Old 02-28-2021, 11:39 PM   #1
knight-rider
2021 20' Basecamp
Hillsboro , Oregon
Why would a brand new BC 20X black tank flush clog?
We just got our new shiny BC 20X. It's one beautiful trailer. I might post a separate review on all the pros and some nit pick cons. There are so many things that Airstream has done really well.
I do have one minor glitch - the black tank flush is not letting water inside the tank. I tried everything (increased water pressure; kept the water knob open for several mins; towed with full tank to clear the inside nozzles, etc. but nothing worked). I don't want to blow air, because I don't know how delicate the inside nozzles are structured. The unit is an out of state delivery. I should have checked this feature when I got the delivery. We checked everything except this feature. I'm not too worried because there is warranty.
I can understand if this happened on older units. The inside nozzles might get blocked with periodic build ups. But why would this happen in a new unit delivered directly from factory few days ago? How did the quality checks miss this issue? Black tank flush system is a new feature added in BC 20 models. So it's a bit disappointing to see this feature not working.
Any suggestions I could try before I loop the service crew and invoke warranty? Appreciate any pointers. Thanks!
knight-rider is offline   Reply With Quote
Old 03-01-2021, 02:16 AM   #2
SeaLevel's Avatar
2016 25' Flying Cloud
Jupiter , Florida
Why is difficult to answer. Installed wrong? Faulty part?
I would just let it be handled under warranty. Maybe wait a bit to see if anything else comes up so you can get everything handled at one time.
"A good traveler has no fixed plans, and is not intent on arriving." - Lao Tzu
SeaLevel is offline   Reply With Quote
Old 03-01-2021, 02:20 AM   #3
Long Island , New York
Sorry for your troubles. Good research IMO.
Air pressure at 30 PSI should not hurt anything IMO, and you should be able to hear the air escaping from the spray nozzles on the top of the black water tank. [with the trailer and surroundings very quiet -- which includes the compressor being off]
Guessing a plumbing error, or a defective anti-siphon vacuum-breaker valve?
https://www.google.com/search?q=blac...=airforums.com
"Quality checks?" . . . . . . see here . . . good company.
Ditto to last comment to let a dealer check under warranty after further investigation per above.
Good luck.
Let the music lift you up . . .
Have a little pun in life . . .
Peter
OTRA15 is online now   Reply With Quote
Old 03-01-2021, 09:18 AM   #4
Airstream Ambassador
AirstreamInc's Avatar
Jackson Center , Ohio
Hi knight-rider,*
Congrats on your new Airstream! We're very sorry to learn about the issue you are having. Please send us a direct message with your contact information, email and the last 6 digits of your VIN so we can share it with our Customer Service and Technical Support team. We look forward to helping you get this resolved.
You can also reach Airstream Customer Service and Technical Support at*customersupport@airstream.com
Thank you.*
Official account for Airstream, Inc.
Airstream Customer Service and Technical Support can be reached at 1 (877) 596-6111, option 1.
AirstreamInc is offline   Reply With Quote
Old 03-01-2021, 09:21 AM   #5
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
If you can find it I’m with Peter re: possible reversed back flow preventer install.
Try to find it and get pic of it.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Dexter 4 Piston Disc Brakes, Carslile Actuator, Equal-I-Zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 03-01-2021, 09:13 PM   #6
DBWJLW
2021 20' Basecamp
Tulsa , OK
We just got a BC20X in January and the SAME thing happened with ours. It's currently at the dealer waiting on warranty/part. They said the black flush valve was "faulty".
DBWJLW is offline   Reply With Quote
Old 03-02-2021, 12:26 AM   #7
Thank you for that report, and welcome to the forum. When you get the details of the repair, and the parts removed/installed, please update us. Our new 2014 FC20 came with a defective valve, and the dealer sent us a new brass version, because we were not able to get back there for a warranty repair. The new brass valve is sitting on a shelf above the bed, because this part is in a hard-to-reach location.
If there is a 2021 Basecamp 20X fleet-wide problem, it would be good to let everyone here know IMO.
Thanks.
Peter
Old 03-02-2021, 12:31 AM   #8
Originally Posted by AirstreamInc View Post
Hi knight-rider,*
Thank you.*
Per the recent Post #6, is this a 2021 BC20X fleet-wide problem?
Thanks.
