Originally Posted by dwight69
We recently bought a 2020 International 28RB and have found a somewhat annoying and potentially dangerous problem with the shower mixing valve. When we adjust the temperature to warm with the valve handle at about the 10 o’clock position it often drifts to the full hot position, 8 o’clock.
I have taken the handle off looking to see if there was a problem or some way to tighten the stem. Nothing obvious about the valve mechanism but I was very surprised that the handle weighed so much. I’m convinced the heavy valve handle “falls” to the full hot position. The valve stem resistance is not enough to stop it. Anyone else have this problem? I’m probably going to have a plumber look at it and replace the valve if it can’t be adjusted.
Hi dwight69,*
Please send us a direct message with your contact information, email and the last 6 digits of your VIN so we can share it with our Customer Service and Technical Support team. We look forward to helping you get this resolved.
You can also reach Airstream Customer Service and Technical Support at*customersupport@airstream.com
Thank you.*
