08-26-2012, 05:20 PM
#301
1966 26' Overlander
Woodstock
, Georgia
Oven
Oven in our66 looks to be in great shape. But I can't get the pilot
To light. What position should the valve on the under trailer gas
Line be in to be open? I dont smell any gas when I turn the pilot knob on
Stove works 100%
08-26-2012, 07:36 PM
#302
Remember, Safety Third
Possum Trot
, Georgia
Counter-clockwise, I think, should be the open position, just like the hose-bib on the side of your house. If you have one of those valves that only turns 90 degrees, the handle should line up in-line with the actual gas line. 90 degrees out of line would mean it's closed.
Does that make sense?
08-28-2012, 05:48 PM
#303
1966 26' Overlander
Woodstock
, Georgia
Yes...should I unscrew it and run some air through? Not getting a lighted pilot.
08-28-2012, 06:40 PM
#304
Central
, Mississippi
My '63 has a pilot light shut off...look for the small aluminum tube that comes from the oven, see if there is a small screw at 90 degrees where it goes into the control.
The hole in the pilot light that allows the gas to escape is about the size of a hair. Mine was corroded closed and I had to get another one.
09-22-2012, 07:35 AM
#305
1966 26' Overlander
Woodstock
, Georgia
Fixed it. Cleaned all the parts outside using solvent, Dried them for a day and blew out with compressed air. Lit the pilot and the burner came right on when I dialed up the temp to 300.
Nice blue flame. Ready to bake. Glad that works.
10-19-2012, 05:25 PM
#306
1966 26' Overlander
Woodstock
, Georgia
New question..light switch?
On the kitchen wall next to the large sliding cabinet over the refrig. There is a switch plate. I has a larger pair of wires connected than a 12v light would need. What could it I be for? A refrig control for the old dometic?
10-25-2012, 12:17 PM
#307
1966 26' Overlander
Woodstock
, Georgia
Never mind,,its the old water pump switch.
Meanwhile I bought a 1966 Trailer license Plate from Ohio. Should look very cool on the Ohio built Overlander.
01-31-2013, 09:14 AM
#308
1966 26' Overlander
Woodstock
, Georgia
Leak fixed...not
The trailer had a leak ( imagine that!) for a long time while it sat unused. It dripped water down the black vent pipe over the bed and behind the kitchen area.
I tried sealing the old vent cap, but it did not help.
Ordered and installed a new mushroom type cap, cleaned the whole area and sealed beneath and around the vent well. Even shot some flex seal up around the opening from the inside.
Looked like a plan.
First big time rain storm yesterday with a lot of wind and the pipe had water on it again. Not a lot, but enough to hold me back on the next job- replacing the veneer below it that has water damage.
07-11-2013, 02:51 PM
#309
1966 26' Overlander
Woodstock
, Georgia
TANKS to the Guys
Thanks to a few of the guys here, notably KayakKampers, KevinB, and Overlander62 - Frank..
I was able to finally get out the infamous galvanized box that surrounds the black tank. Now I need to get one fabbed up so I can put it back in.
A nasty three or four day job of drilling rivets, pulling out old rusted bolts and finally getting the box to drop out.
07-14-2013, 11:10 AM
#310
1999 27' Safari
Stone Mountain
, Georgia
Believe it or not Alan, ours was worse! By the looks of the mounting screws, I would double, at least, the number of them on the new tanks. Chris
_______________________________
Beth Wallace & Chris Sanor
1999 Safari 27'
1966 26' Overlander International (damaged back panel)
Towed by 2016 Ford F-150
Tin Can Tourist
TAC #GA-27
AIR #34930
07-14-2013, 01:00 PM
#311
1966 26' Overlander
Woodstock
, Georgia
I plan on using a lot. At least the box was intact enuf to allow measuring.
08-08-2013, 03:20 PM
#312
1966 26' Overlander
1995 36' Cutter Bus LE
Largo, Florida
Black water "Tanks" for all your help
Hi Allan: I too have a '66 Overlander Twin. I'm interested in knowing what made you venture into changing it out. Iv'e thought about doing mine and at the same time adding a gray water tank also. Any advise would be appreciated.
Jean b
08-09-2013, 09:38 AM
#313
1966 26' Overlander
Woodstock
, Georgia
I had to change it out as it was badly corroded as most of them are. It was not holding up the tank anymore by much...
08-30-2013, 12:04 PM
#314
1966 26' Overlander
Woodstock
, Georgia
The galvanized pan is finally installed. I painted it inside with Flex seal. Outside with black rustoleum. Took about 70 3/4" # 10 screws. I had a hard time finding short fatter screws, wanted #12, went to 4 stores, settled for 10. Needed 3/4 with the 5/8 floor and the thickness of the sheet metal.
Hopefully it will stay where it is. Forgot to take a pic when it was open.
Reinstalled the bumper trunk, now have to do the belly pan. May need to get some sheet aluminum for patches.
08-31-2013, 09:53 AM
#315
1966 26' Overlander
Largo, Florida
Alan: I really enjoy your blog--a wealth of info-thanks.
09-02-2013, 06:49 AM
#316
1999 27' Safari
Stone Mountain
, Georgia
That's great Alan. Holy cow! 70 screws! I don't think you have to worry about it falling out! Nothing wrong with too many, it should give you peace of mind. My new tank stays very dry as I spent a long time sealing the seams at the back of the trailer, above around and near the back. When I open the rear door ( where the toilet, battery, etc is ) the floor is nice and dry after big rains. Of course under the storage hatch at the bumper gets wet, but drains well. Ideally, the aluminum skin will allow any water in to escape out. Can't wait to see it finished.
Chris
1999 Safari 27'
Tin Can Tourist
TAC #GA-27
AIR #34930
09-02-2013, 08:40 AM
#317
1966 26' Overlander
Woodstock
, Georgia
I shouldn't say this--- but I also spotted each screw with wood glue. I expect 50 years from now someone will not like that..
I do have a small spot of wood rot at the very back edge of the trailer- where the access panel was open for awhile. Since it is sealed it no longer leaks. I have coated tha area in wood hardener and such to keep it from getting worse.
11-06-2013, 05:12 AM
#318
1966 26' Overlander
Woodstock
, Georgia
Photo Shoot
A big thanks for a referral from a member here- my Overlander spent the day in a photo shoot at Stone Mountain campground.
A beautiful day and it was good to see the Airstream have her moment in the Sun!
11-06-2013, 07:15 AM
#319
Pet Sitter Extraordinaire
1989 33' Land Yacht
Chattanooga
, Tennessee
That is so awesome! Great picture. Welcome to stardom!
Kathy, Tommy, & Crew, Chattanooga, TN
Air #2757
1989 SquareStream (Annie #8)
11-07-2013, 05:47 PM
#320
Possum Trot
, Georgia
So what publication is that going to appear in? I'll go buy several copies so I can brag about my friends with the famous Airstream.
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
A/C for 1966 Ambassador
law1966 |
Member Introductions |
1 |
07-24-2011 09:24 PM |
1966 airstream
eBay Watch |
Airstreams on eBay |
0 |
03-26-2010 06:40 AM |
1966 airstream
eBay Watch |
0 |
03-19-2010 06:10 AM |
1966 airstream
eBay Watch |
0 |
03-01-2010 07:30 PM |
1966 TradeWind
66TradeWind |
1959-69 Tradewind |
2 |
03-18-2002 07:09 AM |
