11-22-2019, 06:20 PM
2017 19' International
Tallahassee
Sewage hose — what's a good one?
I need to replace the sewage hose, which is a not-quite 10-foot cheapie the Airstream dealer threw in.
What's a good one?
Need more than 10 feet, probably less than 20.
11-22-2019, 07:46 PM
2002 30' Classic S/O
Fleming Island
I have been using two of the 10' Camco RhinoFlex hoses for about 4 years now. They are heavy duty and well made. I stepped on one of mine and the wire reinforcement bent, but the plastic hose didn't tear. I bent it all back into shape and it is still going strong.
The only "gotcha" is that the fittings are bigger than other hoses and they will not fit in the smaller under trailer tubular hose holders without modification. The fittings have "Ears" on them that you use to twist and lock them together. If you cut the ears off they will fit, but you may find it more difficult to mate and unmate the connectors. You can also get a bigger hose holder. That's what I did on my previous trailer. On this one I store them in the bumper drawer.
Al
11-22-2019, 08:00 PM
Sioux Falls
, South Dakota
There are two types of fittings for the "stinky slinky" - Thetford and Valterra. They look similar, but they are not the same. Valterra is much more common. We used the cheap ones at first, too, but shortly before we went full-time I added a third valve and switched to the Valterra fitting. I then bought two Rhino hoses. That was 2013. Haven't bought another hose in that time.
David Lininger, kb0zke
AIR 54240
Heartland mpg 181 (sold)
1993 Foretravel U300 (sold)
2022 Grand Design Reflection 315RLTS
11-22-2019, 08:05 PM
2002 25' Safari
Dewey
We acquired a Rhino Flex Hose with our current trailer. I have been very pleased with it.
Richard
11-22-2019, 11:11 PM
Salem
, Oregon
Dominator
Hi, I bought the Dominator kit which comes with two 10' hoses and an elbow. These are tough hoses, but the best part is that they collapse down to 3' each. I carry five of the 10' hoses.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
11-23-2019, 06:13 AM
1988 25' Excella
1987 32' Excella
Knoxville
, Tennessee
I also have converted to using the Rhino flex. With some changes. I put on a large enough under the trailer carrier tube to carry the Rhino with the end fittings attached. I also do not use the swiveling 90 degree connection for the sewer that comes in the kit. I bought a solid 90 that does not come apart when you are dumping or when one of the 2 little tabs breaks. (I did not learn the first time but twice was enough.) And at my advanced age I also bought a set of the plastic levers or wrenches that work with the Rhino fittings. Keeps me from getting them stuck. And I put a Valterra fitting on the trailer so that the Rhino fits.
11-23-2019, 06:22 AM
Riveted
2018 33' Classic
Charleston
, West Virginia
My vote is for the Lippert Waste Master 20’. $95 on Amazon. Uses cam lock instead of bayonet type. Easy conversion for Airstream. You can still use bayonet with adapter (separate purchase). Easily stows in 33 Classic bumper compartment. I assume other bumper storage space is the same. Very high quality.
11-23-2019, 07:24 AM
Tampa
What's a good one?
I've tried several, cheap and expensive.**
So far the Camco RhinoFlex set with two 10' sections has worked fine. Brown hose, orange ends.
It seems to be leak free, clicks open and better, clicks closed.
90% of the time you only need one. But for the long reach...(Alumalina) 20' is great.
Since I don't use the caps, I made a PVC thingy to store it compressed.
** The overpriced Thetford Titan hose, Black/Green, clicked open, then wouldn't compress again. Imagine storing a 15' hose that's like a noodle.
11-23-2019, 07:26 AM
2013 31' Classic
billings
, Montana
What's a good one?
I like the blue line...push on pull off connections...going on 6 yrs..still goog
11-23-2019, 07:49 AM
2015 27' Flying Cloud
Newberg
, Oregon
I’m using the same hose. It works well, and I like it about as much as anyone can like sewer hose. I particularly like the way in compresses to fit in the storage tube. I’d buy it again if needed.
Mike
2015 27ft FC FB
WBCCI #3960
2019 F150 ecoboost
11-23-2019, 08:50 AM
2017 28' International
Jim Falls
, Wisconsin
Mike
Yep. It’s what I have. I had another brand that I bought at the dealer. OK, but this one compresses down much better. Seems more durable. I carry 2 just in case I need the length.
