Old 05-25-2020, 02:55 PM   #1
2016 30' Classic
Sweeny , Texas
Shower mixing valve
I need to replace mixing valve on shower and the hole that was cut in wall isnít large enough to remove cartridge as it was designed to be removed . The wall between bedroom and bath will have to be removed to access it from backside. How is wall secured, ours has a TV on bedroom side.
One wildfire is offline   Reply With Quote
Old 05-25-2020, 03:32 PM   #2
2018 25' International
Slidell , Louisiana
most people just cut the hole a bit bigger. if you mark the decorative cover with some painters tape and make a jig the size yo need to remove the valve, you won't cut too far.
Brian
Old 05-30-2020, 05:25 AM   #3
Bluffton , South Carolina
I used this Holesaw. After I fretted over cutting a hole in my shower wall it took less than 30 minutes to be done with the job. If I can answer any questions pm me.
69SoulShine is offline   Reply With Quote
Interstate Shower Head / Faucet / Mixing Valve nvestysly Sprinter and B-van Forum 15 10-23-2017 05:37 PM
2017 Classic Hot Water Mixing Valve Calibration rivetville 2016 - Current Classic (all lengths) 74 08-17-2017 04:20 AM
Shower Mixing Valve Cartridge Replacement jmellana Plumbing - Systems & Fixtures 2 07-29-2017 11:34 AM
Atwood XT Water heater mixing valve orloffgray Plumbing - Systems & Fixtures 0 03-23-2016 07:55 AM
Need mixing valve G. Traveler Sinks, Showers & Toilets 5 11-01-2011 06:15 PM
