RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 02-11-2020, 10:54 AM   #1
2012 30' International
Dallas , Texas
Connecting Weber Q 1200 grill to Airstream LP
I just got a Weber Q 1200 grill from the Airstream Supply Company. It is designed to work with the low pressure LP system of the Airstream. I had assumed (always unwise) that it would come ready to connect to the trailer, but evidently not. I have a few questions that I hope someone can help with.
1) Do newer Airstreams have a quick connect port for LP gas for a grill? We have a 2012 International 30', and I don't recall ever having seen such a port on ours (it's stored at a facility that's a 45 minute drive from where we live, so I can't easily just step out and look at it). The hose that came with the grill only has a quick connect male to hook up to the trailer.
2) Can you direct me to where I might purchase the adapter I'll need to connect the hose to the LP bottle? I'll check at the usual places (Airstream factory, Amazon, Camping World, etc.) but I thought if someone has already chased this adapter down it could save me the legwork.
3) If you have a 2012 International (or similar), does yours have the quick connect port for LP?
I'm attaching a file that is an image of the quick connect male that hooks up to the trailer.
Thanks for any help.
Russ
russingr is offline   Reply With Quote
Old 02-11-2020, 01:01 PM   #2
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
I have a 2012 25FB Intl and it has the QD on the front, with a valve, for the LP propane supply to the grill.
Larry
lsbrodsky is offline   Reply With Quote
Old 02-11-2020, 01:30 PM   #3
jeffmc306's Avatar
2019 27' Globetrotter
McHenry , Illinois
russingr, you may be in luck as Isbrodsky has one.
It would look something like this - from our 2019 GT Owner's manual.
I checked the 2012 International manual but couldn't find any reference. By the way, the manuals have come a long way (still not perfect) but much better!
We use our Weber Q on the low pressure port without the Q's regulator - works great!
ID:	360937   Click image for larger version
Name:	weber Q grill.jpg
2019 27’ Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1000#
WBCCI# 10258
RETIRED!
jeffmc306 is offline   Reply With Quote
Old 02-11-2020, 01:58 PM   #4
Dallas , Texas
Larry
Great! Perhaps mine does as well.
Old 02-11-2020, 01:59 PM   #5
Dallas , Texas
Very helpful, thank you.
Old 02-12-2020, 11:12 AM   #6
2014 27' FB International
Hooper , Utah
There is a quick connect on the front frame of the trailer, on the right side. It should have a black cop over the quick connect and a cock cut off value (which should be turned to off when you are not using it). It is next to the bottom frame by your battery box. Hope this helps?
albret is offline   Reply With Quote
Old 02-12-2020, 11:39 AM   #7
2007 31' Classic
Gulf Breeze , Florida
Please confirm that you removed the Weber’s regulator and that allows you to connect directly to the AS quick connector.
trumpetguy is offline   Reply With Quote
Old 02-12-2020, 12:14 PM   #8
greenflag's Avatar
2016 30' International
Quartz Hill , California
The Q may not work going through both regulators. Remove the Q regulator then purchase parts you need to make the connection to the Airstream
greenflag is offline   Reply With Quote
Old 02-12-2020, 01:05 PM   #9
2018 30' Classic
Williamsburg , VA
I thought they made and Airstream specific one without the regulator. I have a different grill that I removed the regulator on but for this grill I believe the regulator is already removed. Maybe I'm wrong.
2018 Classic 30
2012 F250 6.7l
US Army Watercraft Engineering Officer
primepower is offline   Reply With Quote
Old 02-12-2020, 02:13 PM   #10
Dallas , Texas
Yes, quite helpful, thanks.
Old 02-12-2020, 02:14 PM   #11
Dallas , Texas
This one came without the regulator, so it's ready to go with the Airstream.
Old 02-12-2020, 02:15 PM   #12
Dallas , Texas
Old 02-12-2020, 02:16 PM   #13
Dallas , Texas
You are correct. This one came with the regulator already removed.
Old 02-12-2020, 04:01 PM   #14
2018 30' Classic
Williamsburg , VA
For mine I just use hoses that I bought at calling world that connect to the quick connect fitting on the trailer and then to the fitting on the grill.