Peter
Old 03-02-2021, 11:11 AM   #9
kgottleib's Avatar
2021 20' Basecamp
South Easton , MA
ouch! this is a thread I will be following... I have a basecamp 20x on order now.. keep us informed please
kgottleib is offline   Reply With Quote
Old 03-03-2021, 10:15 PM   #10
knight-rider
2021 20' Basecamp
Hillsboro , Oregon
Thanks everyone for your inputs.
Hi knight-rider,*
Thank you.*
Thanks AirstreamInc. We contacted the customer support as per your request. Looking forward to getting this issue resolved.
DBWJLW, sorry to hear that you faced the same problem. Please keep us posted.
Old 03-22-2021, 01:23 PM   #11
DBWJLW
2021 20' Basecamp
Tulsa , OK
Dealer confirmed the valve was faulty. They didn't say it was installed wrong or backwards, just "faulty". They are replacing now. They also said the winterization kit was sucking antifreeze into the fresh water tank and not through the pipes. Yikes! They are placing that as well.
Old 03-29-2021, 07:36 AM   #12
2021 20' Basecamp
Lafayette , Colorado
Easy fix. Drive side cabinet, behind bathroom, open the door, take out 4 screws (covered in white). Remove back panel of cabinet. Just over the wheel well is an anti-siphon valve that protects the black tank line. They have also added a check valve, it is a grey 2" 1/2" part coming off the right side of the anti-siphon valve. This check valve is most likely backward. Mine was. Unscrew the bottom of the anti-siphon and check valve, unscrew check valve. Flip so arrow goes the way the water should flow, into tank.... re-install.
Mtstarr1 is offline   Reply With Quote
Old 04-01-2021, 12:22 AM   #13
knight-rider
2021 20' Basecamp
Hillsboro , Oregon
Thanks for keeping us posted. I'm glad it's getting fixed, along with the winterization kit.
Wow! Thanks so much for the tips. I'll try this out tomorrow. I hope it's the same issue with my unit as well. By any chance, do you have a picture of the correctly installed valve? Appreciate your help. Thanks!
Old 04-04-2021, 11:32 AM   #14
2021 20' Basecamp
Westlake Vlg , CA
Thank you very much for the post and replies. Found it last night when doing a pre-first trip trial of the various systems and realized the inlet would not add water to the black tank. Our trip will start with a detour to our dealer to flip the valve. I was not confident after opening the panel per Mtstarr1's instructions that I'd get it right without assistance from the service folks but at least now I know exactly what to tell them to do! I will also have them show me where it is and what's what behind the panel.
the eagle is offline   Reply With Quote
Old 04-04-2021, 06:45 PM   #15
2021 20' Basecamp
Westlake Vlg , CA
photos of check valve repair
Okay, so I went from not knowing we had a problem with the black tank inlet until last night and not even knowing what a check valve was, to replacing it this afternoon myself without having to see the dealer. Here are some photos for anyone considering doing it yourself.
It's the gray plastic piece in the upper left of the close up photo. It was installed with the arrow facing the wrong way. I unscrewed both ends, flipped it, added some plumber's tape and screwed it back in. That's it. This is the panel immediately to the left of the bathroom, lowest level. Good luck and thank you to all who posted here!
Name:	check valve repair wide view.jpg
ID:	392390   Click image for larger version
Name:	check valve repair.jpg
Old 04-08-2021, 10:58 PM   #16
knight-rider
2021 20' Basecamp
Hillsboro , Oregon
thanks for sharing pictures
Thanks for sharing the pictures. Did you replace it or just flipped the direction of the valve? If you replaced it, did you order the part from the dealership or picked from a local store?
Old 04-09-2021, 07:51 AM   #17
2021 20' Basecamp
Westlake Vlg , CA
I just flipped the existing valve. It’s been working just fine since then.
Old 04-11-2021, 12:51 PM   #18
knight-rider
2021 20' Basecamp
Hillsboro , Oregon
I had the same problem! I flipped the valve and everything is working now. Thanks to you guys - you saved me a trip to dealership. This forum rocks!!
New Black Tank thinking about adding a black tank flush Peter417 Waste Systems, Tanks & Totes 1 12-21-2020 10:18 AM
Brand new !!!15x6 6 lug trailer wheels/tires black inlay!!! Brand new John Nelson Airstream Classifieds 0 06-04-2020 10:57 AM
Black Tank Clog PaulG_4307 Waste Systems, Tanks & Totes 9 01-13-2017 09:26 AM
Black Water Tank Clog, I think... kstewart23 Waste Systems, Tanks & Totes 19 01-09-2017 12:23 PM
black tank flush clog jump Waste Systems, Tanks & Totes 1 03-20-2015 10:15 AM
