Old 07-09-2011, 01:28 PM   #261
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
New interior stuff
Haven't done much on the 66 lately as we were away for most of June. Came home and finished the tile in the bathroom, added some cool pillows to the bedroom, and stripped the clear coat.
Next up is fabbing some lower tub surround panels, trimming out the carpet to tile spot and some polishing.
ID:	134344   Click image for larger version
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 07-09-2011, 05:04 PM   #262
Remember, Safety Third
Jim & Susan's Avatar
Possum Trot , Georgia
Love that tile.
www.nesa.org
Air No. 6427
Jim & Susan is online now   Reply With Quote
Old 07-11-2011, 03:45 PM   #263
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
thanks Lowe's a buck each.
I started polishing too. Using Rob Baker's method so far, with success on the first pass. It uses Diamondbrite form Lowe's on a Cyclo. I wipe it down with mineral spirits after. I will have to get a bit more aggressive on some spots on the next pass, but so far I am looking pretty shiny in a half hour per panel.
I may try red compound on the tough spots and the Diamondbrite, or order one can of Nuvite G. Some very obvious filliform and one place where a kid scratched their name in the side, luckily not very deeply. Never saw that until I stripped the clearcoat.
AIR #005
retired!
Old 08-08-2011, 06:22 PM   #264
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Bathroom is finished
Finally after a month of trying to come up with a way to finish out the cracked tub surround panels,,,here they are.
AIR #005
retired!
Old 08-08-2011, 06:32 PM   #265
reinergirl's Avatar
Hollis , New Hampshire
Certainly was worth the wait! Looks great!
reinergirl is offline   Reply With Quote
Old 08-09-2011, 06:39 AM   #266
kevinb's Avatar
1968 24' Tradewind
1959 17' Pacer
holly springs , Georgia
Alan
The bath on 64,65,66 can be a challenge, nice job! Cant wait to see all your handiwork at Falluminum.
Kevin
kevinb is offline   Reply With Quote
Old 08-09-2011, 11:23 AM   #267
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
thanks I did on the cheap, materials were under 40 bucks. Right in my budget LOL
AIR #005
retired!
Old 09-06-2011, 03:39 PM   #268
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
question- My trailer has that wheel on the front, that rolls the tongue around. It will sometimes hit the ground on an exit or entry with a dip, but rolls when it does.
Anyway it will not come off...have not tried a torch yet but so far with any other method it ain't budging.
What do those of you that have one of these do? Take it off when not needed. Leave it on all time?
AIR #005
retired!
Old 09-08-2011, 08:56 PM   #269
Central , Mississippi
I've never seen one that wouldn't come off. To install a new jack, the wheel would have to be removed just to get off the old jack, right?
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie(RIP) -
A honkin' long 34' named AlumaTherapy https://www.airforums.com/forums/f20...num-54749.html
and a 26' '63 Overlander, Dolly https://www.airforums.com/forums/f10...ome-71609.html
Old 09-17-2011, 08:38 AM   #270
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
It may take a torch to get it hot enough to remove, I tried a few days soak with blaster it did not budge..
On another note, got the lower trim molding striped. My usual black and burgundy red GA Dawgs color.
Also I opened up the panel under the belly pan for the umbilical tie in, cleaned everything in there with electrical spray cleaner and my light seem to work way better.
Gearing up for a short weekend in Chattanooga before we do Falluminum in N Ga.
AIR #005
retired!
Old 12-10-2011, 11:57 AM   #271
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Power Inlet
Finally got the outside power inlet I have wanted. Got it on last Sunday, and looking forward to not having to pull the cable through that fake sewer hose deal these old 66s have. Next comes the water inlet.
AIR #005
retired!
Old 02-23-2012, 07:54 PM   #272
Jimbcole's Avatar
1958 17' Pacer
Tryon , North Carolina
Where did you purchase your Hubbell power inlet? Can you tell me the distance the inlet is behind the mounting plate? I can't find that measurement on their website. Thanks!
Jimbcole is offline   Reply With Quote
Old 02-24-2012, 03:00 PM   #273
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
I got it on EBAY. Not sure of the distance but no problem mounting it at all. Borrowed the hole saw from a friend.Cut my old power cable and wired it right up. Got the inlet cable on the bay too another day.
AIR #005
retired!
Old 02-24-2012, 08:58 PM   #274
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
Vintage Trailer Supply sells a power receptacle. I plan on getting one from them.
Dan
Old 02-24-2012, 11:09 PM   #275
Jimbcole's Avatar
1958 17' Pacer
Dan
Yes they do. The VTS-660. But it says the depth behind the mounting flange is 2.2 inches. The Hubbell 50 amp says 1.4 inches. That is all the room I have. I can't find any specification on the 30 amp. I'd rather have the 30 amp if it is short enough.
Old 03-03-2012, 02:24 PM   #276
1966 26' Overlander
Owensboro , Kentucky
1966 Overlander
We just purchased our 1966 Overlander today. We are excited to get started on the restoration!
Hunterz is offline   Reply With Quote
Old 03-03-2012, 02:29 PM   #277
Unless the coach is garaged, the first step is to make it waterproof, using gaskets, sealers, etc.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 03-03-2012, 03:31 PM   #278
Lothlorian's Avatar
Loganville , Georgia
That is the power reciptical I put on the 1960. I built my own power cord. I got the parts at Lowe's
Brian
Brian & Adrienne
Lothlorian is offline   Reply With Quote
Old 03-04-2012, 03:47 PM   #279
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
I used my newly found Hitachi Polisher today with the black emery bar on some difficult corrosion. Looks like some progress on that finally. I hope to get more done when it warms back up some. Then the Cyclo will come back out.
AIR #005
retired!
Old 03-30-2012, 05:54 PM   #280
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Corrosion is a bear!
Been working this area and it looks better, but will it ever be free from that filliform?
I am guessing I would have to go too deep into the aluminum. Using that emery bar and cotton buff.
It will shine and look fine from 10' or more though.
AIR #005
retired!
1966, 1966 overlander, bunk bed
A/C for 1966 Ambassador law1966 Member Introductions 1 07-24-2011 09:24 PM
1966 airstream eBay Watch Airstreams on eBay 0 03-26-2010 06:40 AM
1966 airstream eBay Watch Airstreams on eBay 0 03-19-2010 06:10 AM
1966 airstream eBay Watch Airstreams on eBay 0 03-01-2010 07:30 PM
1966 TradeWind 66TradeWind 1959-69 Tradewind 2 03-18-2002 07:09 AM
