Old 05-29-2019, 02:43 PM   #1
Brookfield , Wisconsin
FUSION radio on/off
What is the trick to turning the power totally off?
I push on/off switch and "hold" for a sec or two ... sound and display "go off". I think all is good.
The next morning the dash and storage compartment is "warm" to the touch - - this means the FUSION is consuming my valuable watts while I think it is "off"
When I hold power button down for 10 or 15 sec ... it reboots the sytem.
Manual is useless! Help...
Mike H
Long Spur is offline   Reply With Quote
Old 05-29-2019, 03:23 PM   #2
Prof. of Pending Projects
wachuko's Avatar
2018 Tommy Bahama Interstate
Orlando , Florida
You have just learned that the Fusion is really never off... reason some of us have installed kill switches to do just that...
Safe travels!
Wachuko
WBCCI #26769
2018 Airstream Interstate 3500 Lounge EXT Tommy Bahama w/ARS
wachuko is offline   Reply With Quote
Old 05-29-2019, 03:24 PM   #3
wachuko's Avatar
Orlando , Florida
And welcome to the forum!!!
Safe travels!
Wachuko
WBCCI #26769
Old 05-29-2019, 07:28 PM   #4
2017 Interstate Grand Tour Ext
Western , Tennessee
same here... now it is off
TN Princess is offline   Reply With Quote
Old 05-31-2019, 12:31 PM   #5
Looking at pics above. Please explain the reason for the dual switches to manually disconnect 12v power to the Fusion.
Mike H
Old 05-31-2019, 01:33 PM   #6
wachuko's Avatar
Orlando , Florida
Mike H
You have two wires (a yellow and a red) powering the Fusion... for some strange reason, that I have not been able to find an explanation for, you have to cut power to both for the unit to completely shut off... The red should have been switched to the ignition, but in mine it had power all the time. Both did, so I just did a switch for each wire.
FYI, with this setup you do not loose your settings or preset stations...
Safe travels!
Wachuko
WBCCI #26769
Old 11-03-2019, 04:57 PM   #7
Contributing Member
Pahaska's Avatar
Austin (Hays County) , Texas
I finally got around to installing the same Mercedes switches in the same place. I found something that baffles me. I have to have both switches on for the Fusion to light up, although both the red and the yellow wire are hot. If either switch is off, my Fusion is dead.
Since I use a dash-top trucker's GPS instead of the Fusion, the Fusion is simply a CD player. I find the Fusion display is way too far down and takes my eyes off the road. For the same reason, I use the dash-top GPS as my speedometer.
John W. Irwin
2018 Interstate GT, "Sabre-Dog V"
WBCCI #9632
Fusion radio controls issue mrgolf Sprinter and B-van Forum 5 06-02-2017 10:06 PM
Radio Speakers but no Radio 1969 ???? tdoescher 1965-1969 Sovereign 13 04-21-2015 01:17 PM
cb radio, cassette radio jagcb750 Classic Motorhomes 14 04-19-2012 02:32 PM
Fusion for Plastic 76sovereign Sinks, Showers & Toilets 11 09-05-2008 01:15 PM
Krylon "fusion" stuart1 Plumbing - Systems & Fixtures 2 06-24-2003 08:36 PM
