodstock
, Georgia
I just got an aluminum vintage style drip rail for over our front window. Saw this recently on a vintage AS and it looked great. If it goes well I will do the other windows too. Figured on starting with one and seeing how it works out.
05-01-2014, 10:21 AM
#340
Corona
If your windows leak, then they need gaskets.
Installing the drip caps "DOES NOT" stop leaks in a wind driven rain, or when the trailer is in motion when it's raining.
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
A/C for 1966 Ambassador
law1966 |
Member Introductions |
1 |
07-24-2011 09:24 PM |
1966 airstream
eBay Watch |
Airstreams on eBay |
0 |
03-26-2010 06:40 AM |
1966 airstream
eBay Watch |
0 |
03-19-2010 06:10 AM |
1966 airstream
eBay Watch |
0 |
03-01-2010 07:30 PM |
1966 TradeWind
66TradeWind |
1959-69 Tradewind |
2 |
03-18-2002 07:09 AM |
