Dometic Thermostat Error Code 7
Hello. I recently had a lithium battery upgrade. I am now on my first road trip, now in Eastern Washington and it is HOT as blazes🔥. When I turn on the Dometic thermostat to turn on the air conditioners. I get "Error Code 7", and they won't turn on.
I googled this error code and the recommended fix is to disconnect, shut down all power. Then check all the fuses, for both the 50 amp and the two 20 amp fuses for both AC's.
Confirming that yes, I am hooked up to 50 AMP power.
Confirming also that I also did the System Reset/Error Code.
Any ideas or suggestions most welcomed..
BogeyPro
Seattle, Wa
2024 International 23' Twin
2021 Ford F-150 XLT 4x2 Powerboost
