Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Overlander > 1970 - 1973 Overlander
Old 03-01-2016, 12:01 PM   #221
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
test photo rotation
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 03-02-2016, 07:37 PM   #222
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
Alan,
Did you do that from within the Airforums? or rotate it +90 degrees then re-upload it?
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
Old 03-03-2016, 03:59 PM   #223
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Rotated on my laptop saved as jpeg
AIR #005
retired!
Old 07-31-2016, 05:26 PM   #224
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
I finally was able to take some time off from work and devote it to the trailer. The belly is now all enclosed, the holding tank/dump valve plumbing installed, and the fresh water plumbing is installed as well.
Finally, I can start on the interior. In that direction I removed all the spare parts sitting in the trailer, and gave the floor two thick coats of spar varnish on top of the West System Epoxy the plywood was originally coated with. At least if it leaks, there won't be any floor damage!
Craig and Carol
2009 Ford F150 5.4L
AIR 41028
TAC GA-8
WBCCI 10199
Old 08-01-2016, 04:41 PM   #225
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
ready to see this project! Keep up the good work
AIR #005
retired!
Old 11-25-2016, 03:33 PM   #226
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
I had some more vacation time and was able to get some work done on the trailer. The new interior wiring is now in. The second layer of Prodex is going in along with the original interior skins. Initially I planned to replace all of the interior skins with new aluminum, but finding .04" in a 17' sheet was difficult. So, the new idea is to install the old skins and paint them. If my wife likes the look, we will go with that. If she doesn't, I can find thin 5052 in any length I want which I will use as a vainer over the now painted old skins.
Attached are some pictures as proof that I actually worked on the trailer. This project is taking forever! What I don't have finished by Springtime, will be completed by Woodland up in Grand Rapids.
ID:	275961   Click image for larger version
Craig and Carol
2009 Ford F150 5.4L
AIR 41028
TAC GA-8
WBCCI 10199
Old 11-25-2016, 03:43 PM   #227
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
OK, I am well and truly puzzled. The pics are properly oriented in my computer prior to uploading, but then I get flipped on my head in the final version of the post. Grrrrr. Or maybe I should be happy I have a gravity defying Airstream. Just think how great my towing milage will be!
Craig and Carol
2009 Ford F150 5.4L
AIR 41028
TAC GA-8
WBCCI 10199
Old 11-26-2016, 05:51 AM   #228
1989 29' Excella
Tyrone , Georgia
Awesome work Craig.
mikeandnora is offline   Reply With Quote
Old 11-26-2016, 09:42 PM   #229
Central , Mississippi
Awesome work while standing on your head. Did you move to Australia 'down under'?
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie(RIP) -
A honkin' long 34' named AlumaTherapy https://www.airforums.com/forums/f20...num-54749.html
and a 26' '63 Overlander, Dolly https://www.airforums.com/forums/f10...ome-71609.html
Old 12-21-2016, 05:57 PM   #230
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
A bit more accomplished over the past week. The old interior panels are clean and re-installed. The aluminum end cap kits I purchased from Colin Hyde are buck riveted together and clecg'd in place awaiting final trim fitting. I'm waiting for an estimate to spray paint the interior a uniform silver color from our local helicopter repair shop which has a monster sized paint booth.
ID:	276967   Click image for larger version
Craig and Carol
2009 Ford F150 5.4L
AIR 41028
TAC GA-8
WBCCI 10199
Old 12-21-2016, 05:59 PM   #231
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
More pics of riveting end caps.
ID:	276961   Click image for larger version
Craig and Carol
2009 Ford F150 5.4L
AIR 41028
TAC GA-8
WBCCI 10199
Old 12-22-2016, 05:52 AM   #232
KAYAKAMPERS's Avatar
1999 27' Safari
Stone Mountain , Georgia
Amazing work Craig. I can't wait to see it one day!
_______________________________
Beth Wallace & Chris Sanor
1999 Safari 27'
Towed by 2016 Ford F-150
Tin Can Tourist
TAC #GA-27
AIR #34930
KAYAKAMPERS is offline   Reply With Quote
Old 12-23-2016, 01:31 PM   #233
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
We were able to install the end cap kits purchased from Colin Hyde yesterday afternoon. The kits went together easily, but did require a bit of trimming to fit around the window openings fore and aft.
Craig and Carol
2009 Ford F150 5.4L
AIR 41028
TAC GA-8
WBCCI 10199
Old 11-20-2017, 04:52 PM   #234
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
It's been a long project. After about three years working on it myself, the project was at the point of needing custom cabinetry made. I have the tools, but not the time. After some searching we selected Woodland Travel Center in Grand Rapids, MI to do the work. Gary did a fantastic job on the cabinets and other items. We can't speak highly enough of him and his attention to detail.
Below are the final pics of the project. We camped several nights in the trailer prior to bringing it back to Atlanta and did have any significant camping issues.
Thanks guys!
ID:	299528   Click image for larger version
ID:	299530   Click image for larger version
Craig and Carol
2009 Ford F150 5.4L
AIR 41028
TAC GA-8
WBCCI 10199
Old 11-20-2017, 04:59 PM   #235
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
A few more pics
ID:	299535   Click image for larger version
ID:	299537   Click image for larger version
Craig and Carol
2009 Ford F150 5.4L
AIR 41028
TAC GA-8
WBCCI 10199
Old 11-21-2017, 09:20 PM   #236
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
Thanks for posting the photos. Absolutely superb design and build quality by you and Woodland.
Dan
Old 12-06-2017, 11:39 AM   #237
Deerfish's Avatar
1970 27' Overlander
Highland , Indiana
Hi ,
Graig The Overlander looks Wonderfull!!! Glad that you were able to finish her !
She looks Beautiful that gives me the motivation that I need to finish mine I have the same problem that you did not enough time!
Deerfish is offline   Reply With Quote
