Old 09-06-2020, 07:36 AM   #1101
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Very nice indeed !!!!
Old 09-06-2020, 07:49 PM   #1102
2018 27' Globetrotter
Mooresville , North Carolina
This says it all.
2018 GMC Sierra 2500HD Duramax
Equal-I-zer Weight Distribution attached to the Gen-Y Torsion Flex Weight Distribution Hitch
"Roadrunner"
GOUSC is offline   Reply With Quote
Old 09-06-2020, 08:07 PM   #1103
chris_kelly's Avatar
2021 25' Globetrotter
Somewhere , Texas
Originally Posted by GOUSC View Post
This says it all.
Totally.
What about helping the self installer?
chris_kelly is offline   Reply With Quote
Old 09-06-2020, 08:17 PM   #1104
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
Originally Posted by chris_kelly View Post
Totally.
I do my part when I can.....
Instagram @Airstream_Nuts_And_Bolts
DoItYourselfRV Articles
Certified Victron Installer
Old 09-12-2020, 06:53 PM   #1105
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Stepping up the Game
Build a jig and worked out the fine details to be able to make copper buss bar battery interconnects.
1/4” x 1” silver plated (not tinned) Oxygen free copper.
3/8” holes punched nut drilled for precise holes.
They are rated at 500A and can be made for 2,3,4,5,6........ battery.
Work super well for the BattleBorn GC2’s.
ID:	378385   Click image for larger version
ID:	378387   Click image for larger version
ID:	378389   Click image for larger version
ID:	378391   Click image for larger version
ID:	378393   Click image for larger version
Old 09-12-2020, 10:05 PM   #1106
2007 22' International CCD
Nicely done. You should consider making and selling kits for this setup!
Old 09-14-2020, 09:52 PM   #1107
Solar Show and Tell
Either that, or I’m going to have to move BACK to Alabama to get some of this good stuff from you directly.
Old 09-19-2020, 02:29 AM   #1108
Atomic_13's Avatar
1968 24' Tradewind
1968 26' Overlander
Detroit , Michigan
Agreed! That is some high quality craftsmanship. Nice job, Ronnie.
Brian's AS renovation:
https://www.airforums.com/forums/f11...on-134984.html
Tow vehicle: 2019 F250 Lariat 6.7L CC SRW
Atomic_13 is offline   Reply With Quote
Old 09-20-2020, 12:55 PM   #1109
Potential Safety Issue
This thread has been a great resource for solar installs in our Airstreams. I recently upgraded my factory solar controller to the Victron MPPT 100/30 along with a Victron Battery Sensor, Solar Cut-off switch and a 40 Amp breaker. The potential safety issue I ran into relates to the 40 Amp breaker. I purchased most of these parts from AM Solar.
I want to stress that I am by no means an electrical expert. I followed some of the pictures and narratives in this thread to determine how to connect some of the components. I also referred to the AM Solar diagram on their website since I purchased the parts from them. As noted earlier, I also referred to contacts on this forum that are knowledgeable in this area. The OP and I are in disagreement over whether this is a safety issue or not. I just wanted to post this information so that others can make their own informed decision when wiring the breaker.
The 40 Amp breaker has 2 connecting posts. The one on the left is labeled “line”. The one on the right is labeled “load”. Post #136 in this thread has a collage of 8 pictures of the OP’s equipment and connections for their 400W system. If you look at the bottom row, 3rd picture from the left I could see that the studs are labelled “line” and “load”. The top stud in the picture is labeled “load” on the black paint of the breaker. This connection goes to the MPPT. This would then have the stud labeled “line” going to the batteries. I initially wired mine up the same way as the OP.
Prior to connecting the power, I referred to the AM Solar diagram for the connections. I noticed their connections were different. They have the “line” stud connected to the MPPT and the “load” connection going to the batteries.
I reached out to AM Solar to confirm the connection in their diagram. They confirmed what their diagram displayed and believe that is the correct way to install the breaker.
I reached out to the OP, who posted the pictures to determine if he had anything to confirm his connections as I perceived this to be a safety issue. Below is his response;
“Ok I looked into this issue myself. From what I read it doesn’t make any difference. I looked at the specifications and there’s no line or load indication. Both my terminals are silver so that’s no indication. I didn’t crawl under my bed inside my storage compartment to see if my breaker is labeled line and load. I’m just going to leave mine wired the way it is, backwards from the AmSolar diagram. If there is a short or overload, I’m certain the breaker will perform its job. Thanks for bringing this to my attention.”
I had a few more private messages with the OP in an attempt to see if he could provide some additional clarification. Having received none, I wanted to provide clarification here.
I did some research regarding “line” and “load” with regard to breakers and they all stated the “line” side should be where the power is coming from and the “load” side is where the power is going to. AM Solar confirmed the same. The power is coming from the solar panels and going to the batteries. Based on that, the MPPT is the “line” side and passes this power to the “load”, the batteries.
Below is link to an article which also spells this out very well. It also notes reversing polarity would result in safety issues and irreversible damage. I wanted to make sure this information is included in this thread so anyone can make their own decisions in connecting their breaker.
https://www.quisure.com/blog/faq/com...rcuit-breakers
Item #5 in this article is the critical one to me.
