Old 08-15-2019, 09:27 AM   #1
2016 16' Sport
Afton , NY
Talking Generator hookups
I am a newbie- I will be picking up my 2016 Bambi 16 ft. in a few days. I am looking to buy a generator for boondocking. What I want to know is what type outlets should my generator have ? 110 V or 30 amp. Not sure what type hookup comes with the Bambi. It's a private sale and the lady seller is not helpful with technical questions.
farrider387 is offline   Reply With Quote
Old 08-15-2019, 10:43 AM   #2
2008 27' Safari FB SE
Miami , Florida
Well, if you want to use your A/C , then perhaps A Champion dual fuel 3400. If not, the Honda 2100 Companion. Both have 30a plugs.
Sorta new (usually dirty) Nissan Titan XD (hardly paid for)
Middle-aged Safari SE
Young, lovely bride
Dismissive cat
Old 08-15-2019, 11:17 AM   #3
Al and Missy's Avatar
2002 30' Classic S/O
Fleming Island , Florida
With a MicroAir EasyStart added to the AC the Honda 2100 will run the AC. Much easier to handle than the 3400. The trailer will come with a power cord which has a 30A connector on it. Adapters are available to convert the 30A plug to a 15 or 20A plug which will mate with the 15/20A socket on the regular Honda 2100 but if you can get the Companion model for the same price or a little more, it's nice to have the 30A connector.
I have the older Honda 2000 (not a Companion) which I converted to run from propane. I had an EasyStart put on my (13,500 BTU) air conditioner and I can run the air conditioner (and little else) on the Honda, even in the ECO mode, from my propane tank.
All that said, air conditioning is largely for use in campgrounds with electricity available. Running the air conditioner on a generator in warm weather will use a LOT of fuel. If you anticipate boondocking at altitude or in cooler weather, almost any generator will do to keep batteries charged.
Also be advised that many boondock-type campgrounds (USFS for example) have quiet hours when generators are not allowed.
Al
Old 08-15-2019, 11:34 AM   #4
Reno , Nevada
Cool Start by estimating your power needs....
Welcome, Farrider
The job which you need to do first is: Estimating your power usage.
If your 'Boondock' trips will sometimes involve the Air Conditioner, then this is the minimum Generator to run it, and the most-respected Generator of it's size: https://www.amazon.com/Honda-2200-Wa...dp/B07R1HK2RL/. (Per this post: http://www.airforums.com/forums/f295...ml#post1942372).
It includes Receptacles for both 15/20A (a NEMA "5-20R T-slot") and 30A (a NEMA L530P "twist lock").
You will want this adapter, to connect the straight-pinned RV plug.
https://www.amazon.com/Camco-55333-3.../dp/B0011FLODA. You need the '30A 3 prong Generator Version', which converts provides an L5-30 Plug on one side, and a TT-30R Receptacle on the other side.
If you WILL NOT need air conditioning, then you have a number of other options. (Solar Panels, or a smaller generator, or charging from the Tow Vehicle with something like this: https://www.renogy.com/renogy-12v-dc-to-dc-on-board-battery-charger/)
But it all starts with the question: How much power do you really need?
rickst29 is offline   Reply With Quote
Home RV pad with hookups considerations? aomastu Full-Timing, Winter Living & Workamping 34 01-01-2018 11:37 AM
dumb question - water hookups stu.cruz Fresh Water Systems 16 12-16-2009 04:04 PM
Internet / Satellite Hookups wtmark Computers, Internet & Satellite 58 01-21-2008 07:02 PM
Cable TV Hookups Devoman Electrical - Systems, Generators, Batteries & Solar 7 03-20-2006 11:11 AM
Setting up hookups at home rluhr Winterizing, Storage, Carports & Covers 26 05-10-2005 05:11 AM
