Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 06-25-2018, 11:07 AM   #1
emmadow's Avatar
1965 26' Overlander
sugar land , Texas
Domestic AC and SZ Thermostat hook up
Hi,
I purchased Dometic AC model 651816 and Dometic single zone thermostat model 3313192 and I'm having trouble with the wiring. I sure don't want to blow the thing up! I removed the junction box and ran the trailer wiring into the electronic box. I've rerun the thermostat wiring with 18-3 wire and I have that hooked up ok. I added spade connections to the 2 blue wires (heat) and plugged in the freeze control wire and sensor up into the fins.
The electronic control box has a 6-pin connector with 5 wires running to it. How do I hook this up to my bare wires coming from the new a/c unit? There are 2 black wires with RJ-11 connections. I think these are high and low speed fan wires? Is this right and if so how do I figure out how to connect? There is a blue and a black wire in the electronic box that might be the wires I need to connect to? Maybe???
Help and thanks in advance for any expert advise!
Emma
Emma Dow
1965 Overlander Newbie Restorer
emmadow is offline   Reply With Quote
Domestic Thermostat Adjustment. clicker187 2009-2015 Flying Cloud 1 09-17-2016 08:04 AM
Domestic 3314080 (twin zone) thermostat Ohiobrits General Repair Forum 10 06-28-2015 06:40 PM
My Hook Things Won't Hook Sbb Rock Guards, Segment & Window Protectors 2 04-12-2015 06:16 PM
thermostat wire hook up 1973 Argosy Sprouty Electrical - Systems, Generators, Batteries & Solar 5 03-10-2014 09:04 AM
Hook up OR Not Hook up while camping purman Boondocking 29 08-18-2009 06:42 PM
