Old 01-08-2011, 01:05 PM   #201
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Fridge in
I lucked into a nice stainless stell front refridgerator, and some sweet carpet for the hall.
I am thinking of 4x4s under the fridge to raise it some, then figure out a way to secure it. Then, trim around it some. It is smaller than the old Dometic.
Also got the bi-fold wood bathroom door back in today.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 01-08-2011, 04:56 PM   #202
1966 26' Overlander
Bluffton , South Carolina
I like the fridge. Have one very similar and I may have to use it. I'm testing my domestic now.
teufel is offline   Reply With Quote
Old 01-09-2011, 10:24 AM   #203
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Mine was totally rusted out. I am playing with ideas to mount the fridge. Thinking I will use two 4x4" boards under secured to the floor, then a pair of small "handles" and I will strap the fridge thru the handles with a ratchet strap. This way I can easily take it out if I want to and it won't move when it is in there.
Then I have to create some trim to surround it so it fits the hole better. It's a bit narrower and doesn't have the underneat extra panel the Dometic had.
Whaddaya all think?
AIR #005
retired!
Old 01-09-2011, 01:28 PM   #204
1966 26' Overlander
That should work. I would Mount panel with rare earth magnets in end of 4x. Drill some finger holes and vents call it good. Ratchet strap would work but check often. Angle iron with lags would work better. I think there's. Mount holes in front crossbar of fridge too. Two small lag bolts and done.
Old 01-09-2011, 03:15 PM   #205
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Whats the rare earth thing do and where would u get them?
AIR #005
retired!
Old 01-09-2011, 05:41 PM   #206
1966 26' Overlander
Rare earth magnets are extremely strong magnets. The magnet would act as your catch for removable faceplate. Magnets.can be purchased online and are very common at wood working sites. I think rockler sells them. Ill look for a supplier when I get home.
Old 01-10-2011, 11:02 AM   #207
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
does anyone know will brass opd valves for 30# tanks work with aluminum tanks? The guy selling a pair does not know. Got a dealer I can go to, but curious...
AIR #005
retired!
Old 01-10-2011, 11:08 AM   #208
Lothlorian's Avatar
Loganville , Georgia
Alan: I have brass on mine. The gas company did not say anything and they installed and certified them. Mine still work great.
Brian
Brian & Adrienne
Lothlorian is offline   Reply With Quote
Old 01-19-2011, 11:04 AM   #209
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
I pulled the curbed plastic panels from the bathtub outer wall. They are cracked pretty badly.
I am thinking of having some fabbed in metal and then skinning them with flexible plastic made for bathrooms. . I have found them available thru Lowe's and HD.
Any other ideas for this?
AIR #005
retired!
Old 01-19-2011, 07:14 PM   #210
Central , Mississippi
I bought a set for my 40lbs from Out of Doors mart...I seem to remember they had some pretty good on-line info that showed a 30 aluminum tank uses the same valve as a 20 lb steel tank...but double check me on that.
If that is the case, I'd print the info and haul them to my local propane shop and see if they would sell the valves and install on sight. But like I said...double check my info!
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie(RIP) -
A honkin' long 34' named AlumaTherapy https://www.airforums.com/forums/f20...num-54749.html
and a 26' '63 Overlander, Dolly https://www.airforums.com/forums/f10...ome-71609.html
Old 01-19-2011, 09:16 PM   #211
Athens GA
Myrtle lynn's Avatar
1995 28' Excella
1989 34' Excella
1986 31' Sovereign
1987 34.5' Airstream 345
Athens , Georgia
I have a great metal guy here in Athens GA. He could make anything at a low $$. What year AS? Let me know if you need his #.
Athens GA
Myrtle lynn is offline   Reply With Quote
Old 01-20-2011, 12:19 PM   #212
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Thanks for that too...I have a local fabricator near my home who did another guy's 60's airstream parts.
AIR #005
retired!
Old 01-22-2011, 01:25 PM   #213
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Bathroom sink; reaching frustration level!
I scrunched into the bathtub to get my wrench in to the hole for access to the faucet connection. I managed to get the hot water side loose-- YAAAY, and then nothing more-- WAAAAH ...in an hour.
The hole is pretty small, you can't see what you are doing when your arm is in it, and the wrench barely fits so that you have little room to turn it..
HELP !
I could not get the 2 nuts that hold the faucet itself to turn at all. I will spray some rust buster on those and go for it again on them.Might have to cur the faucet off somehow.
-Also what is the little white box with three hoses on it that go to the toilet? It is mounted on the inside of the camper's shell at the very back.
AIR #005
retired!
Old 01-22-2011, 01:47 PM   #214
Lothlorian's Avatar
I have had the same problem with screws and nuts. I squirted with liquid wrench and did them the next day. Man it is cold out there today. We just put some new tear drop lights on ours and organized the tools. It is cold out there today.
Brian
Brian & Adrienne
Old 01-22-2011, 01:55 PM   #215
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
How did you get your hands in there? I just read a post where the guy cut the faucet body off with an angle grinder cut off wheel. Thinking of going to Harbor Freight to get one.
I also read one guy cut the supply lines with a tubing cutter...I have one of those I can try.
Yeah it is pretty out-- but my hands were stiff quickly after working with no heat on.
AIR #005
retired!
Old 01-22-2011, 04:38 PM   #216
Lothlorian's Avatar
My bath tub faucet came right off. It was coming through the wall under the twin bed. I cut the supply lines off. Who ever owned it before me had cut the copper lines and put that gray pipe on. No problem. Where I had problems was getting the pluming nuts loose on the galley. Those things did not want to come off. Today I was taking off some curtain rods to strip and clean and those screws would not budge. I was starting to strip the screws with my screw driver. I used liquid wrench on them and let them sit for about an hour. I got all the screws out but one. I had to cut it.
Brian
Brian & Adrienne
Old 01-23-2011, 07:31 AM   #217
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Just the opposite for me ,the galley faucet popped right off once I got the wrench in there.
I will attack the bathroom again, maybe today.
AIR #005
retired!
Old 01-28-2011, 05:00 PM   #218
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Some new pix
Hadn't out up any in awhile. Here is the inside with all the wood back in, cork floor and carpet down. Bedding is off on one side so I can redo plumbing thru there...
ID:	120296   Click image for larger version
AIR #005
retired!
Old 01-29-2011, 01:16 AM   #219
Lothlorian's Avatar
Alan:
Looking good inside. You are so far ahead of where I am.
Brian
Brian & Adrienne
Old 01-30-2011, 05:26 PM   #220
Wow, it looks GREAT!
I've got a ways to go...
1966, 1966 overlander, bunk bed
A/C for 1966 Ambassador law1966 Member Introductions 1 07-24-2011 09:24 PM
1966 airstream eBay Watch Airstreams on eBay 0 03-26-2010 06:40 AM
1966 airstream eBay Watch Airstreams on eBay 0 03-19-2010 06:10 AM
1966 airstream eBay Watch Airstreams on eBay 0 03-01-2010 07:30 PM
1966 TradeWind 66TradeWind 1959-69 Tradewind 2 03-18-2002 07:09 AM
