Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 12-29-2019, 12:53 PM   #721
Airstream Driver
PeterH-350LE's Avatar
1994 30' Excella
1992 35' Airstream 350
Images: 49
Originally Posted by PeterH-Airstreamer View Post
Thanks, Bob!
Also found floor rot along the floor channel on the rear street side just forward of the fuel inlet. I checked all adjacent water lines and they appear to be fine. Must be an external issue related to the long awning draining down the side. Unless I have some toilet supply issue buried in the cabinet.
Found suspect gap on the bottom rub rail, applied some pigment and hosed it down, voila found it. Massive water intrusion due to Airstreams brilliance of overlapping the wraps over the skin. So all the lower rub rail is suspect. For the time being in will Tempro 635 to seal the top of the rubrail, until time allows to pull it all off and seal the gap under the rub rail
ID:	358333   Click image for larger version
AIR #13
PeterH-350LE is offline   Reply With Quote
Old 12-29-2019, 05:10 PM   #722
Airstream Driver
1994 30' Excella
Images: 49
Any suggestions on what type of fuel filter I could add by tank. I think the only 2 filters currently used may be the internal tank filter (i am guessing) and the very fine mesh at the injectors.
I am also contemplating to add a secondary high pressure fuel pump, that could be used in emergency or demand situations. Is there such a thing as a high pressure non restrictive flow through fuel pump?
AIR #13
Old 12-29-2019, 05:36 PM   #723
Waipio Rim's Avatar
1984 31' Airstream310
Honokaa , Hawaii
Our ‘90 345 has one of these:
https://www.amazon.com/gp/offer-list...&condition=all
mounted near the tank. Apparently pretty common, the NAPA store in Juneau, AK had a replacement cartridge for it sitting on the shelf a few months ago.
Waipio Rim is offline   Reply With Quote
Old 12-30-2019, 04:58 PM   #724
Airstream engineering at it's finest.....
1975 24' Argosy Motor Home
Old 12-30-2019, 05:02 PM   #725
I used the same filter on my Argosy just prior to the Carter suction pump.
Old 12-30-2019, 05:04 PM   #726
The only issue I can think of that might be a problem is fuel injection systems are pretty picky about the pressure supply. It would sure be interesting to find out if you could add a second pump.
The only other thought is if the in-tank pump dies would an external pump be able to pull fuel through the dead in-tank pump?
Old 12-30-2019, 06:48 PM   #727
Airstream Driver
1994 30' Excella
Images: 49
I happen to have the old in-tank pump on hand and yes it allows fuel to be pulled through when it is non operational. It does have a check valve.
So just for grins, I will install the external Facet pump controlled by a switch, as well as temporarily connect the internal to a switch as well. Then I can test all of the scenarios.
I will report back on this in a few weeks.
ID:	358406   Click image for larger version
AIR #13
Old 01-01-2020, 04:24 PM   #728
Airstream Driver
1994 30' Excella
Images: 49
Happy 2020 everyone! Out with the old (sold my 1991 25') and in with the new. Finally was able to move the 350 under cover
ID:	358470   Click image for larger version
AIR #13
Old 01-02-2020, 07:03 PM   #729
Airstream Driver
1994 30' Excella
Images: 49
Completed one of the many systems today. The onboard fresh water system is fully operational, no leaks after replacing leaky and questionable fittings. Auto fill works, external works. Just need to source a new pump for the "DesertCooler" radiator mister. Previous owner installed a huge accumulator tank that will feed the system for a good while before pressure needs to be added by the onboard water pump.
ID:	358540   Click image for larger version
AIR #13
Old 01-02-2020, 07:15 PM   #730
Kid's and their toys.....
Old 01-03-2020, 03:09 PM   #731
Airstream Driver
1994 30' Excella
Images: 49
Found this close to the tank, old secondary fuel pump remnants?
AIR #13
Old 01-03-2020, 03:13 PM   #732
I think that's part of a leveling system. I found something like that on the 345 when I was taking it apart.
Who knows, I might even have it laying around in a box somewhere.
Old 01-04-2020, 10:21 AM   #733
1986 34.5' Airstream 345
Alliance , Ohio
I second Brad's response. It contains some mercury filled level switches that
tell you when you are level.
mehes is offline   Reply With Quote
Old 01-04-2020, 06:09 PM   #734
Airstream Driver
1994 30' Excella
Images: 49
Thanks, I think all I have is the base of the original unit.
On other news, we dropped the tank today (thanks Tony for the pump trick, it helped a lot to get 70 gals of fuel out)
I also found a fuel filter on the rail which must have been original to 1992, look at the crud
ID:	358649   Click image for larger version
AIR #13
Old 01-04-2020, 06:28 PM   #735
Looks like muddy red water!
Old 01-04-2020, 07:47 PM   #736
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
Two questions, is that a centramatic between the duals? I thought they fit behind the wheels not between them. Also I noticed your two different styles of ramp construction, do you prefer one over the other and why? Thanks
Cheers, Dan
~ Margaret Thatcher ~
Old 01-04-2020, 07:58 PM   #737
Airstream Driver
1994 30' Excella
Images: 49
Than I found this mess, modified fuel supply lines and the generator fuel line just dangling above the tank. Thanks Brad for your feedback this pm and offering a possible solution!!
AIR #13
Old 01-04-2020, 08:07 PM   #738
Airstream Driver
1994 30' Excella
Images: 49
Dan,
On the drive axle, they can only go in between the wheels. They do have slots for valve extenders. On the Tag the same type is mounted on the drum.
The first set of ramps on the left, I built 20 years ago when I was working on my 79. They are strong but showed wear and cracking. I decided to make the new set solid wood all the way. 5 2x10's @$6.- ea sure made it a worthwhile investment. Safety first!! Still was scary to drive the rig up those ramps.
In case anyone is interested, i am using 9" heights on the ramps, to clear the tank with a floorjack. And this is without the use of the airbags for 2 reasons, one is safety the other is that they deflate once you raise the drive axle and let the tag float.
AIR #13
Old 01-05-2020, 03:06 AM   #739
Dan,
Thanks, I use dyna-beads and have never seen centramatics mounted so it just looked a little strange.
That makes sense, I use planks myself but I don't have the fancy bevels. Mine have a lot more dirt and grease on them too.
Cheers, Dan
Old 01-05-2020, 07:57 AM   #740
Airstream Driver
1994 30' Excella
Images: 49
this 350 has a huge onboard compressor and it is mounted in an metal enclosure underneath the vehicle. It was running continuously, so I had to track down the leak. I finally found an inline check valve at the compressor to have a crack.
ID:	358675   Click image for larger version
AIR #13
Need a new gear/sprocket for a Reese lector-jacket! Ribbler Towing, Tow Vehicles & Hitches 4 06-03-2013 11:45 AM
Vintage Airstream jacket eBay Watch Airstreams on eBay 0 02-09-2012 11:10 AM
Bypass TBI water jacket???? Taxman General Motorhome Topics 8 06-15-2007 04:20 PM
motorhome jacket ALANSD Airstream Motorhome Forums 4 12-09-2002 04:58 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
