RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 10-06-2020, 09:50 AM   #1141
daleyocum's Avatar
2018 25' Flying Cloud
Portland , Oregon
Originally Posted by kpm View Post
My proposed location for the 6th panel is on the driver side, roughly between the refrigerator vent and the shower fan. On your trailer, it looks like you have a some kind of wire going down the refrigerator vent (cell booster antenna?) but I suspect there would still be room there. Your solar combiner box and feed through the roof is on the opposite (passenger) side, right?
Sorry I was turned around and didn't realize which side you were on. Yes in my case I put a cell booster cable glad there but if it works for you that would be exciting! A tight fit for sure.
daleyocum is online now   Reply With Quote
Old 10-25-2020, 08:56 PM   #1142
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
1000 Watts!
Ok guys...... 1000 Watts install on our 30’ GT.
ID:	381790   Click image for larger version
ID:	381792   Click image for larger version
ID:	381794   Click image for larger version
ID:	381796   Click image for larger version
Old 10-25-2020, 09:49 PM   #1143
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Nice.
wulfraat is offline   Reply With Quote
Old 10-25-2020, 11:00 PM   #1144
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Originally Posted by wulfraat View Post
Nice.
Old 10-26-2020, 05:52 AM   #1145
gregwall's Avatar
2014 25' FB Flying Cloud
2005 30' Classic
Keswick , Virginia
Oh my goodness!
Greg
2014 25' Flying Cloud FB
2015 GMC Sierra Denali 6.6L diesel
Charlottesville, Virginia
gregwall is offline   Reply With Quote
Old 10-26-2020, 05:55 AM   #1146
Acheron2010's Avatar
2019 26' Flying Cloud
Morristown , Tennessee
Jellie - can you tell us the rest? Batteries, controllers, what size city you can power?
2015 Chevrolet Silverado 2500
2019 Airstream Flying Cloud 26RBQ
WBCCI #6679
Acheron2010 is offline   Reply With Quote
Old 10-26-2020, 07:01 AM   #1147
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Haha,
Sure! First I am a Victron certified installer, but I am trying a new system. All the components in my system are MasterVolt except the panels and they are Zamp. List of components below.
(2) MLI Ultra 12/5500 400Ah Lithium batteries (total bank 800)
Mac Plus 50A DC/DC Charger
CombiMaster 12/3000-160 Inverter Charger soon to be swapped out for their 5000W 50A unit coming out in January.
SCM60 MPPT Solar Charger
(2) Easy View 5 monitors.
MasterBus DC distribution 500
All of these components are connected in series to a MasterBus network allowing complete control and monitoring of the system.
Each battery has a built in shunt to monitor energy in and out of the system.
Each charging source can and does communicate with the system batteries and other chargers to optimize there function and prioritize the charge based of available charge sources (Sun first- truck second-shore power third)
It’s a great system with a clean lay out.
ID:	381837   Click image for larger version
ID:	381839   Click image for larger version
Old 10-26-2020, 07:39 AM   #1148
DaveP's Avatar
2004 28' Classic
Monument , Colorado
Wow!! Second the jellie!
DaveP
2004 Airstream Classic 28 "Willard"
2014 Ford F150 FX4 Ecoboost
DaveP is offline   Reply With Quote
Old 10-27-2020, 07:29 AM   #1149
Half a Rivet Short
Carlisle , Pennsylvania
Crazy !!!!
Old 10-27-2020, 12:32 PM   #1150
Wolfwhistle
Fair_Enough's Avatar
Margaritaville , Banana Republic
GMFL, easily the best and nicest install yet. Awesome! Question: your panels that are next to a/c units; do you know the sun’s angle that would adversely affect production due to shading? I assume those on one of the sides are in series to lessen the likelihood of being “taking out” by shading? I had considered placing Renogy Eclipse - these are the 32 cell smaller ones - beside the a/c unit (singular) but was concerned that one or the other would not produce much of the time. I recently added 2 more (500 now) That is pushing the 30 ampere capacity of the controller, but still okay. It’s hard to get an even number of panels on the 23FB required for series-parallel but one next to the a/c would do it. Of course If I could, I would have to go with an MPPT or a 24v bank and keep the Trimetric equipment. Thoughts?
