Old 02-01-2011, 11:17 AM   #221
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
added two new shiny faucets last night, just haven't hooked them up yet. Still no pex.
But ..boy they look good!
I sanded and painted the bathroom sink Saturday with Krylon fusion and then gloss clear coat on Sunday. It came out good for 4 bucks worth of paint. Only a couple of very tiny spots I am not happy with, but that is only seen if u stick your face right on it. Been told that the paint holds up- guess we will see.
Found out that the hot water heater is a newer unit than I thought and looks pretty good all around. If it doesn't leak,,,I will clean it up soon. The tank seems to be solid all over. Great news,,,don't need to buy anything I don't need to buy.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 02-09-2011, 11:56 AM   #222
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
I did use an angle grinder to cut off the corroded bathroom faucet. It would not budge otherwise. Also cut out the remainder of copper except for the curved piece that goes under the bed into the galley. Might have to pull the furnace to get to that one.
Got all the fittings I need to start, and crimp rings. Waiting to get a crimp tool next.
AIR #005
retired!
Old 02-15-2011, 07:45 AM   #223
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
White box for toilet
Posted this before but no answer yet--the toilet lines run to a small white box mounted at the back of the trailer shell. Is this a pressure regulator? As soon as my crimp tool gets to me I want to start installing the pex. If need be I will use that box as it is, or maybe I can bypass it and use another newer regulator. Any know what that box is for?
AIR #005
retired!
Old 02-15-2011, 02:27 PM   #224
1966 26' Overlander
Bluffton , South Carolina
No box in mine, but PO removed check and pressure regulator. They were not mounted in box. External pressure regulator used and everything seems to work. Haven't gone PEX yet.
teufel is offline   Reply With Quote
Old 02-15-2011, 03:11 PM   #225
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Mystery Box
here is a shot if the mystery box..It has 1 water line going in and two coming out. I removed the outs.
AIR #005
retired!
Old 02-15-2011, 03:13 PM   #226
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
while I am putting up pix, here are my two new faucets. I painted the bathroom sink, came out about 90% to my liking.
ID:	122342   Click image for larger version
AIR #005
retired!
Old 02-15-2011, 07:22 PM   #227
1966 26' Overlander
My owners manual shows a water filter being mounted there. Could that be it? One cold supply in 2 out.
Old 02-16-2011, 11:12 AM   #228
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
cool! you might have hit it. I will remove it and see what is inside. My toilet seems to have 3 water lines. I will have to see why.
AIR #005
retired!
Old 02-19-2011, 02:46 PM   #229
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Got the fridge installed today, screwed it into the floor with 4 small brackets.
Started on the Pex, and laid some in, but will need flexible supply line to connect the faucets and toilet, it is too hard to do this any other way.
AIR #005
retired!
Old 02-24-2011, 04:46 PM   #230
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Some new finds
Got a perfect little Microwave to sit on the counter. Sharp "Half Pint." Also two aluminum wall sconces for the living room area.
ID:	122994   Click image for larger version
AIR #005
retired!
Old 02-24-2011, 05:14 PM   #231
Lothlorian's Avatar
Loganville , Georgia
Alan:
I am really impressed! You are really moving along and everything really looks great.
Brian
Brian & Adrienne
Lothlorian is offline   Reply With Quote
Old 02-25-2011, 10:11 AM   #232
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Just not the outside yet. I have stripped what I could with the Removall I had left, but it was only one or two panels. Will have to order more.
AIR #005
retired!
Old 03-08-2011, 10:57 AM   #233
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
OPD Valves
Still have not gotten the opd installed. The dealers I reached either don't have them or can't recertify them so far. No rush but ..
Will these fit? If so I might go ahead and do my own install...They are brass and 30# rated.
Name:	opd valves.JPG
AIR #005
retired!
Old 03-08-2011, 11:07 AM   #234
Lothlorian's Avatar
Alan:
I was trying to find people forever before I got them done in Illinois. I was told you have to get them certified showing they were installed by certified people. Otherwise they will not fill them with out the certification tag. The other thing is they use a certain type of glue for them, so they don't leak.
Brian
Brian & Adrienne
Old 03-09-2011, 07:49 AM   #235
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Blossman in Cleveland GA says they will do it if i leave them there for a day or so. I think I found the valves on EBAY finally most sellers have no clue if they will work for aluminum tanks, but the propaneguy there may have 2.
As long as the water works, my wife will be happy and we can cook with our microwave and grill for now.
AIR #005
retired!
Old 03-09-2011, 08:20 AM   #236
kevinb's Avatar
1968 24' Tradewind
1959 17' Pacer
holly springs , Georgia
Alan
Talk to Mark at Blossman in Canton,he should be able to help. You will have to leave them for a day but that is way closer. If you want I'll stop and see if he will do it.
Kevin
kevinb is offline   Reply With Quote
Old 03-10-2011, 11:18 AM   #237
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
I didn't know there was one there. Cartersville said they couldn't do it. I can get two valves from the propane guy on ebay...just need to install them. If I can get my old ones out, I might just buy and put the new ones in.
I live near Canton, so that could work too.
AIR #005
retired!
Old 03-12-2011, 06:55 AM   #238
kevinb's Avatar
1968 24' Tradewind
1959 17' Pacer
Alan
Mark is in both Cartersville and Canton I'll stop by next week and ask him. Dont know why they told you no go.
Kevin
Old 03-12-2011, 04:08 PM   #239
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
I appreciate that, I attempted to get the valves out today, forget about it! Back on the plumbing, and my wife is making the curtains. Got some pex done, the crimper is really cool and easy so far..
AIR #005
retired!
Old 03-13-2011, 07:39 AM   #240
kevinb's Avatar
1968 24' Tradewind
1959 17' Pacer
They did tell me that there was a possibility of the threads stripping when the old valve was removed. Mine turned out ok and they were a little older than yours.
Kevin
1966, 1966 overlander, bunk bed
A/C for 1966 Ambassador law1966 Member Introductions 1 07-24-2011 09:24 PM
1966 airstream eBay Watch Airstreams on eBay 0 03-26-2010 06:40 AM
1966 airstream eBay Watch Airstreams on eBay 0 03-19-2010 06:10 AM
1966 airstream eBay Watch Airstreams on eBay 0 03-01-2010 07:30 PM
1966 TradeWind 66TradeWind 1959-69 Tradewind 2 03-18-2002 07:09 AM
