Continuing adventures...
LSS... the Mercedes Sprinter shop found and tested the battery boxes exactly where you showed them under the van, they said there is no way to charge them directly, and they were kind enough to connect up my battery tender to the terminals you posted are under the passenger seat (I didn't understand that we should look for the terminals under the passenger seat INSIDE the van, we didn't have to get under it
I took a photo of that terminal access under the passenger seat... fcol I coulda done that first... well anyway...
I used the same battery tender I use for my car/pick up, this one brand new out of the box.
It was on steady red light (connected propery, charging, should turn off when it completes the charging stage) when we hooked it up on Friday, its Sunday morning and I have a flashing red light on the battery charger, the battery tender manual says "The RED light flashing indicates that the battery charger has AC power available and that the microprocessor is functioning properly. If the RED light continues to flash then either the battery voltage is too low (less than 3 volts) or the output alligator clips or ring terminals are not connected correctly. The fuse in the output alligator clips or ring terminals may also be blown."
Ah so... this is what they are talking about in the post you linked...
https://www.airforums.com/forums/f24...ml#post2578886
Originally Posted by Vacayourway1
You can recharge AGM batteries if there completely dead I’ve done it several times, a friend of mine that’s own golf cart shop showed me years ago how they take supposedly dead batteries and recharge them. First you need to take a known good 12v battery and hook the battery charger to it and jumper cables from the good battery to the bad AGM battery, the charger will keep charging because it see’s a good battery. Another way is to have a old charger that doesn’t have all the smart sensor installed.
If that's correct, here's a couple questions before I try it...
Why wouldn't I just connect the terminals under the passenger seat with jumper cables to the battery in the Roadtrek with the Roadtrek engine running, like I did when I jumped the battery in the Airstream terminals in the engine compartment? Why would I connect the battery tender to the Roadtrek and then to the Airstream? Do they expect that the "good" battery is not installed in a vehicle?
Should I use a "good" battery that is not in a vehicle to try this method?
Many mucho mucho thanks
Oh and the battery tender manual says: "If you try to charge a dead battery having a voltage below 3 volts the Battery Tender charger will not start. An internal safety circuit prevents the charger from generating any output voltage unless it senses at least 3 volts at the charger output. In this situation the AMBER light will continue to clash, indicating that a charge has not been initiated."
That sounds like the post above except my battery tender is flashing Red, not Amber.