FE
Fair_Enough is offline   Reply With Quote
Old 10-27-2020, 01:21 PM   #1151
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
FE
Photo below shows my series pairs. Low sun angle does cause shadows/shading but I think that’s just the game we have to play. ( And yes, I do realize pair 5 is less than ideal but again I’ve got 1000W on the roof)
“Modern” panels are not as affected by partial shading as much as older panels were.
The MPPT chargers really take advantage of higher voltage so keeping the voltage high helps the charger alway produce at its peak.
Right now my system is pushing just north of 50A under cloudy sky’s because the series pairs are still running at 39V. Under peak conditions these panels should produce 42VDC.
Changing to an MPPT Charger should make a HUGE difference in how your panels perform weather they are all parallel or series/parallel.
Old 10-27-2020, 01:24 PM   #1152
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Crazy !!!!
BOB,
From you that means the world to me!
Old 10-27-2020, 07:08 PM   #1153
Wolfwhistle
Thank you!
The CTC (converted cargo trailer) has 600w (3-200 Hightech Solar - 21 VMP; 9.5 IMP... and an Epever 40A MPPT. Programming via MT-50. I must have had something set wrong that I might have corrected. did a factory reset and changed just the minimum under "User" settings. (Max charge to 14.6, turned off Equalize, set bank to 170Ah, Boost to 14.6, Overvolt disconnect to 14.8, Absorb time to 10 minutes, left Float at 13.8) and clicked save.
My $40 Battery monitor was showing 100%, so I turned on the roof a/c - 9200 Coleman Cub (100A load); soon it popped up to 14.1v and climbing ... amps were low since it was quite cloudy. Didn't stick around, had other things to do, but hopefully it is fixed.
Have you tried this: I initially connected the CTC panels in series. I saw .4A charge under a street light and something like .3A under a full moon. I told someone this and they said "there is no way".
I also found out that 66v (no load) will make you hurt yourself and say things that you will be sorry for later. Maybe not you. Note to self, cover up those panels when working with their wiring.
FE
Is taking it all with you, really getting away from it all?
Old 11-05-2020, 02:20 PM   #1154
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Just finished another one. 600Ah with 600Watts and a 200Watt suitcase. 3000 watt Victron suite.
ID:	382618   Click image for larger version
ID:	382620   Click image for larger version
Old 11-07-2020, 04:50 PM   #1155
2021 27' International
Prosper , Texas
Wow. What a great looking install. Ronnie has to be the best installer.
Octane1 is offline   Reply With Quote
Old 11-07-2020, 07:23 PM   #1156
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Haha. I don’t know about the best, but I do try to be neat.
Old 11-14-2020, 09:42 PM   #1157
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Here’s this weeks install. 900Ah 10.8KWh! 800 watts of solar but did not get a photo because we were putting them on after dark.
ID:	383255   Click image for larger version
ID:	383257   Click image for larger version
Old 11-15-2020, 04:48 PM   #1158
Wolfwhistle
You are working too hard, young man.
Old 11-17-2020, 09:27 PM   #1159
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Here’s the next one...
ID:	383448   Click image for larger version
ID:	383450   Click image for larger version
Old 11-18-2020, 09:19 AM   #1160
batman's Avatar
1964 22' Safari
modesto , California
GMFL, Super clean work! I love the flat cable/buss on the last install. I assume you made it. Where do you get it? What kind of crimp tool do you use for that?
batman is offline   Reply With Quote
I'll Show You My Dent If You Show Me Yours! Rubyslipper Ribs, Skins & Rivets 42 12-22-2016 08:10 AM
If you show me yours, I'll show you mine... SKEETER 1993 Excella 1000 38 01-09-2008 12:01 AM
Show and tell (thinking caps) rebel beck Off Topic Forum 5 08-16-2006 07:21 PM
Cyber finds - show and tell Janet H Off Topic Forum 6 04-01-2006 06:39 PM
I'll Show you Mine If you'll show Me yours... joossens Link Archive 0 05-12-2004 01:51 AM
