This is my first attempt at a question so here goes: any ideas why water would only be warm? Propane is fine and I hear water heater run so can’t figure out how to get water hotter. I could use a hot shower right now. Thanks so much for any ideas. Sent the AS dealership an email about it but no reply.
Donna C
Many many threads on cool and lukewarm water. Far and away the most common issue is a plugged or non-functional mixing valve. You can measure or estimate water temperature in the tank. If it is good then the valve is a good guess as the issue. You can remove the valve and clean it with vinegar. Second issue is plugging at the faucets in question.
