Thanks Boxter (Mike).
I posted two fairly long detailed posts, neither of which showed up, and none had attachments.
I had open voltage and amperage at the solar panels, but the display inside showed battery voltage (constantly dropping) as was the charge percentage. .1 amps showing , but the solar "time" was going up.
Today I pulled the bottom lounge cushion so I could get at the controller and do some checking in there.
I found I was getting voltage and amps to the yellow wire from the panels to the controller, but not coming out to the battery. First thought was a bad controller, but then I realized the voltage showed at a -20 volts. WHAT?
I pulled the bath fan to get eyes on the wiring, up there the wires were red and black coming out of the "firewall" plug (Not the yellow and green they should be).
Finally figured out whoever wired that in, wired it backwards (Red was Negative , Black was Positive).
Swapped them at the panels, all is well and working now. Go figure!!
