Old 02-19-2020, 02:36 PM   #21
ondaroadagin's Avatar
2016 27' International
San Anselmo , California
Go online to a company called "Torjik" that has complete "quick disconnect" kits to convert your Weber grill to hook up to your low port Airstream. It's easy and they also include a hose with the kit as well. We did this, and are very satisfied! You may want to also acquire a long Q.D. hose to allow you more set up flexibility. Good luck!
Ars Gratia Artis
https://www.anamericanstream.com
Get our travel writing ebook on Amazon: "Wanderlust: A Scrapbook of life on the Road"
ondaroadagin is offline   Reply With Quote
Old 02-19-2020, 04:39 PM   #22
Mattdjmorris's Avatar
2008 19' Safari SE
Waterloo , Ontario
Thanks for the detail. Yes, pictures would be great. Thank you again. Matt
Mattdjmorris is offline   Reply With Quote
Old 02-26-2020, 09:20 AM   #23
2016 30' Classic
Houston , Texas
We have connected our Weber Q directly to our rig's propane port. Love the convenience of not having to carry/store another propane tank. On small dissatisfaction is that the gas flow from the rig's low pressure propane system results in a lower than desires flame level. That said, I still like it.
dhroberts is offline   Reply With Quote
Old 02-26-2020, 12:20 PM   #24
turk123's Avatar
2019 30' Classic
Canfield , Ohio
Here is the hose you need to connect the grill to the trailer propane port. For the safest connection, this has a shutoff on one end of the hose and your Airstream has another.
You don't want to blow yourself up!
"At some point, throwing money at the problem *is* the right answer", Uncle Bob
x\x/x\x/x\x/x\x/x\101970\x/x\x/x\x/x\x/x\x/x\/x\x/x\x/x
Tom & Doty
2019 Airstream Classic 30 Twin
turk123 is offline   Reply With Quote
Old 02-26-2020, 04:07 PM   #25
2007 22' International CCD
Note that this is the standard 1/4 inch quick connect setup.
Old 02-26-2020, 04:24 PM   #26
Connecting Weber Q 1200 grill to Airstream LP
Note that this is my 3/8 inch quick connect setup.
This reliably supports a 3400 watt Champion Dual fuel inverter generator. The generator propane hose regulator setup has been modified to run off either the low pressure port or a propane bottle directly, as desired.
My 2007 Airstream did not come with any quick connect port. I added this setup myself. It’s documented in the “which generator” thread. I went with 3/8 quiche connectors and a larger 1/2 inch propane low pressure hose to assure the flow to the generator would be sufficient at the end of 24 feet of hose.
I have two 12 foot hoses with quick connects to get the generator noise and fumes far away from us when in use. The power cable just reaches that far.
I still need to add a few clamps to keep things steady. Note the large diameter ‘split loom’ tubing on the rubber hose that leads to the regulator going off on the right in the top picture. This is to keep UV light off the hose to make it last longer.
I included a 1/4 turn propane rated shutoff valve for the quick connect, and another for the entire propane supply for emergencies. Quicker than trying to get to the tank valves.
Old 05-17-2020, 08:34 PM   #27
is there Ean adapter for the grill side of the hose that comes in the parts box from airstream? We got the Weber Q1200 and a caravel 19 cb 2020 airstream. I can fibrous out the hose on the trailer side for the quick connect, but not to the grill.
clcapet is offline   Reply With Quote
Airstream Weber Grill Pez Vela Sprinter and B-van Forum 144 07-04-2023 12:09 PM
Airstream Weber Gas Grill Jobforjim Airstream Lifestyle 14 12-22-2019 07:20 PM
Weber Airstream Q1200 Grill Carry Bag mohrmh Stella's Kitchen 1 10-15-2019 07:47 PM
Weber Q grill mwilliamsmd LP Gas, Piping, Tanks & Regulators 5 10-11-2014 06:10 PM
Weber grill Bambi sfixx Airstream "In the News" 3 06-02-2005 11:01 PM
