07-25-2010, 10:22 AM
#501
1955 22' Safari
Great Lake State
Venting AC behind license plate.
toastie
07-25-2010, 03:05 PM
#502
1955 22' Safari
Great Lake State
Added side duck work........toastie
07-25-2010, 05:42 PM
#503
Jupiter
You sure no one saw you borrow the rest stop combo waste receptacle - towel dispensers?
The days are short and the night is long and the stars go tumbling by.. . ~Airstream~
07-26-2010, 05:45 AM
#504
1955 30' Liner Commodore Vanderbilt
Wayne County
, Michigan
Very well thought out installation. I really like how you are hiding the vent behind the license plate, neat. Are you going to mount the unit on rubber washers to help isolate it further or doesn't it seem to telegraph thru the floor?
Jason & Veronica J.
S.E. Michigan
1955 Commodore Vanderbilt 30'
"Hawley"
TAC Member MI-6
2008 Chevy Silverado Ext. Z71 w3.73
07-26-2010, 04:28 PM
#505
1955 22' Safari
Great Lake State
Thanks very much, very happy with the installation. Will go back and fine tune to bring the noise down, Dave Park came up with some great ideas also. The noise level according to Frigidare at high is 54.8 dB, seem to be a lot less noise then the roof top on my 65 Caravel.
toastie
07-27-2010, 05:48 PM
#506
1955 22' Safari
Great Lake State
Removed side louvres and did a test run and it did reduce the noise level. Also drilled a drain hole and ajusted the side duct work.
toastie
07-28-2010, 12:54 AM
#507
2005 22' Safari
Hyde Park Place
, Ohio
Excellent!
I have done that on a window unit before, and it increased the airflow too, so the unit also ran a little less and drew a little less current.
It's also nice that not having the A/C on the roof lowers the center of gravity a little more.
I am thinking of doing something similar with my next project, but near the wheel cover. I'll credit you then
TX-16
08-08-2010, 08:54 AM
#508
1955 22' Safari
Great Lake State
Started working on the shower today and below pictures show my final drain setup to gray water tank, going with HepVo waterless trap and a touch-toe stopper kit. I have 2 gray water tanks, one will be used for the shower only.
Hepvo Waterless Valve
toastie
08-08-2010, 11:06 AM
#509
2005 22' Safari
Hyde Park Place
, Ohio
Is the elevation of the shower pan vital to you? Can you shave 1" off the stopper assembly to lower from 4.5" to 3.5"?
TX-16
08-08-2010, 03:48 PM
#510
1955 22' Safari
Great Lake State
No need to lower, will be using 2 X 6 for the shower base. There will be a removal panel for service.
toastie
08-08-2010, 03:53 PM
#511
2005 22' Safari
Hyde Park Place
, Ohio
With the floor of the pan elevated 6" will you have comfortable headroom? Just making sure...
Nothing worse than getting it all in, then going for a shower and bonking your head on the side wall.
TX-16
08-08-2010, 04:20 PM
#512
1969 27' Overlander
Adel
, Iowa
Originally Posted by toastie
Starting to compound the inside, this will be the first cut, will replace all rivets with olympic rivets, then shave then to look like the rivets to the 13 panels, than compound second cut.............
OK.. What are Olympic rivets and where do you get them?
08-08-2010, 04:27 PM
#513
2005 22' Safari
Hyde Park Place
, Ohio
Normally, riveters have access to both sides of the piece, and use buck rivets. If access is only from one side, you would use a pop rivet, which is left with an unattractive hole. Of more concern to an airstreamer, it lets water in.
Olympic rivets are a special type of pop rivet that leaves the center aluminum shaft in place when popped. This shaft can then be shaved down, so the rivet then appears to be a standard buck rivet.
TX-16
08-08-2010, 04:45 PM
#514
1955 22' Safari
Great Lake State
Hope this helps..........toastie
Olympic Rivets
08-09-2010, 04:04 PM
#515
1955 22' Safari
Great Lake State
Marinco power Inlet is a good product on the outside, but hooking the wires up on the inside is a pain, very poor design. This is how I handled mine.
toastie
08-09-2010, 06:44 PM
#516
1972 31' Sovereign
Lexington
Ah, we just installed one of those. Haven't hooked it up yet. Thanks for the info, Toastie. That will come in handy (someday).
Kay
08-09-2010, 07:34 PM
#517
1955 22' Safari
Great Lake State
Kay
Thanks very much Minno, got the idea from markdoane, http://www.airforums.com/forums/f449/marinco-electrical-connection-58288.html#post769103 . What I know today it would be a very simple installation to install wire's to the Marinco then fasten Marinco to trailer, the set screws are perpendicular to the wire inputs.
08-09-2010, 07:48 PM
#518
Jupiter
Please say you isolated the bright zinc-plated steel receptacle box from the aluminum!
08-09-2010, 07:56 PM
#519
1955 22' Safari
Great Lake State
No I didn't, but I can......why?
08-09-2010, 07:59 PM
#520
Remember, Safety Third
Catfish Corners
, Georgia
I'm curious, too. Would the same thing apply to the circuit breaker panel inside the camper? I don't recall it being isolated from the aluminum wall either.
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