By the way CAMCO has a connector that fits on the end of the hose that you can connect to the sewage hose. It will spray and flush it out and clean it. Highly recommend it.
11-23-2019, 09:22 AM
Married with Airstream
2004 25' International CCD
Vancouver Island
, British Columbia
I second the 10 ft Camco RhinoFlex hoses bought the kit off amazon includes everything you need to watch the crap flow (ha ha)
La Dolce Vita Brick & Mona
We're Married With Airstream dot com
2004 International 25CCD Registered Name "Blue Streak"
2013 F-150HD FX4 SuperCrew Lariart (MaxTow) "Red Dragon"
11-23-2019, 09:58 AM
2019 25' Flying Cloud
Greeneville
, Tennessee
I like the Camco Rhino EXTREME. Available at Amazon.
11-23-2019, 10:04 AM
Long time owner
2004 25' Classic
1974 25' Tradewind
1970 21' Globetrotter
1975 26' Argosy 26
Forrest City
, Arkansas
The new Camco Extreme Rhino Hose is the very best that I have used over the years. You will not go wrong purchasing this hose and it is available on Amazon. However, as some have stated it will not fit in the standard carrier so I put it in a large garage bag and store in the rear storage bin on my AS.
11-23-2019, 10:29 AM
Tallahassee
Thanks for the responses.
I looked for some hoses on Amazon and, I have to say, the reviews are all over the place. No matter the hose, someone is disappointed and wants to tell the world all about it.
That makes it hard to make a choice, so these recommendations are helpful.
Just to be clear, which connection would a 2017 Airstream have — Thetford or Valterra?
And for those using the 20-foot RhinoFlex, or any of the other recommendations, do both 10-foot sections fit in the trailer's bumper hold?
11-23-2019, 11:00 AM
Tampa
and for those using the 20-foot RhinoFlex, or any of the other recommendations, do both 10-foot sections fit in the trailer's bumper hold?
Easily, along with the other sewer fittings, the awning hook, and my sandbag*.
*Back when you weren't sure the sewer hose would stay in the ground pipe, I got this tip from an RV'er. A tube sock filled with pea gravel, closed with a cable tie, inserted into the other tube sock and cable tied again. It's a 5# floppy bag that I drop over the ground fitting so if the hose wanted to jump out, it can't. It conforms to any shape.
Cheap to make and lasts for years.
I'm always looking to make things more efficient, and attaching the hose to the trailer so close to the ground is hard without kneeling.
I found these Camco 'wrenches'. Inexpensive.
Good for the Camco fittings, and no other it seems. The handle hits the trailer so it's awkward to hook the hose fitting.
In the real AS world, there's not that much space.
11-23-2019, 11:06 AM
2008 27' Classic FB
Burkburnett
I’m also on board with the Rhino. As others have mentioned, the ears on the connector need to be shaved down so it will fit into the stock underbelly storage tube. I added a 2nd tube for a Rhino extension that is useful on occasion. I’ve gotten 8+ years service from the Rhino. We take extended road trips that last all summer so the Rhino sees lots of use.
AIR 47751
11-23-2019, 11:11 AM
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach
We gave up on the slinky about twelve years ago and went with the Sewer Solution. We still keep a slinky in the belly tube for a fast gray water dump at a dump station.
We carry three additional 10' SS hoses. This gives us a 40' dump reach if we need it. In over 2,00 nights of Airstream camping we have never had the slightest urge to go back to the slinky.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
11-23-2019, 11:48 AM
Tallahassee
Can you explain the PVC thingy?
How's it work, and how did you make it?
Thanks for the photo and info.
11-23-2019, 12:20 PM
1999 28' Excella
New Orleans
, Louisiana
I do not think this is such a big deal. We purchase hoses that are heavy duty and use our thetford and screw in fittings in a cg. We have 2 sets. If we are going to be there for an extended time we use our sewer hose rack, 2X4 and zip ties. I am 68 and female and handle the hookups, health prevents my husband from doing anything that is the least bit physical. I do use a stool to hook up... that makes this comfortable...I like simple. Never a problem.