2018 Classic 30
2012 F250 6.7l
Old 02-12-2020, 05:05 PM   #15
2015 25' FB Flying Cloud
Grapevine , Texas
Dallas russingr
Hey russingr:
IF you are not already a member of our North Texas Airstream Unit, send me your email address and I will get information to you. 135 members strong with rallies and events coming up this spring and summer.
tomjensen@msn,com
NTU - Membership
tommyglen is offline   Reply With Quote
Old 02-13-2020, 10:26 AM   #16
Dallas , Texas
Originally Posted by tommyglen View Post
Hey russingr:
tomjensen@msn,com
NTU - Membership
Hi Tom,
We are actually members of the Heart of Texas Unit, although we have not been active for some time, in terms of attending events.
Russ
Old 02-16-2020, 02:59 PM   #17
Dallas , Texas
Well I picked up my trailer from storage today, and mine does not have the quick connect fitting. I followed my gas line from the LP tanks, and it just goes straight back to the trailer; there is no Y or T in the gas line that would provide LP to a quick connect fitting.
I think maybe what happened is that when the shop installed my ProPride hitch some years ago, they had to take out the quick connect line to properly fit the hitch onto the trailer. They may have even mentioned it to me at the time, but if so it wouldn't have meant anything to me, since at the time I wasn't planning to get this grill.
Now I need to find the adapter that goes on the LP tank that has a quick connect on the other end. I saw one in a video on YouTube, but they didn't say where it could be purchased.
Old 02-16-2020, 03:41 PM   #18
jeffmc306's Avatar
McHenry , Illinois
Another option
Russ, you might still be able to re-add the low pressure port which is really handy.
Follow the propane line from the tanks under the curb side frame. Look to see if there’s a coupler that the hitch guys installed when they removed the line. If so, you could add a Tee and run a line for the low pressure valve.
You can get this stuff on Amazon or your local hardware store. I found everything I needed for my dual-fuel Champion generator there.
Below are photos of what it looks like on our GT.
Good luck!
ID:	361194   Click image for larger version
2018 FC23FB
WBCCI# 10258
RETIRED!
Old 02-16-2020, 04:02 PM   #19
Denver , North Carolina
russingr
If you don't have a low pressure quick connect fitting on your trailer and you don't want to add one I would consider returning the grill. You have paid a premium price for Airstream to sell you a grill that has had a regulator removed and will now only run on low pressure.
If you want to operate the grill directly from your onboard tanks or a 20 lb (high pressure) cylinder you will need to add a pressure regulator back into the supply line.
Dave S
link2dks is offline   Reply With Quote
Old 02-16-2020, 11:46 PM   #20
2007 22' International CCD
Most airstreams have a rubber flex hose from the bottom of the auto switch regulator located under the propane tank cover to a coupling under the A-frame to the copper tubing that goes back to the rest of the propane appliances.
On mine, a 2007 International, it was on the bottom curbside of the A-frame. I simply replaced a double male compression union there with some brass pipes, adapters and quick connect fitting plus a shut off valve. Except for the quick connect part, all the bits came from the local big box home improvement store. The assembly I designed just happened to fit right in when I replaced the rubber hose with a slightly shorter one. Serendipity is where you find it, even in the Department of Overkill Engineering. The old one happened to be tired, stiff, and getting brittle. It got replaced along with the tank pigtails as a maintenance action.
I’ll try to get a few pictures of the pipes and stuff tomorrow when the sun comes out.
I also use this added 3/8 inch quick connect port to run a modified Champion Dual fuel 3400 watt generator.
Airstream Weber Grill Pez Vela Sprinter and B-van Forum 116 10-13-2020 07:58 AM
Airstream Weber Gas Grill Jobforjim Airstream Lifestyle 14 12-22-2019 08:20 PM
Weber Airstream Q1200 Grill Carry Bag mohrmh Stella's Kitchen 1 10-15-2019 08:47 PM
Weber Q grill mwilliamsmd LP Gas, Piping, Tanks & Regulators 5 10-11-2014 07:10 PM
Weber grill Bambi sfixx Airstream "In the News" 3 06-03-2005 12:01 AM
