10-07-2019, 08:12 AM
2019 22' Sport
Bend
, Oregon
How the heck to install a camco winterizing kit
I understand that the Camco winterizing three-way valve needs to be installed on the inlet side of the pump. I also understand these are popular upgrades amongst those living in the frozen north/interior.
What I don’t understand is how in the world people access and install these valves. See pic of my pump, which seems to be buried deeply under the refrigerator and accessed from under the closet. Sandwiched among the ducting and wiring rats nest (Sport 22FB).
Perhaps there is a trick or access panel I’m not aware of?
Also, is there a simple way to know which side of the pump is the inlet (vs the outlet?). I’m used to inlet being centered in the axis of the main body, and outlet being perpendicular and “above”.
10-07-2019, 08:20 AM
1995 25' Excella
xxxxx
, xxxxxx
That looks nearly impossible to put a kit on.
Mine is in a tight spot, but not that tight .... I just unscrew the inlet water line and screw on a short hose with a free end that I put in the antifreeze jug.
10-07-2019, 08:24 AM
2000 25' Safari
Davidson County
, NC Highlands County, FL
The filter screen should be on the inlet side, between the FW tank and pump.
When I installed the three way valve I also added flexible lines, which allowed me to move the plumbing a bit. I removed the screws that hold the pump to the floor so I could adjust the pump's position. After I got it all connected the pump was in a slightly different position, but that did not affect function.
ps:
The 3way valve should be located between the water tank and the filter screen so that antifreeze will be drawn into the filter screen housing when winterizing.
https://www.lowes.com/search?searchT...+line+flexible
Alan
10-07-2019, 08:57 AM
2019 22' Sport
Bend
, Oregon
ps:
Good idea on the flex tubing.
And thanks for pointing out the water filter...might not have done that.
10-07-2019, 10:05 AM
Married with Airstream
2004 25' International CCD
Vancouver Island
, British Columbia
Yep, the PEX piping makes it a challange alright ... I swear the factory attached the PEX to the pump then screwed the pump to the floor. I refuse to spend $30.00cdn for the camco kit and spent $5.00 for the clear tubing and connector take 2 minutes to attach. This spring I am thinking about adding Accumulator Tank with flex tubing both sides of the pump just to cut down on the noise. At that time I will add a three-way valve for winterization
La Dolce Vita Brick & Mona
We're Married With Airstream dot com
2004 International 25CCD Registered Name "Blue Streak"
2013 F-150HD FX4 SuperCrew Lariart (MaxTow) "Red Dragon"
10-07-2019, 10:49 AM
2019 30' Classic
Belleville
I paid the dealer $80 to install mine because it is in the same confined space as yours.
10-07-2019, 11:17 AM
2019 27' Globetrotter
McHenry
Doughpat, I had the same issue with our FC23FB and just used the flexible tube from the kit connected to the pump. Our new Globetrotter came with a winterizer valve pre-installed but it’s backwards!
I took that as a sign and bought a blow-out hose and valve from Amazon. I’ll use my portable compressor to blow out all the water and just put antifreeze down the toilet, shower and sink traps. Plus, since I’ll have this with me all the time, I can quickly “winterize” when on the road should we get caught in a cold snap. Bonus, no more flushing before we can use it again.
Happy Camping!
2019 27’ Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1000#
WBCCI# 10258
RETIRED!
10-07-2019, 12:59 PM
Antiquepedaler
2010 25' FB Flying Cloud
Laramie
, Wyoming
That’s why I just carefully Drain and blow out the plumbing with compressed air, put some antifreeze down the drains and call it good. It’s worked thru 21 Wyoming winters and 4 Airstreams so far.
Antique Pedaler
2021 Caravel 20 FB
10-08-2019, 12:15 PM
The Aluminum Tent 3
2014 23' Flying Cloud
Park City
, Utah
Pro Tip: Don't install it backwards! On the valve body, the end that has a 'C' stamped on it attaches on the pump inlet side. It's easy to install it backwards, and you won't have suction in that case.
Not necessary to install the kit 'before' the inlet filter, if doing so is more difficult. Just unscrew the filter cover and make sure it's empty of water.
10-09-2019, 05:51 AM
McHenry
Alternate option to valve install
I couldn't find room to install the Camco kit on our previous FC23FB so I just took the input fitting off the pump and used the plastic fitting and hose from the kit and a funnel.
I tried putting the tube directly in the bottle but couldn't get it to draw so the funnel solved that problem. Worked like a charm! As mentioned in the previous post, make sure there's no water in the filter before the pump.
2018 FC23FB
WBCCI# 10258
RETIRED!
