Old 08-15-2019, 12:44 PM   #1
2018 27' Globetrotter
Richardson , Texas
Atkinson PVCM40D vs newer MPT (PVCM40D-MPT)version
The solar controller in my 2018 Globetrotter is the Atkinson PVCM40D-SE2 unit with is a really simple controller that just basically closes a relay to connect the solar panels to the battery if the voltage is below a voltage threshold.
This is obviously pretty low end since the panel voltage is pulled down to the voltage of the battery and there is nothing to optimize anything for lighting conditions.
Atkinson has a PMT version of this called the PVCM40D-MPT. They call the control MULTI POINT TRACKING not MPPT (Maximum Power Point Tracking). They do say is uses PWM regulation.
Anybody evaluated this unit? It has the advantage of a easy "swap-out" of the origninal factory unit and the display panel is the same so you can keep that too. It also fits in the same location as the original controller that came with my Globetrotter. Disadvantage it is expensive ($167) so you could buy two after market MPPT controllers vs this one and have MPPT control on 2 sets of panels.
If someone has used this unit please comment.
DLDINS is offline   Reply With Quote
Old 08-15-2019, 01:05 PM   #2
rowiebowie's Avatar
2012 Avenue Coach
Corpus Christi , Texas
I upgraded from the stock Atkinson to a $109 Victron 75/15. Not that hard if I could do it. I can monitor the Victron via it's built in bluetooth. That meant I no longer needed the wall monitor, so I re-purposed the CAT5 cable that went to it for added USB charge port. It runs off the "Load" connection on the Victron.
rowiebowie is offline   Reply With Quote
Upgrading the solar charge controller from Atkinson to MPPT FlyFishinRVr Sprinter and B-van Forum 107 08-28-2020 06:31 PM
Atkinson Sun Explorer charge controllers Mhawke2 Sprinter and B-van Forum 42 05-04-2020 12:53 PM
Atkinson Solar controller swilly43 Electrical - Systems, Generators, Batteries & Solar 2 01-07-2018 05:49 PM
Location of the Atkinson Charge Contolller Display kit on a 2017 Interstate Mitou Electrical - Systems, Generators, Batteries & Solar 1 03-09-2017 07:41 AM
