Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Floor Finishes
Old 06-12-2016, 10:40 AM   #1
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
Laminate hid major leak/water damage
So I'm in the middle of tearing out the rest of my interior (doing a full restoration), and just took out the rest of the pergo that I installed about 10-12 years ago. pulling up those last couple of pieces, and I found the sub-floor completely saturated. "poke-your-finger-through" saturated.
The location is the front street-side, just between the couch and the galley.
(73 safari--gaucho across the front; street side galley).
Not sure where the water is coming from--point is that the pergo completely hid it.
So this has me re-thinking finish floor, again. Seems to me that the only thing that wouldn't hide a leak is plain-old glue-down vinyl.
Or would it?
~thoughts~
I was still leaning toward some other type of diy click-laminate because its cheap, easy, and looks great. Plus, my original plan was not to completely gut, but I've decided that it is necessary. Now, with a completely empty trailer, a full sheet of glue-down is possible. (I shudder to think of the cost of paying for it, as I think it is probably beyond my diy capabilities.).
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 06-12-2016, 10:50 AM   #2
Images: 59
I used VCT tile as the base. That might be a more DIY alternative that would give you the moisture barrier you want.
It's heavy though, make sure it fits in your GCVW budget.
Old 06-12-2016, 11:24 AM   #3
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
I believe that it all depends on the origin of the leak. If within the walls to the wood it COULD potentially get under the OEM vinyl and any other vinyl. I left the OEM vinyl and installed the LVT over it. Behind the cabinets the OEM vinyl is a barrier if there is a plumbing leak (I hope). I do not believe there is a perfect solution other than to watch for leaks at fixtures and lines in visible areas.
WBCCI 8653/AIR 60240
2022 Ford F150 PowerBoost Platinum w/7.2KW
rodsterinfl is offline   Reply With Quote
Old 06-12-2016, 03:00 PM   #4
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
The leak source is within the wall. no plumbing anywhere near this spot. After looking it over some more, a likely candidate is the awning attachment point. The seam where the front end-cap section starts is "ground zero", and there is a full-length window awning that attaches there on the front main bow. I'll know for sure when I finish gutting; since the walls are coming off, there won't be any problem finding it...but the point is, such a leak could (and likely will) happen again, anytime, anywhere.
Air:291
Wbcci: 3752
'73 Safari 23'
Major Water Leak fmacmaster Plumbing - Systems & Fixtures 8 10-16-2012 08:08 AM
MAJOR damage to my 2001 Bambi (see pictures) ksrich343 1997 - 2004 Bambi 28 04-13-2010 11:09 PM
HID headlights anyone? boondockdad Tow Vehicles 11 04-01-2008 08:49 PM
Brake failure causing major damage? davidz71 Brakes & Brake Controllers 12 11-02-2007 03:24 PM
Major fresh water tank leak! JohnGalt48 Fresh Water Systems 2 05-17-2004 05:50 PM