5. Are DC circuit breakers directional?
Direct currents flow has one and one only ‘unidirectional’ flow of electrical charge one a constant direction, e.g. batteries or solar cells so the DC circuit breaker must respect that one direction charge. Reversing polarity would result in safety issues and irreversible damage. DC circuit breakers must be built to maintain arc voltage that will interrupt the current, at low currents. DC currents are constant currents, while AC is sinusoidal current.
The above is consistent with what AM Solar posts on their website regarding the use of this breaker.
Name:	Post 136 Pic.jpg
ID:	379091   Click image for larger version
Name:	AM Solar wiring set up used.jpg
"Roadrunner"
Old 09-21-2020, 12:01 PM   #1110
Peoria , Arizona
Some additional updates
Made some additional updates to my install:
Added 3 cut off switches and relocated tongue jack (lever) breaker in the shallow cabinet under the small portion of the L lounge.
Included a pic of the factory panel cut out also located under the lounge seat which is where the 12V wiring panel was relocated. Added wiring labels.
Thanks again to the OP for the inspiration!
ID:	379207   Click image for larger version
ID:	379209   Click image for larger version
ID:	379211   Click image for larger version
'24 Silverado 2500 Diesel 4x4 ZR2, 2018 FC 28W (Queen) Landmark Truffle, ProPride Hitch, 3" Dexter Lift, Centramatics
kb7our is offline   Reply With Quote
Old 09-23-2020, 08:17 PM   #1111
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
More buss bar shenanigans. Twisting bar stock to change post orientation.
Note the opposite twist on each side (1) clockwise (1) counter clockwise to add a little Wham-Pow! to the install.
ID:	379374   Click image for larger version
ID:	379376   Click image for larger version
Old 09-23-2020, 09:53 PM   #1112
waninae39's Avatar
2022 25' Flying Cloud
NCR , Ontario
I have similar red shut off switches.
3, one each fir solar panel, battery and front jack
My switches have pull out handles to allow them to be "locked in".
I mounted them on the rear of the panel, drill a hole for the key.
Now just the keys appear and hide the switches, this allow easy access in shut off the jack when we camp.
I'll try to post a photo soon as inet is limited where we are camping now
Name:	2020-09-23 23.58.02.jpg
waninae39 is offline   Reply With Quote
Old 09-23-2020, 09:55 PM   #1113
Solar Show and Tell
Ronnie, you are definitely a charter member of the Overkill Engineering Department! Looks super clever, and I love the symmetry that gives. [emoji1360]
I bet it took a fair amount of force to get that twist just right?
Old 09-24-2020, 12:33 AM   #1114
gregwall's Avatar
2014 25' FB Flying Cloud
2005 30' Classic
Keswick , Virginia
You are a true craftsman! Too cool!
Greg
2014 25' Flying Cloud FB
2015 GMC Sierra Denali 6.6L diesel
Charlottesville, Virginia
gregwall is offline   Reply With Quote
Old 09-24-2020, 05:50 AM   #1115
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Currently I’m using a large benchTop vise with aluminum jaw covers and a huge crescent wrench.
I working on building a tool I will call “The Buss Bar Bender”. Details to follow.....
Old 09-24-2020, 08:48 AM   #1116
Nothing quite as handy as big tools when it comes to doing stuff like this. I’ve worked a couple projects where, if they didn’t have the right tool to break things, they had a complete machine shop and welding equipment to make an appropriate tool to break whatever they wanted.
Old 09-24-2020, 07:25 PM   #1117
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
DC distribution board for our 30’ GT is complete!
ID:	379429   Click image for larger version
ID:	379431   Click image for larger version
Old 09-24-2020, 07:47 PM   #1118
Carmel , Indiana
Any chance we can get an outline of what your doing and trying to accomplish? The workmanship looks incredible.
Mike46032 is offline   Reply With Quote
Old 09-24-2020, 08:23 PM   #1119
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Mike,
My project is our 2020 30’ GT. I am a solar installer that is going outside of my normal Victron systems to experiment with some new products.
The install will consist of the following
1000 watts of Zamp Obsidian prototype high voltage panels. (25 volts each) (10)100watt panels ran in 5 pairs.
MasterVolt components, including
(2) MLI Ultra 12/5500 400Ah batteries (800Ah total)
MasterVolt 5000 watt 160A inverter/charger
MasterVolt Mac plus 50A DC/DC Charger
MasterVolt MPPT 60A Charger
(2) MasterVolt Easy View 5 monitors
All BlueSea Systems fuses, switches, and other toys
So basically it’s a 800Ah battery, 5000 watt Inverter, 1Kw Solar install. Pretty big system for an Airstream.....
Old 09-24-2020, 09:47 PM   #1120
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Solar Show and Tell
Curious as to why you decided to go with a mastervolt stack? Looks like good stuff btw...
500A blue sea. Smart. I melted a 300A version running the air con for long durations in my system and then had to upgrade
wulfraat is offline   Reply With Quote
I'll Show You My Dent If You Show Me Yours! Rubyslipper Ribs, Skins & Rivets 42 12-22-2016 07:10 AM
If you show me yours, I'll show you mine... SKEETER 1993 Excella 1000 38 01-08-2008 11:01 PM
Show and tell (thinking caps) rebel beck Off Topic Forum 5 08-16-2006 06:21 PM
Cyber finds - show and tell Janet H Off Topic Forum 6 04-01-2006 05:39 PM
I'll Show you Mine If you'll show Me yours... joossens Link Archive 0 05-12-2004 12:51 AM
